2020-04-01, 10:07 | 只看该作者 #319 | ||
回复时引用此帖 |
2020-04-02, 17:18 | 只看该作者 #320 | ||
STEPZ is a powerful tool which can augment high volumes of jobs, optionally with variable designs, text, numbers, and barcodes, translating data from data systems directly to a step & repeat layout. The new capabilities in version 5.2, based on feedback from a number of customers, have been praised for their ease of use, richness of features, and the efficiency and speed of file output. In fact, the first version was targeted at HP Indigo users migrating to the new Production Pro DFE, with step & repeat templates matching the form factor of HP Indigo label & packaging presses. Processing moves from desktop to server Rather than at the press, VDP file development with STEPZ has always resided at prepress, where it belongs. To offer even more computing power, STEPZ 5.2 can process all VDP file variants from the desktop to a server level, if desired. The link to STEPZ is still accessible in CLOUDFLOW, making possible the most powerful VDP execution of output files yet. Users can build complete VDP files approximately eight times faster, compared to leaving the work at the desktop workstation. STEPZ 5.2: Now available as a stand-alone solution For those who prefer to operate STEPZ for its VDP capabilities alone, HYBRID Software is offering a standalone solution, providing customers the opportunity to handle high volume VDP jobs with a single, easy to use application. With its modern server architecture, STEPZ 5.2 optionally allows users to scale their processes if needed, and output any challenging amount of data with ease. A number of new step & repeat features STEPZ 5.2 also includes a number of new step & repeat production enhancements. There are upgrades for roll-to-roll applications as well as for sheetfed solutions. For example, users can now define the bleed distance of common flaps on cardboard folding boxes. “PACKZ is our flagship product for sophisticated prepress work” explains Guido Van der Schueren, Chairman of HYBRID Software, “Based on this powerful technology, STEPZ now offers just the required tool set for digital printing preparation for a short learning curve and a quick introduction.” |
回复时引用此帖 |
2020-04-11, 08:25 | 只看该作者 #323 | ||
SCREEN数码标签机,现在放宽了,土豪钱多的话也可以买一套回家玩,所以国内企业有几家公司准备透过上海的贸易商引进该软件投入生产,我想很快就有安装可以play. Hybrid Software(比利时根特)宣布发布STEPZ 5.2,这是其功能强大的原生PDF落版解决方案的最新版本,用於数字标签和包装印刷。凭藉其强大的可变数据打印(VDP)功能,STEPZ 5.2是软件开发商PACKZ系列的模块化版本,可让用户在必要时利用软件的复杂性。该公司表示,STEPZ 5.2的简化版本可加快学习速度,但入门价格却更具吸引力。 STEPZ是一个功能强大的工具,可以增加大量工作(可选地带有可变设计,文本,数字和条形码),将数据从数据系统直接转换为步进和重复布局。基於客户反馈的5.2版中的新功能因其易於使用,功能丰富以及文件输出的效率和速度而受到赞誉。 该解决方案使HP Indigo用户可以为其HP Indigo标签印刷机和包装印刷机创建步骤和重复模板。 Hybrid STEPZ可与HP PrintOS Production Pro一起高效,快速地工作,用於标签和包装数字前端(DFE)。 DFE基於Global Graphics的Harlequin RIP,Fundamentals(将Hybrid Cloudflow技术用於数字标签和包装工作流程)和Hybrid Software的Label Layout Station进行拼版。 HP Indigo用户可以通过HP PrintOS Marketplace订阅或购买STEPZ,非常适合超短期打印和可变数据打印。 处理从台式机转移到服务器。使用STEPZ进行VDP文件开发始终驻留在其所属的印前系统中,而不是在印刷中。为了提供更大的计算能力,STEPZ 5.2可以根据需要处理从桌面到服务器级别的所有VDP文件变体。仍然可以在Cloudflow中访问到STEPZ的链接,这使得“迄今为止最强大的输出文件VDP执行”成为可能。与将工作留在桌面工作站上相比,用户可以以大约八倍的速度构建完整的VDP文件。” STEPZ 5现在可以作为独立解决方案使用。对於那些喜欢单独使用STEPZ来实现其VDP功能的用户,混合软件(Hybrid Software)提供了一个独立的解决方案,为客户提供了使用单个易於使用的应用程序处理大量VDP作业的机会。凭藉其现代化的服务器体系结构,STEPZ 5.2可选地允许用户根据需要扩展其过程,并轻松输出任何具有挑战性的数据量。 许多新的步骤和重复功能。 STEPZ 5.2还包括许多新的步骤和重复生产增强功能。卷对卷应用程序以及单张纸解决方案都有升级。例如,用户现在可以定义纸板折叠盒上常见摺页的排出距离。混合软件主席Guido Van der Schueren说:“ PACKZ是我们用於复杂印前工作的旗舰产品,基於这种强大的技术,STEPZ现在仅提供数字印刷准备所需的工具集,以缩短学习时间并快速介绍。 。” Hybrid Software是一家软件开发公司,在美国,比利时,德国和意大利设有办事处,并拥有全球合作夥伴网络,致力於为印刷和图形艺术行业提供创新的提高生产力的工具。其Cloudflow工作流程,PACKZ编辑器和集成产品提供了一系列独特的优势,包括本地PDF工作流程,基於行业标准的独立於供应商的解决方案,可扩展的技术和较低的拥有成本。这些产品已在全球范围内的印前和印刷各个领域中使用,包括标签和包装,折叠纸盒,瓦楞纸,大幅面和数字印刷。 为了STEPZ 5.2的独特功能(PACKZ 5.2没有的),我想收集一套STEPZ 5.2的安装很划算也很直得,你说是吧? |
回复时引用此帖 |
2020-04-11, 19:36 | 只看该作者 #324 | ||
回复时引用此帖 |
2020-04-14, 10:35 | 只看该作者 #327 | ||
"PACKZ-" 改成 "STEPZ-" 兴许STEPZ就可以经过patcher後使用,提供一个思路 |
回复时引用此帖 |
2020-04-14, 21:09 | 只看该作者 #328 | ||
回复时引用此帖 |
2020-04-15, 07:06 | 只看该作者 #330 | ||
missortr,inter1000等几位大师中的大师,可以将PACKZ 5.2.2 pc or mac 捅一份和谐来看看吗? 最近的ArtPro+ 20.0.0.207是否可以靠inter1000的Lic+一字节esko万用和谐法给捅破吗?软件正在从mega下载中.....待续..... |
回复时引用此帖 |
