旧 2019-02-22, 09:18     #1
qq5611057 qq5611057 当前离线
Uid: 651890
注册日期: 2019-02-15, 14:38
声望: 10 qq5611057 向着好的方向发展
Uid: 651890
对眼 求教喷墨打印机
经常印一些文件袋、信封、请柬、名片等产品,而且是比一般的还要厚,纸张厚度1--2mm之间吧。
所以问问大家应该选哪种打印机好?
要求:
1.进纸吃纸能力强, 打印头空间高的(或者可调高度),不卡纸的
2.打印速度快,
qq5611057 当前离线
旧 2019-02-22, 20:24   只看该作者   #2
madhuronda 的头像
madhuronda madhuronda 当前离线
级别:8 | 在线时长:111小时 | 升级还需:6小时级别:8 | 在线时长:111小时 | 升级还需:6小时
Uid: 652048
注册日期: 2019-02-17, 18:17
来自: 8-224,rosiah street,vijayawada,AP-7,India
8 个帖子获得 17 次感谢
现金: 23金币
资产: 23金币
声望: 10 madhuronda 向着好的方向发展
madhuronda 的头像
Uid: 652048
8 个帖子获得 17 次感谢
现金: 23金币
资产: 23金币
Hello Brother,
go for color inkjet printer in general.note following points as well
1.Color inkjet printers offer superior results compared to color laser printers when printing detailed images. Laser printers are fine for documents with lots of text but if you are printing an intricate font on your invites, an inkjet printer is the way to go.
2.Every printer here can handle a range of customizable paper types and sizes. Invites, envelopes and place cards require varying degrees of adjustment depending on your paper preference.
3.A rear paper feed is another must-have for any DIY stationery project. Rear feed printing lets you feed specialty paper like cardstock one by one into the machine, circumventing any potential curling or jamming issues that occur when printing from the more common front feed tray.
4.Cartridge costs can vary greatly across printer models and some offer more prints than others for a better overall value. To compare printing costs, take note of the cartridge size and page yield. High yield and extra high yield cartridges include more ink than a standard cartridge, giving you more prints per cartridge.
(⚠警告: 用户发帖严重违规!)
madhuronda 当前离线
旧 2019-02-22, 22:06   只看该作者   #3
4190 4190 当前离线
级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时级别:47 | 在线时长:2423小时 | 升级还需:73小时
Uid: 4418
注册日期: 2005-08-10, 17:14
年龄: 52
69 个帖子获得 98 次感谢
现金: 1509金币
资产: 1509金币
声望: 10 4190 向着好的方向发展
4190 4190 当前离线
Uid: 4418
年龄: 52
69 个帖子获得 98 次感谢
现金: 1509金币
资产: 1509金币
说的不错,就是俺英文水平不高,看了半天才看明白,幸好做过远洋船舶驾驶员,轮机员,电机员
4190 当前离线
旧 2019-02-22, 22:33   只看该作者   #4
limuma limuma 当前离线
级别:8 | 在线时长:114小时 | 升级还需:3小时级别:8 | 在线时长:114小时 | 升级还需:3小时
Uid: 263880
注册日期: 2011-11-08, 09:22
声望: 10 limuma 向着好的方向发展
limuma limuma 当前离线
Uid: 263880
你需要的就是平板打印机了,用爱普生的打印机来改装的。
limuma 当前离线
旧 2019-02-23, 09:11   只看该作者   #5
qzp505 qzp505 当前在线
级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时级别:100 | 在线时长:10413小时 | 升级还需:192小时
Uid: 196961
注册日期: 2010-11-28, 21:38
35 个帖子获得 36 次感谢
现金: 390金币
资产: 390金币
声望: 10 qzp505 向着好的方向发展
qzp505 qzp505 当前在线
Uid: 196961
35 个帖子获得 36 次感谢
现金: 390金币
资产: 390金币
作者: madhuronda 查看帖子
Hello Brother,
1.Color inkjet printers offer superior results compared to color laser printers when printing detailed images. Laser printers are fine for documents with lots of text but if you are printing an intricate font on your...
印度兄弟,你这个比较并不全面。1、你说得喷墨比激光机器表现图像细节有优势,那得看是什么样的机器。如果四色与四色比,情况就不一样了。无论是HP、EPSON、CANON等的四色喷墨,都不可与四色激光机比较效果和速度的。
2、处理页面尺寸和材质范围两者不相上下的。当然,喷墨的幅面目前比激光的大很多。并且,颜色的数量也成倍或数倍增加了。但此时的应用范围就不同了。
3、进纸模式确实很重要,对于上述中国用户来说,纸的厚度很大,激光目前确实解决不了,因此你说得后进纸应该是必须的。最好是平进平出,因此楼上说的平板喷墨打印机就是最佳选择。
4、cartridges墨盒就不用担心我们中国人的才智了,我们南方生产的很多墨盒都销到你印度等国家了。至于墨盒大小,对中国人来说,那简直是a piece of cake,小菜一碟!听说众人的连供吧?你到医院打点滴那玩儿,哪个本地用户不在玩?
所以,印度兄弟,请说明具体型号,性价比比较适合楼主,最好时亲自使用过的,才有帮助。
qzp505 当前在线
旧 2019-02-23, 10:00   只看该作者   #6
wonduin wonduin 当前离线
级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时级别:46 | 在线时长:2384小时 | 升级还需:13小时
Uid: 404825
注册日期: 2014-05-20, 20:45
35 个帖子获得 36 次感谢
现金: 585金币
资产: 585金币
声望: 10 wonduin 向着好的方向发展
Uid: 404825
35 个帖子获得 36 次感谢
现金: 585金币
资产: 585金币
把单个要求拿出来讲并不算高,佳能的桌面机进纸就比较强,比爱普生要好,喷头高度就连最基础的R230都可以调,这些不在话下。
但结合实际用途,要求就比较高了,文件袋、请柬、名片密度基本都不少于300g,尤其文件袋,鼓起来容易碰到喷头。一般喷墨机进纸轮都是小小的,不耐用,打不了多少厚纸就坏了,L型进纸的都不行,只有平进平出的机器能搞得定,即平板打印机,介质以纸类居多的打颜料墨就行了,对付铜版纸之类吸墨能力不佳的就要带个加热装置
wonduin 当前离线
旧 2019-03-06, 10:29   只看该作者   #7
Uid: 651890
Uid: 651890
作者: limuma 查看帖子
兄台,可以给个具体的机器型号吗?
qq5611057 当前离线
所有时间均为 +8, 现在的时间是 2025-12-11 22:55.
