2008-12-03, 22:57 | 只看该作者 #16 | ||
VIP会员
http://download.adobe.com/pub/adobe/...dobeCMMAll.zip Adobe Color Management Module (CMM) The Adobe® Color Management Module (CMM) provides methods to transform colors using industry-standard International Color Consortium (ICC) color profiles. It is intended for users who wish to achieve consistent color workflows using a common CMM. The CMM is included in Adobe applications that use the Adobe Color Engine, a full Color Management System. However, the CMM component of the Adobe Color Engine has previously been unavailable to users in parts of their workflows that do not include Adobe applications. The CMM can be used by applications that support the selection of third-party CMMs. It can also be integrated with workflows using custom software to access the CMM APIs. See the ReadMe document contained in the CMM download for details. For information about bundling the Adobe CMM with non-Adobe products, contact Adobe at adobecmm@adobe.com. |
2008-12-14, 21:58 | 只看该作者 #22 | ||
而先在PS转换后的再进入EFI的转换过程就是sRGB Color Space Profile.icm—JapanColor2001Coated.icc—JapanColor2001Coated.icc—打印介质颜色空间,在PS转换后已是CMYK文件,就不需要再用前面的sRGB Color Space Profile.icm—JapanColor2001Coated.icc,而是JapanColor2001Coated.icc—JapanColor2001Coated.icc—打印介质颜色空间 还有对黑点补偿解释的也有问题,黑点补偿最初由ADOBE推出,现在都在学它了,主要是保证源空间的黑色转换到目标色空间中仍然是黑色,其实还是挺有用的。 |
2008-12-15, 12:40 | 只看该作者 #25 | ||
VIP会员
第一点是我说的不太清楚,其实说的是包括在ps中转换过程了,也就是rgb物件从原始状态到最终输出这个过程,然后把不同路途的整个过程进行比较,文字写的有问题,容易引起歧义。 第二点说的是efi的黑点补偿的问题,我不知道efi是否学的adobe,只是看的efi自己手册里的解释,另外不选也是为了减少干扰,有时间要对于这点实际测试一下。 |
发表新主题 关闭主题 |
相似的主题 | ||||
主题 | 论坛 | |||
efi技术讨论之“实现拼版时图像水平居中” | ◆- 数码打样与色彩管理 | |||
CD、PS讨论区! | ◆- Adobe 设计软件应用 | |||
EFI做出来没有PS打的好? | ◆- 数码打样与色彩管理 | |||
【讨论】EFI BestColor Premium | ◆- 数码打样与色彩管理 |
