海德堡Primefire 106数码喷墨印刷机
1 个附件
在Drupa2016海德堡正式发布Primefire 106数码喷墨印刷机,海德堡号称此机为“世界上首台用于工业化包装机商务印刷的B1幅面的喷墨印刷系统”。
此机最大进料幅面为:750mmx1060mm;最小进料幅面470mmx480mm 可接受材料克重从170g-450g不等;可接受材料厚度0.2-0.6mm; 这台喷墨机由CMYK+OGV七个颜色,据说对Pantone色域的覆盖率达到95%, 印刷模式为:Single Pass ,采用富士Samba 3GL喷头,最高分辨率1200x1200dpi,在此模式下的最高生产速度能达到2500张/小时! 这台机器由6部分组成,每部分的介绍信息如下: 1. Feeder The proven Preset Plus feeder looks after all the format and air settings required for steady sheet travel. 2. Conditioning unit The conditioner prepares the substrate surface for the water-based inkjet printing and produces highest dot sharpness for a precise printing result. 3. Jetting unit The jetting unit, powered by Fujifilm, offers space for seven printhead modules. The CMYK color space can be extended by orange, green, and violet. With the Heidelberg Multicolor Technology almost all common special colors are thus covered. 4. Dryer system The DryStar® drying system fully cures the ink and coating. This means that the sheet can go into postpress immediately without any loss of time. 5. Coating unit The conventional coating unit with CoatingStar® for pulsation-free coating delivery and integrated coating conditioning also is compatible with conventional offset coatings. 6. Prinect Digital Center Inline with Perfect Stack-Technology Together with the Prinect Digital Frontend the Prinect Digital Center Inline features the proven Heidelberg operating philosophy and seamlessly integrates your machine into process flows. A particular highlight: With the Perfect Stack Technology only perfect good sheets are placed. Furthermore test sheets will be output directly to the operator panel at the push of a button. Enjoy! |
| 所有时间均为 +8, 现在的时间是 2025-12-09 00:13. |
