2020-03-20, 16:01 | 只看该作者 #287 | ||
same to me. there are so many bugs and glitches in packz. its a real nightmare to use their buggy software in a real production environment. false overprinting is a problem in ghent pdf output suite 5.0 too. but hybrid doesnt care at all! if you take a closer look at their change logs you will find out there are LOTS of serious bugs which may screw up your files. a new software release every month is the proof that there are many things to fix. artpro+ is much more reliable and has a much better and more intuitive user interface. |
回复时引用此帖 |
2020-03-20, 18:06 | 只看该作者 #289 | ||
hybrid software does not care what is said. The support department is very bad, they answer the questions after 3-5 days. When you ask 3-4 questions, they do not follow. I have to constantly remind. Works with both companies. Esko is ahead in support. |
回复时引用此帖 |
2020-03-20, 20:09 | 只看该作者 #292 | ||
As I said before, they don't care much. Changelog PACKZ 5.2.4 #33623 Station Number with fixed paint in Overprint turns into Registration when used in repetition #33645 Rotation value not correctly reflected in Variables #33688 Opening and submitting files to Cloudflow does not work |
回复时引用此帖 |
2020-03-20, 23:21 | 只看该作者 #295 | ||
its a big waste of time to argue with idiots: he didnt understand your concerns at all and is forcing overprint AFTER importing the file. i can confirm your overprinting problems. i have tested with version 5.2.4. as you have already said, hybrid support is a big piece of shit. avoid using their rubbish software if you dont want to get into serious troubles! |
回复时引用此帖 |
2020-03-23, 09:28 | 只看该作者 #296 | ||
回复时引用此帖 |
右列会员因为此帖价值甚高向 重庆&老鬼 表示感谢: |
jacky_0527 (2020-03-23)
2020-03-23, 15:29 | 只看该作者 #297 | ||
现在终於可以有玩具可以玩...ArtPro+ 20 beta要等下个月中了... Drupa2020延期,esko开发员可能没那麽来劲了....这牙膏可能挤一年? PACKZ 6.0可能无缘使用?要靠老法接济了....持续关注吧..... |
回复时引用此帖 |
2020-03-23, 20:08 | 只看该作者 #298 | ||
回复时引用此帖 |
2020-03-24, 02:12 | 只看该作者 #299 | ||
https://www.cnprint.org/bbs/attachme...1&d=1584986953 |
回复时引用此帖 |
右列 5 位会员因为此帖价值甚高向 missortr 表示感谢: |
master death (2020-03-24),
Siem (2020-04-15),
terasonic (2022-10-24),
tzm1018 (2020-03-24),
重庆&老鬼 (2020-03-24)
