旧 2011-05-23, 23:02     #1
zza5137495 zza5137495 当前离线
级别:12 | 在线时长:216小时 | 升级还需:5小时级别:12 | 在线时长:216小时 | 升级还需:5小时级别:12 | 在线时长:216小时 | 升级还需:5小时
Uid: 215607
注册日期: 2011-03-19, 15:38
感谢: 15
现金: 20金币
资产: 20金币
声望: 10 zza5137495 向着好的方向发展
Uid: 215607
感谢: 15
现金: 20金币
资产: 20金币
默认 施乐DC5065报错求救
施乐5065突然报错010-326,,,请求高手解释什么错误??什么原因及解决办法?????
zza5137495 当前离线
旧 2011-05-24, 01:52   只看该作者   #2
gwf530013617 gwf530013617 当前在线
全幼儿园最帅
Uid: 99784
注册日期: 2009-06-06, 14:47
来自: 垃圾堆旁边
感谢: 54
269 个帖子获得 352 次感谢
现金: 4136金币
资产: 4136金币
声望: 10 gwf530013617 向着好的方向发展
全幼儿园最帅
Uid: 99784
来自: 垃圾堆旁边
感谢: 54
269 个帖子获得 352 次感谢
现金: 4136金币
资产: 4136金币
10的代码一般都是定影的问题。。。
gwf530013617 当前在线
旧 2011-05-24, 09:59   只看该作者   #3
lixuok2010 lixuok2010 当前离线
帅哥 级别:16 | 在线时长:350小时 | 升级还需:7小时
Uid: 154673
注册日期: 2010-04-06, 11:34
9 个帖子获得 9 次感谢
声望: 10 lixuok2010 向着好的方向发展
Uid: 154673
9 个帖子获得 9 次感谢
010-326 RAP
BSD-ON:10.3 Fuser Heat Monitoring BSD
Wait Heat Roll Fuser On Time Fail. Main lamp #1, main lamp #2, or the sub lamp is continually
flashing abnormally during wait state.
NOTE: Wait state: the state during which lamps are used to adjust the temperature to what is
required for printing, after turning on the power, closing the front cover interlock, closing the
MSI cover interlock, or closing the marking drawer interlock.
Initial Actions
•Check that there is no foreign object on the Heat Roll surface and no paper wound around
it.
•Check the Heat Roll Thermistor 1 is free from dirt.
•Check that the Drawer Connectors (P/J612) connecting the Fuser Unit and the main unit
are free from bent pins, foreign objects and burnout.
•Check that the connectors (P/J146)(white) on the Heat Roll Thermistor 1 are connected.
•Check if DC131[744-00004](Fuser Warm Up Complete HR Temp)(Default:185) is set to a
higher temp.
•DC131[744-001](Warm Up Control Temp)(Default:192) and DC131[744-050](Ready Con-
trol Temp)(Default:185) are set to higher temperatures each.
lixuok2010 当前离线
旧 2011-05-24, 21:14   只看该作者   #4
ahog ahog 当前离线
级别:5 | 在线时长:58小时 | 升级还需:2小时级别:5 | 在线时长:58小时 | 升级还需:2小时
Uid: 17615
注册日期: 2006-06-16, 22:26
声望: 10 ahog 向着好的方向发展
ahog ahog 当前离线
Uid: 17615
010-326 Wait Heat Roll Fuser On Time Fail
参考:CH10.14
说明
Wait状态下,Fuser其中一个的Lamp一定时间异常连续On(亮灯),判定为Lamp、NC Sensor、Heat Roll Sensor的异常。
初始行动
OFF/ON电源。
重设Fuser。
确认Fuser Drawer接头部的异物。
确认Fuser是否被纸张缠住。
确认P/H Drawer。
步骤
确认 J405~ J612A/ J612B之间的断线、短路(CH10.3)。
J405~ J612A/ J612B之间是否无断路、短路,且正常接通?
Yes No
修理断线、短路。
确认 J407~ J510之间的断线、短路(CH10.2)。
J407~ J510之间是否无断线、短路,且正常接通?
Yes No
修理断线、短路。
确认 J16/ J15~ J612之间的断线、短路(CH10.2)。
J16/ J15~ J612之间是否无断线、短路,且正常接通?
Yes No
修理断线、短路。
测量各Lamp两端的电阻。各Lamp是否无断线,且有一定的电阻值?
Yes No
更换断线的Lamp(PL 8.2)。
确认Fuser Centor NC Sensor(PL 8.3)、Fuser Rear NC Sensor(PL 8.3)、Heat Roll Sensor(PL 8.3)的表面。表面是否脏污?
Yes No
更换断线的Lamp(PL 8.2)。
依序更换Fuser Assy(PL 8.1)、AC Unit(PL 11.3)、MCU PWB(PL 11.1)。
ahog 当前离线
旧 2011-05-26, 00:18   只看该作者   #5
china-yb 的头像
china-yb china-yb 当前离线
级别:18 | 在线时长:419小时 | 升级还需:18小时级别:18 | 在线时长:419小时 | 升级还需:18小时级别:18 | 在线时长:419小时 | 升级还需:18小时
Uid: 135769
注册日期: 2009-12-18, 13:18
感谢: 28
24 个帖子获得 28 次感谢
现金: 46金币
资产: 46金币
声望: 10 china-yb 向着好的方向发展
china-yb 的头像
Uid: 135769
感谢: 28
24 个帖子获得 28 次感谢
现金: 46金币
资产: 46金币
如果没有记错的话,一般把744-350改成0就可以了的!
china-yb 当前离线
旧 2011-08-18, 02:10   只看该作者   #6
see see 当前离线
级别:23 | 在线时长:635小时 | 升级还需:37小时级别:23 | 在线时长:635小时 | 升级还需:37小时级别:23 | 在线时长:635小时 | 升级还需:37小时级别:23 | 在线时长:635小时 | 升级还需:37小时级别:23 | 在线时长:635小时 | 升级还需:37小时
Uid: 23397
注册日期: 2006-09-18, 14:39
声望: 10 see 向着好的方向发展
see see 当前离线
Uid: 23397
声望: 10 see 向着好的方向发展
热辊温度过热保护......进维修模式DC131 744-350 重置为""0"".
see 当前离线
旧 2011-08-19, 10:28   只看该作者   #7
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
注册日期: 2010-04-19, 17:09
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
声望: 24 修施乐的海贼 向着好的方向发展
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
应该属于超温或者温度不达标类型的吧
先按照楼上的修改下试试
声 明 如 下:
TEL:15565218000 [V信同号];
[抖音号:zenjusthaizei(V信同号)];
TaoBao:正品施乐耗材旗舰店
←请点击
修施乐的海贼 当前离线
旧 2011-08-20, 20:02   只看该作者   #8
63761527 63761527 当前离线
级别:7 | 在线时长:86小时 | 升级还需:10小时级别:7 | 在线时长:86小时 | 升级还需:10小时级别:7 | 在线时长:86小时 | 升级还需:10小时级别:7 | 在线时长:86小时 | 升级还需:10小时
Uid: 180787
注册日期: 2010-08-22, 20:58
来自: 四川
8 个帖子获得 9 次感谢
声望: 10 63761527 向着好的方向发展
Uid: 180787
来自: 四川
8 个帖子获得 9 次感谢
在指定时间里温度为答到,,,,,,,,,,,,,
63761527 当前离线
旧 2011-08-20, 20:21   只看该作者   #9
ncjingxi ncjingxi 当前离线
Uid: 90831
注册日期: 2009-04-10, 15:03
感谢: 93
92 个帖子获得 109 次感谢
现金: 453金币
资产: 453金币
声望: 10 ncjingxi 向着好的方向发展
Uid: 90831
感谢: 93
92 个帖子获得 109 次感谢
现金: 453金币
资产: 453金币
凡是010打头的代码大多数关机再开机就行了,多出现在较旧的定影器上。如果报错频繁全包机的话报个修换个组件就是,二手机那就凑合着用,实在烦换个组件也不是太贵。
ncjingxi 当前离线
所有时间均为 +8, 现在的时间是 2025-12-06 15:38.
