2019-04-03, 15:52 | 只看该作者 #18 | ||
是否有v4.x最终版的MacOS版?是否有PackZ v5.04 or v5.05 MacOS版的安装? PackZ采用最高技术的wibu授权系统,几个程式库都经过编码Encoding然後在内存下Decoding变成一个程式库,所以只能够决战内存.....在Windows 10上倒是不难对於决战内存的议题....是否有大师傅能够说一下,packz v4有哪些选项是另外购买,基本款式哪些选项,谢谢..... |
2019-04-03, 17:27 | 只看该作者 #19 | ||
latest versions (both mac and windows) are v4.2.8 and v5.0.5 for now. these are the available options for version 3: Options.jpg |
2019-04-05, 13:50 | 只看该作者 #22 | ||
you cant compare stepz and plato. they are targeted for different situations. as stepz is a stripped down version of packz it has built in VDP functionality and native PDF editing. but it is only meant for digital printing. so there might be a paper size restriction. first releases will only be available to HP Indigo users. it will not be released for the whole printing market! Screen.png if you want to know more about S&R or VDP functionality from stepz you might take a look here: PACKZ_DS_STEP-REPEAT_2016_RZ1_SFS1_screen.pdf hybrid_software_vdp_release_final_en.pdf |
2019-04-06, 23:38 | 只看该作者 #24 | ||
license option „client“ is only used for a floating network license. for a local workstation license this option is not mandatory. license option „internal“ is only used for debugging purposes. it enables the debug menu which adds some special functions for developers. so this option isnt available for normal customers. |
2019-04-06, 23:57 | 只看该作者 #25 | ||
2019-04-07, 00:06 | 只看该作者 #26 | ||
右列会员因为此帖价值甚高向 重庆&老鬼 表示感谢: |
donna13579 (2019-12-12)
2019-04-07, 14:21 | 只看该作者 #28 | ||
if you click on "check now" the application sends your product key to the packz server. the server checks if there is a new version for your key available. if the key is allowed to get a new version you can download directly. |
