旧 2005-03-31, 11:42     #1
帅哥 级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时级别:243 | 在线时长:60091小时 | 升级还需:421小时
2759 个帖子获得 17601 次感谢
现金: 3574金币
资产: 13689金币
现金: 3574金币
资产: 13689金币
难过 【讨论】Onyx Postershop 6.0 rip是个啥东西?
有人传到论坛的,不知是那个厂家的,效果用途如何?
6.0 README.TXT file
Last Revised: 6/19/2003
Copyright (C) 2003 Onyx Graphics
THIS VERSION IS READY FOR PRODUCTION PRINTING.
All Known issues are fixed or are listed below.
If you have any questions, comments or bugs, please contact
Onyx Technical Support at 800 295-8324, 801 984-5353, and/or
support@onyxgfx.com.
Important information in this text file:
- Suggested Minimum Requirements
- Security Key issues
- Installation issues
- Known Issues
- Other License Agreements
For the latest fixes and information regarding the product,
visit the Onyx Graphics website at www.onyxgfx.com.
Onyx Workflow 6.0
Operating System:
- Windows 2000?Server w/SP3, Windows 2000-Pro?w/Latest Service Pack, Windows XP Pro?w/Latest Service Pack
- CPU: Intel Pentium III / Athalon , 1.5 Ghz or Higher, (Dual CPU System Required for Production House)
- Storage: 40 Gb Hard Drive, 1Gb RAM per CPU
- Video Display: 1280x768 16-bit Color
- One USB Port Required for Security Key
- DVD-ROM Drive Suggested, 40x CD-ROM Minimum Required
Security Key Issues
- USB Security Keys do not work with Windows NT Workstation or Windows NT
Server.
- Parallel security keys do not work with Windows XP-Pro(R) and Windows XP-Home(R).
Please contact your sales representative to upgrade your parallel key to a USB key
800-828-0723.
Installation:
- If you have a previous installation on your system, 6.0 will override the previous version.
- Please back up your printer information by creating a prninst of each printer.
Known issues
- When using the Mutoh Ultima and left Justify, you must also use a 1-inch offset.
- When processing files using the overprint option, it is necessary to
have an input profile selected.
- Onyx Workflow has two basic modes in which PDF files can be ripped. The default installation
is set to use the fastest mode. If the user is having troubles with some of the more
esoteric pdf files in rip Configuration check the "Transparency - ON".
- When editing the profile dialogue in Preflight for an image that was previously printed
the associated profiles will be lost once you select ok. If you wish to keep the associated profiles,
do not select ok.
- The Mutoh Ultima cutter uses a virtual or simulated COM port for USB communication.
When installing the Mutoh Ultima cutter: You must first install the USB driver from the Mutoh CD
then go to device manager and use the com port listed next to the Mutoh Ultima.
Media Manager
- RIP-Queue must be running for Media Manager to build, delete, or rename a
media.
- If a linearization is copied in Media Manager the Media Model is not copied.
Localization
- Web Portal (HTTP Access) language display is controlled by the Web browser language on the client system.
- Supported Web browsers are Explorer and Netscape.
RIP-Queue
- In RIP-Queue the Printer Status is listed as Nesting, even though Print
Jobs Individually was selected as the printer's Placement strategy.
- When using Step and Repeater, if an image's output width/height is set larger
than the target printer can handle, RIP-Queue will shrink the image to
fit the printer's page size.
- Canceling the ripping of an image while a printer is initializing
causes RIP- Queue to hang.
- When modifying postscript files in Preflight, the preview image may not be
updated in RIP-Queue. You can right-click on the image and click Refresh and
the new image preview should be displayed.
- Once a job has started to preview in Rip-Queue, it is not possible to cancel
the previewing process.
Tiff Files
- TIFF-IT Files containing vector data are not supported.
These will open, but the vector data will not be printed correctly.
You must save these files in a different format.
PPD's
- If you are using Microsoft Windows Me(R) or Microsoft Windows 98(R) to
connect to a remote PC that is either Microsoft Windows NT(R) or
Microsoft Windows 2000(R), the PPD's used in this process are updated when
the remote printer is updated.
Operating System Notes:
To use the product effectively, we assume that you are familiar with the
Microsoft(R) Windows(R) Operating System platforms. If you have problems or questions
regarding Windows platforms, please contact
Microsoft Customer Service at: (206) 635-7000.
In Canada call (905) 568-4494.
Onyx Graphics does not provide Technical Support for Microsoft Windows.
Java Runtime Environment License
This product includes code licensed from RSA Security, Inc.
Some portions licensed from IBM are available at http://oss.software.ibm.com/icu4j/
Apache License
This product includes software developed by the Apache Software Foundation.
http://www.apache.org
Jetty License
The files java.servlet.jar and org.mortbay.jetty.jar (Jetty Package) are distributed by
Mort Bay Consulting Pty. Ltd.(Australia) The standard version of the Jetty package is
available from http://jetty.mortbay.org
Cos.jar End User License
The source code, object code, and documentation in the com.oreilly.servlet package is
licensed by Hunter Digital Ventures, LLC.
MrSID End User License
Portions of this software incorporating MrSID functionality are provided
under license from LizardTech, Inc. The MrSID software is protected by
United States Copyright Law and International Treaty provisions and by
U.S. Patent No. 5,710,835. Foreign patents are pending. Some of the MrSID
technology was developed through a project at the Los Alamos National
Laboratory (LANL) funded by the U.S. Government, managed under contract by
the Regents of the University of California (University). The U.S.
Government and the University have reserved rights in the Technology,
including the following:
(a) the U.S. Government has a non-exclusive, nontransferable, irrevocable,
paid-up license to practice or have practiced throughout the world, for or
on behalf of the United States, inventions covered by the University's
Patent Rights, and has other rights under 35 U.S.C. ?200-212 and applicable
implementing regulations and under the U.S. Department of Energy (DOE)
Assignment and Confirmatory License through which the DOE's rights in the
Technology were assigned to the University; (b) Under 35 U.S.C. ?203,
the DOE has the right to require LizardTech to grant a non-exclusive,
partially exclusive or exclusive license under U.S. Patent No. 5,710,835
in any field of use to a responsible applicant(s) upon terms reasonable
under the circumstances, if LizardTech does not adequately attempt to
commercialize the MrSID Technology. See, 37 CFR 401.6; (c) The University
makes no warranty or representation as to the validity or scope of
Patent No. 5,710,835, and neither the Government nor the University have
any obligation to furnish any know-how, technical assistance, or technical
data in connection with MrSID software. For further information about
these provisions, contact LizardTech, 1008 Western Ave., Suite 200,
Seattle, WA 98104.
此帖于 2005-03-31 12:09 被 wangyu1314 编辑.
wangyu1314 当前离线
旧 2005-03-31, 20:45   只看该作者   #2
A-J A-J 当前离线
扫地小沙弥
级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时级别:218 | 在线时长:48621小时 | 升级还需:216小时
Uid: 1047
注册日期: 2004-10-15, 12:00
感谢: 2910
1107 个帖子获得 2907 次感谢
现金: 27932金币
资产: 43309金币
声望: 58 A-J 身上有一圈迷人的光环哦
A-J A-J 当前离线
扫地小沙弥
Uid: 1047
感谢: 2910
1107 个帖子获得 2907 次感谢
现金: 27932金币
资产: 43309金币
只是一個噴畫機的RIP類似BEST ORIS
支援的部分機種請參考我的附件
文件类型: pdf Hardware Key.pdf (54.9 KB, 99 次查看)
A-J 当前离线
旧 2005-04-01, 11:58   只看该作者   #3
y8888 的头像
y8888 y8888 当前离线
VIP会员
级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时级别:107 | 在线时长:12072小时 | 升级还需:24小时
Uid: 344
注册日期: 2004-06-20, 12:00
年龄: 76
感谢: 192
224 个帖子获得 330 次感谢
现金: 137金币
资产: 137金币
声望: 36 y8888 是将要出名的人啊
y8888 y8888 当前离线
VIP会员
y8888 的头像
Uid: 344
年龄: 76
感谢: 192
224 个帖子获得 330 次感谢
现金: 137金币
资产: 137金币
看来有好多东东我们都没有听过。在这里是可以学到很多啊。
y8888 当前离线
旧 2005-07-10, 17:47   只看该作者   #4
qyc0456 qyc0456 当前离线
Uid: 3561
注册日期: 2005-06-23, 11:03
声望: 10 qyc0456 向着好的方向发展
Uid: 3561
就是rip 有点类似于蒙泰之类就是了 只不过要比蒙泰好多了 :)
qyc0456 当前离线
旧 2005-07-31, 00:38   只看该作者   #5
wxleng888 wxleng888 当前离线
级别:8 | 在线时长:109小时 | 升级还需:8小时级别:8 | 在线时长:109小时 | 升级还需:8小时
Uid: 4135
注册日期: 2005-07-30, 00:57
年龄: 25
声望: 10 wxleng888 向着好的方向发展
Uid: 4135
年龄: 25
大幅面写真机用的RIP :p 很好的哦,希望得到,我有PJ
wxleng888 当前离线
旧 2005-08-01, 16:12   只看该作者   #6
dong-dong dong-dong 当前离线
级别:51 | 在线时长:2859小时 | 升级还需:53小时级别:51 | 在线时长:2859小时 | 升级还需:53小时级别:51 | 在线时长:2859小时 | 升级还需:53小时级别:51 | 在线时长:2859小时 | 升级还需:53小时级别:51 | 在线时长:2859小时 | 升级还需:53小时级别:51 | 在线时长:2859小时 | 升级还需:53小时
Uid: 3877
注册日期: 2005-07-16, 12:00
感谢: 140
38 个帖子获得 46 次感谢
现金: 99金币
资产: 225金币
声望: 10 dong-dong 向着好的方向发展
Uid: 3877
感谢: 140
38 个帖子获得 46 次感谢
现金: 99金币
资产: 225金币
選擇這個網站,沒錯,真的可以學很多東西,因為這裡的專業技術才是真正的專業技術,出現什麼新東西也是這個網站最早發現的,並奉獻出來供大家學習!好好!!
dong-dong 当前离线
旧 2005-08-01, 16:18   只看该作者   #7
Uid: 3877
感谢: 140
38 个帖子获得 46 次感谢
现金: 99金币
资产: 225金币
Uid: 3877
感谢: 140
38 个帖子获得 46 次感谢
现金: 99金币
资产: 225金币
這個網站還有一個好處就是速度快,版主,這個網站的服務器在哪裡啊?這個網站是我上印刷論談網最快的一個,所以我特喜歡,不知大家覺得怎麼樣?反應真快!! :14: :14: :14: :14:
dong-dong 当前离线
旧 2005-08-02, 11:28   只看该作者   #8
ayuan ayuan 当前离线
级别:49 | 在线时长:2679小时 | 升级还需:21小时级别:49 | 在线时长:2679小时 | 升级还需:21小时级别:49 | 在线时长:2679小时 | 升级还需:21小时级别:49 | 在线时长:2679小时 | 升级还需:21小时
Uid: 3412
注册日期: 2005-06-11, 17:27
声望: 10 ayuan 向着好的方向发展
ayuan ayuan 当前离线
Uid: 3412
怎样才能得到呀,我很需要的呀,是中文的么?
ayuan 当前离线
旧 2005-08-03, 05:11   只看该作者   #9
eddie1 eddie1 当前离线
级别:44 | 在线时长:2194小时 | 升级还需:11小时级别:44 | 在线时长:2194小时 | 升级还需:11小时级别:44 | 在线时长:2194小时 | 升级还需:11小时级别:44 | 在线时长:2194小时 | 升级还需:11小时级别:44 | 在线时长:2194小时 | 升级还需:11小时
Uid: 3880
注册日期: 2005-07-16, 17:34
21 个帖子获得 77 次感谢
现金: 174金币
资产: 245金币
声望: 11 eddie1 向着好的方向发展
eddie1 eddie1 当前离线
Uid: 3880
21 个帖子获得 77 次感谢
现金: 174金币
资产: 245金币
这个 RIP 应该是比较偏向出大图用的 RIP, 1bit TIFF 并不支援. 如果打算要做数码打样的话, 小弟我是不会建议使用此套 RIP. :em31:
不过此套 RIP 价钱真的是蛮便宜的 :14:
eddie1 当前离线
旧 2005-08-03, 05:12   只看该作者   #10
eddie1 eddie1 当前离线
Uid: 3880
21 个帖子获得 77 次感谢
现金: 174金币
资产: 245金币
eddie1 eddie1 当前离线
Uid: 3880
21 个帖子获得 77 次感谢
现金: 174金币
资产: 245金币
作者: wxleng888
兄弟, 有 pj 的话, 不妨分享给大家呗 :em31:
eddie1 当前离线
旧 2005-08-03, 23:03   只看该作者   #11
kelly33 kelly33 当前离线
Uid: 4248
注册日期: 2005-08-03, 22:13
声望: 10 kelly33 向着好的方向发展
Uid: 4248
Onyx Postershop 6.0 rip......no good soft
kelly33 当前离线
旧 2005-08-21, 09:12   只看该作者   #12
波波 波波 当前离线
Uid: 4648
注册日期: 2005-08-21, 09:08
年龄: 28
声望: 10 波波 向着好的方向发展
波波 波波 当前离线
Uid: 4648
年龄: 28
声望: 10 波波 向着好的方向发展
作者: ayuan
:12: :em48: :em48: :31: :em41: :fuck-8: :fuck-8: :02: :52: :38: :02: :gan: :60:
波波 当前离线
旧 2005-09-18, 21:26   只看该作者   #13
feng717 feng717 当前离线
级别:29 | 在线时长:959小时 | 升级还需:61小时级别:29 | 在线时长:959小时 | 升级还需:61小时级别:29 | 在线时长:959小时 | 升级还需:61小时级别:29 | 在线时长:959小时 | 升级还需:61小时级别:29 | 在线时长:959小时 | 升级还需:61小时
Uid: 789
注册日期: 2004-08-21, 15:33
4 个帖子获得 10 次感谢
现金: 111金币
资产: 111金币
声望: 10 feng717 向着好的方向发展
Uid: 789
4 个帖子获得 10 次感谢
现金: 111金币
资产: 111金币
是个很好的东西,可是谁把安装给删了,前一端有是个空夹呀.希望斑竹给放上去.谢谢!
feng717 当前离线
旧 2005-09-20, 09:37   只看该作者   #14
dtp1682000 的头像
dtp1682000 dtp1682000 当前离线
帅哥 级别:32 | 在线时长:1173小时 | 升级还需:48小时级别:32 | 在线时长:1173小时 | 升级还需:48小时
Uid: 64
注册日期: 2004-05-12, 12:00
来自: 武汉
现金: -19金币
资产: -19金币
声望: 10 dtp1682000 向着好的方向发展
dtp1682000 的头像
Uid: 64
来自: 武汉
现金: -19金币
资产: -19金币
我有这个东东的多
媒体教学,老大说一声,
需要的话就上传
dtp1682000 当前离线
旧 2005-09-20, 15:33   只看该作者   #15
obj20050920 obj20050920 当前离线
级别:4 | 在线时长:35小时 | 升级还需:10小时
Uid: 5695
注册日期: 2005-09-20, 15:23
声望: 10 obj20050920 向着好的方向发展
Uid: 5695
牛 ONYX GRAPHICS RIP 6.5发行
ONYX RIP厂家美国犹它.此RIP目前共有11国家语言支持.当然包括简体及繁体.标准版:ProductionHouse(四机)PosterShop(二机)RipCenter中国专用版(单机).有关于ONYX RIP有任何问题可回复我.
obj20050920 当前离线
相似的主题
主题 主题作者 论坛 回复 最后发表
【发布】03.30.05 Onyx Postershop 6.0 rip wangyu1314 ◆- 数码喷墨UV印刷 0 2005-03-31 17:15
所有时间均为 +8, 现在的时间是 2025-12-02 19:02.
