2020-05-21, 22:59 | 只看该作者 #421 | ||
会不会是PACKZ软件烂到爆?所以不值得花时间去和谐?或许是选项之一吧? 如果PACKZ出了6.0 Chinese Version,只能中文,无法切换成其它语言版的和谐,会如何?提升软件的学习率?普及率?这仅仅是思想上的论述... |
回复时引用此帖 |
2020-05-22, 14:23 | 只看该作者 #422 | ||
1- All year round updates are free. 2- They have to give support for everything you want to do in the program but cannot do. If necessary, they have to explain by video. Sample; You have purchased the program and have not made any maintenance agreements. It has been 3 years since your program is no longer up to date. If you want to update the program after 3 years, the price you will pay is about 15,000 € But if you made a 3-year maintenance agreement, the price you would pay is about 3,500 € You have the right to ask every question you want in the maintenance agreement. In summary; It is advantageous for the user to make maintenance agreements. |
回复时引用此帖 |
2020-05-22, 15:48 | 只看该作者 #423 | ||
你说PACKZ软件很差劲吗?好像也卖了2500套上的销售,真的锕麽烂吗?也不见得?软件也po上printroot去求破解,也上ruboard求破解,所以PACKZ这软件应该说是没有那麽优秀但是堪用,说烂倒是不至於,还有一堆人享用,论坛也是一堆安装求破解求和谐,所以PACKZ应该是鸡肋软件是吧? PACKZ 6.0会不会继续是鸡肋? 五月份,PACKZ公司罕见地发表两支影片关於热缩套膜的, 如下: https://www.youtube.com/watch?v=42ntt8DqmNY https://www.youtube.com/watch?v=5UGJ2LwDepA 此帖于 2020-05-22 16:28 被 重庆&老鬼 编辑. |
回复时引用此帖 |
2020-05-22, 17:25 | 只看该作者 #424 | |||
回复时引用此帖 |
2020-05-22, 18:38 | 只看该作者 #425 | ||
The interface is bad. Too much bug is bad. customer support is bad. |
回复时引用此帖 |
右列会员因为此帖价值甚高向 RealX11 表示感谢: |
cabron (2020-05-23)
2020-05-23, 10:36 | 只看该作者 #427 | ||
Esko用artpro+的clean UI来打击PACKZ杂乱无章的UI介面,似乎恰如其分? 不过PACKZ很适合Apple的6K colorDisplay,这样UI介面比较够放? 不过目前我只买得起Asus 4K ColorDisplay,玩起来也不错.... 是可以开始做一份报告,从Artpro到PACKZ与ArtPRO+ |
回复时引用此帖 |
2020-05-23, 21:44 | 只看该作者 #428 | ||
PACKZ(STEPZ)+CloudFlow+Harlequin direct Rip整合方式配合HP Indigo做低价的销售,当然比起Esko的AE流程便宜许多....不过如果又便宜效能又快,站在消费者的立场,何乐而不为? |
回复时引用此帖 |
2020-05-24, 10:07 | 只看该作者 #429 | ||
我想如果软件的加密技术没有改变,那麽PACKZ 6.0 Chinese Version应该是同步更新,晚几分钟尔以;所以全仰赖有PACKZ 6.0 beta的印前先进提供,PACKZ 6.0 beta测试版,方便进入代码分析阶段,安装过的PACKZ 6.0 beta也是可以的, Windows and macos都可以,因为正式版还需要一个月.... PACKZ 6.0 Chinese Version即将释出,如PACKZ公司所愿... RuBoard暗黑底层研究室即将发表PACKZ 6.0 beta patcher ? |
回复时引用此帖 |
2020-05-25, 22:02 | 只看该作者 #431 | ||
Studio 20可以直接开启Artioscad的canvas文件 Artpro+20 聚焦在热缩套膜的预失真,以及Plate Cut,Equinox Tool 你看PACKZ也是聚焦在热缩套膜的预失真,可能是买家在意这个问题,所以都聚焦在这个功能上,因为无法拿到PACKZ 6.0 beta所以无法比较 但是Esko却出了最新版的ArtPro 20.0.0build 250测试版,供大客户进行功能测试,有幸得以测试,很是欢喜.... |
回复时引用此帖 |
2020-05-26, 08:03 | 只看该作者 #432 | ||
http://cdn.mysoftware.esko.com/downl...20.0.0.250.dmg http://cdn.mysoftware.esko.com/downl...20.0.0.250.zip |
回复时引用此帖 |
右列 4 位会员因为此帖价值甚高向 roychen 表示感谢: |
