| 论坛帮助 |
| 日历事件 |
只看该作者 #248 | ||
BSD on: CH6.6A Description An error was detected in the harness between the ROS and the Half Tone PWB. Procedure Pull out and insert the harness between the ROS and Half Tone PWB. Check that the harness is connected correctly using the check procedures described in the Installation Procedures of REP 4.1.1. Replace the following parts: Flat Cable (PL 4.1) ROS Assembly (PL 4.1) Half Tone PWB (PL 9.2) |
只看该作者 #250 | |||
顽石之中良玉隐焉
生产不干胶贴纸,双面胶EVA,珍珠棉,海棉等电子绝缘材料等业务!树下春包装材料:https://shuxc1688.taobao.com/ |
