旧 2007-09-02, 23:02     #1
anthGun anthGun 当前离线
级别:14 | 在线时长:255小时 | 升级还需:30小时级别:14 | 在线时长:255小时 | 升级还需:30小时级别:14 | 在线时长:255小时 | 升级还需:30小时级别:14 | 在线时长:255小时 | 升级还需:30小时级别:14 | 在线时长:255小时 | 升级还需:30小时
Uid: 49906
注册日期: 2007-08-21, 01:21
声望: 10 anthGun 向着好的方向发展
Uid: 49906
默认 我购一台六开胶印机, 請給意見
我要來印彩色跑175lpi网點, 用卡紙230gms印, 一下兩台六开胶印机使合用嗎机器性能如何! 請給意見..
自印度的六开胶印机(Autoprint)
Autoprint 1520 FL and Knight
http://www.autoprint.net/images/machine1520.jpg Autoprint 1520 FL (frontloading) with a maximum paper size of 15" x 20", can be ideally utilized in letter press and big offset houses, where in short run and low end jobs can be undertaken. The Autoprint 1520 FL is the ideal upgradation solution for present users as well, since it enables printing using both direct offset master as well as plate.
The 'Plug 'N' Print' capabilities of the machine are complemented by a country-wide support network and Autoprint's highly customer focussed approach to marketing.
A world - class AC drive as standard feature enables use of rugged 3 phase squirrel cage motors resulting in low noise and power consumption. All switchgears are of high quality. Low weight chain gripper assembly helps improve gripper performance and fewer setting changes.
http://www.autoprint.net/topics/features.gifhttp://www.autoprint.net/images/doublearrow.gifPaper Guides On Feeder Table
http://www.autoprint.net/images/doublearrow.gifControl Panel
http://www.autoprint.net/images/doublearrow.gifThree Cylinder - Chain Delivery
http://www.autoprint.net/images/doublearrow.gifFront Loading (FL) Features
http://www.autoprint.net/images/doublearrow.gifSide Lay Registration
http://www.autoprint.net/images/doublearrow.gifOscillation System
http://www.autoprint.net/images/doublearrow.gifDuctor Assembly
http://www.autoprint.net/images/doublearrow.gifCentralised Lubrication System
http://www.autoprint.net/topics/techspec.gif Maximum paper size Minimum paper size Printing area (Maximum) Blanket Gripper margin on plate Gripper margin on paper Gripper bite Paper thickness Plate thickness Direct offset master thickness
Inking unit
Dampening unit Main drive motor
Pump Motor Speed Physical dimensions (L x W x H) Net weight Gross weight Lubrication
http://www.autoprint.net/products/knight/knight_01.jpghttp://www.autoprint.net/products/knight/knight_02.jpghttp://www.autoprint.net/products/knight/knight_03.jpghttp://www.autoprint.net/products/knight/knight_04.jpghttp://www.autoprint.net/products/knight/knight_05.jpg
Autoprint has been the Indian pioneer in the manufacture of sophisticated mini-offset printers and other machines for the printing industry. Built to offer high quality results with economy and reliability, the machines have been designed to meet the requirement for quality short run jobs. Utilizing technology developed by Autoprint's own R & D Centre, the machines have proved their worth not only in India but abroad as well. The 'Plug 'N' Print' capabilities of the machine are complemented by a country-wide support network and Autoprint's highly customer focused approach to marketing.
The quality of large offset. The features of large offset. The price of mini offset. Presenting Autoprint Knight: the machine you helped design!
You wanted a machine that could elevate your printing jobs from cut-colour to multi-colour, from mediocre to high quality, from limited benefits to advanced features
Your needs and your feedback have played a major role in the creation of
Autoprint Knight: a single colour mini offset machine that can offer you excellent multi-colour quality at affordable prices. Autoprint Knight is an ideal upgradable solution for small offset printers across the country - and the world!
Autoprint Knight comes to you with most of the features of large offset. So you can get the quality of large offset in small format printing. In fact, it is for the first time, that a small offset machine has been packed with so many sophisticated features!
http://www.autoprint.net/topics/features.gifhttp://www.autoprint.net/images/doublearrow.gifInking & Dampening System
http://www.autoprint.net/images/doublearrow.gifBellow Suckers, Ball Shoe Guides
http://www.autoprint.net/images/doublearrow.gifDelivery Stacker
http://www.autoprint.net/images/doublearrow.gifPressure Adjusting Scale
http://www.autoprint.net/images/doublearrow.gifPull Type Side Lay
http://www.autoprint.net/images/doublearrow.gifPlate Clamp
http://www.autoprint.net/images/doublearrow.gifSwing Type Ink Duct
http://www.autoprint.net/products/images/mousehelp.gif
http://www.autoprint.net/topics/glance.gif
http://www.autoprint.net/images/doublearrow.gif Front Loading
http://www.autoprint.net/images/doublearrow.gif Three Cylinder Design
http://www.autoprint.net/images/doublearrow.gif Chain Delivery System
http://www.autoprint.net/images/doublearrow.gif Paper Guides on Feeder Table for easy adjustment and feeding of various paper stocks and sizes
http://www.autoprint.net/images/doublearrow.gif A hi-tech Double Sheet Detector
http://www.autoprint.net/images/doublearrow.gif No Sheet Detector
http://www.autoprint.net/images/doublearrow.gif Gear-driven Oscillators
http://www.autoprint.net/images/doublearrow.gif Large Ink Fountain Roller of 60 mm dia and a mechanism of fine control with 8 steps
http://www.autoprint.net/topics/techspec.gif Maximum Paper SizeMinimum Paper SizePrinting Area (Maximum)BlanketGripper Margin on PlateGripper Margin on PaperGripper BitePlate ThicknessPaper ThicknessInking UnitDampening UnitMain Drive MotorCompressor Pump MotorControl PanelSpeedLubricationPhysical Dimensions L x W x H Net WeightGross Weight 380 x 508 mm100 x 150 mm357 x 490 mm4 Ply Rubber blanket, 1.9 mm thickness32 mm9 mm4 mm0.2 mm (Direct Offset Master can also be used)30 to 300 gsm15 Rollers including 4 Oscillators and 3 Form Rollers5 Rollers including 1 Oscillator and 2 Form Rollers1 HP AC 3 Phase (Connectable to Single Phase Power Supply)1 HP AC Single PhaseLatest productivity monitoring type1500 to 6000 iphCentralised Lubrication system1700 x 1340 x 1400 mm1200 Kgs. Approximately1500 Kgs. Approximately 380 x 508 mm 125 x 175 mm 350 x 485 mm 4 Ply rubber blanket, 1.9 mm thick 32 mm (1.25") 13 mm 4 mm 30 to 300 gsm 0.05 to 0.2 mm 100 micron 11 Rollers, 3 Oscillators, 2 Form Rollers 4 Rollers, 1 Oscillator, 1 Form Roller 1 HP AC 3 phase
(connectable in single phase power supply) 1 HP AC single phase 1500 to 5000 iph 1700 x 1200 x 1400 mm 1100 Kg approx. (un packed) 1400 Kg approx. (packed) Centralised lubrication system
anthGun 当前离线
旧 2007-09-03, 12:46   只看该作者   #2
news news 当前离线
Uid: 6785
注册日期: 2005-10-20, 21:04
感谢: 455
116 个帖子获得 263 次感谢
现金: 122金币
资产: 122金币
声望: 16 news 向着好的方向发展
news news 当前离线
Uid: 6785
感谢: 455
116 个帖子获得 263 次感谢
现金: 122金币
资产: 122金币
印度的机器没见过,不敢妄发评论。如果机器好,售后服务也跟的上的话,楼主不妨试试
news 当前离线
旧 2007-09-06, 21:04   只看该作者   #3
唯一 唯一 当前离线
帅哥 级别:6 | 在线时长:64小时 | 升级还需:13小时级别:6 | 在线时长:64小时 | 升级还需:13小时级别:6 | 在线时长:64小时 | 升级还需:13小时
Uid: 49781
注册日期: 2007-08-20, 09:37
声望: 10 唯一 向着好的方向发展
唯一 唯一 当前离线
Uid: 49781
声望: 10 唯一 向着好的方向发展
唯一 当前离线
旧 2007-09-07, 08:31   只看该作者   #4
leadmeng leadmeng 当前离线
级别:19 | 在线时长:452小时 | 升级还需:28小时级别:19 | 在线时长:452小时 | 升级还需:28小时级别:19 | 在线时长:452小时 | 升级还需:28小时级别:19 | 在线时长:452小时 | 升级还需:28小时
Uid: 2443
注册日期: 2005-03-24, 13:04
声望: 10 leadmeng 向着好的方向发展
Uid: 2443
是呀印度的机器行吗?lz是不是觉得便宜呀,多少钱一台???
leadmeng 当前离线
旧 2007-09-07, 14:21   只看该作者   #5
小城 小城 当前离线
帅哥 级别:27 | 在线时长:851小时 | 升级还需:45小时级别:27 | 在线时长:851小时 | 升级还需:45小时级别:27 | 在线时长:851小时 | 升级还需:45小时级别:27 | 在线时长:851小时 | 升级还需:45小时级别:27 | 在线时长:851小时 | 升级还需:45小时级别:27 | 在线时长:851小时 | 升级还需:45小时
Uid: 6990
注册日期: 2005-10-26, 09:09
来自: 佛山
2 个帖子获得 3 次感谢
声望: 10 小城 向着好的方向发展
小城 小城 当前离线
Uid: 6990
来自: 佛山
2 个帖子获得 3 次感谢
声望: 10 小城 向着好的方向发展
LZ你那个有中文就好,可以看下介绍,价格方面应该是高过国产的吧!你可以试下机器啊!自己拿个版去试下就知道了~~
小城 当前离线
旧 2007-09-23, 10:21   只看该作者   #6
lixinyinshua lixinyinshua 当前离线
Uid: 47749
注册日期: 2007-08-02, 09:23
声望: 10 lixinyinshua 向着好的方向发展
Uid: 47749
lixinyinshua 当前离线
旧 2007-10-04, 13:51   只看该作者   #7
海阔天空最早 海阔天空最早 当前离线
级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时级别:55 | 在线时长:3326小时 | 升级还需:34小时
Uid: 54207
注册日期: 2007-09-25, 22:45
35 个帖子获得 36 次感谢
现金: 268金币
资产: 268金币
声望: 10 海阔天空最早 向着好的方向发展
海阔天空最早 海阔天空最早 当前离线
Uid: 54207
35 个帖子获得 36 次感谢
现金: 268金币
资产: 268金币
威海滨田的六开机就不错,性能稳定,机器加工精度高,我一直用的,单色机印彩活。小胶印机没有必要买进口的,何况是印度的,印刷技术杂志上考察的说他们的印刷技术至少比我们晚十年。
海阔天空最早 当前离线
旧 2007-10-09, 11:01   只看该作者   #8
Uid: 47749
Uid: 47749
lixinyinshua 当前离线
旧 2007-11-09, 22:32   只看该作者   #9
亿林 亿林 当前离线
Uid: 59707
注册日期: 2007-11-09, 21:49
声望: 10 亿林 向着好的方向发展
亿林 亿林 当前离线
Uid: 59707
声望: 10 亿林 向着好的方向发展
那位朋友加我qq,我是新手,想请教一些问题771921639
亿林 当前离线
旧 2007-11-09, 23:24   只看该作者   #10
drhames drhames 当前离线
帅哥 级别:38 | 在线时长:1601小时 | 升级还需:76小时级别:38 | 在线时长:1601小时 | 升级还需:76小时级别:38 | 在线时长:1601小时 | 升级还需:76小时级别:38 | 在线时长:1601小时 | 升级还需:76小时级别:38 | 在线时长:1601小时 | 升级还需:76小时
Uid: 9025
注册日期: 2005-12-10, 22:30
来自: GZ
现金: 28金币
资产: 188金币
声望: 10 drhames 向着好的方向发展
Uid: 9025
来自: GZ
现金: 28金币
资产: 188金币
哪机器应该是深圳代理的吧!哪家什么都什么!就是不精
售后你就知道了!好像这促印度的机子不能印薄纸!
还是支持国产好了!
drhames 当前离线
旧 2007-11-15, 12:54   只看该作者   #11
fanjianfong fanjianfong 当前离线
级别:1 | 在线时长:11小时 | 升级还需:1小时
Uid: 60337
注册日期: 2007-11-15, 09:01
声望: 10 fanjianfong 向着好的方向发展
Uid: 60337
钱少的话(十几万),国产景德镇或威海的
钱多的话(80万)进口的海德堡GTO52就很好,我现在还用
fanjianfong 当前离线
旧 2007-12-19, 20:50   只看该作者   #12
qwf_12000 qwf_12000 当前离线
级别:8 | 在线时长:109小时 | 升级还需:8小时级别:8 | 在线时长:109小时 | 升级还需:8小时
Uid: 62531
注册日期: 2007-12-19, 20:08
2 个帖子获得 3 次感谢
现金: -92金币
资产: -92金币
声望: 10 qwf_12000 向着好的方向发展
Uid: 62531
2 个帖子获得 3 次感谢
现金: -92金币
资产: -92金币
印度的机器好像真没见过,建议还是买国产的,如果二手的话更不要买了,就怕到时连个配件也一时买不到。还是支持国产的好了,威海滨田应该不错的。
qwf_12000 当前离线
相似的主题
主题 主题作者 论坛 回复 最后发表
我购一台华光六开胶印机, 請給意見 anthGun ◆- 普通 & 高保真胶印技术 2 2007-10-04 13:57
我购一台东航六开胶印机, 請給意見 anthGun ◆- 普通 & 高保真胶印技术 9 2007-08-27 08:09
转让一台日本良明480K-NP六开打码胶印机 brenfeng ◆- 印刷企业经营与管理 0 2006-10-28 00:45
转让一台日本良明480K-NP六开打码胶印机 brenfeng ◆- 普通 & 高保真胶印技术 0 2006-10-28 00:39
所有时间均为 +8, 现在的时间是 2025-12-02 17:11.
