2023-11-25, 12:38 | 只看该作者 #49 | ||
原始发布带了安装说明: Install the plugin. Patch the plugin with the patcher. Start Illustrator. If a window appears: An Internet connection is required to activate Hot Door CADtools... Close Illustrator. Check your Internet connection. If Internet access is blocked in Firewall, allow. If you've clicked 'Add to hosts' before, click 'Remove from hosts' in the patcher. Internet access is needed once to install the trial key. When the window appears: The trial period for Hot Door CADtools has ended... Close Illustrator. Click 'Add to hosts' in the patcher. *** Now you have an endless trial *** ----------------------------------------------------------------------- 翻译过来就是: 安装插件 打开Patch.exe,点Patch按钮用补丁程序修补插件 启动Illustrator 如果出现一个窗口:需要Internet连接才能激活Hot Door CADtools... 关闭Illustrator 请检查您的Internet连接 如果防火墙中阻止了Internet访问,请允许 如果您以前单击过【Add to hosts】,请单击补丁程序中的【Remove from hosts】 安装试用密钥需要访问一次Internet 当窗口出现时:Hot Door CADtools的试用期已经结束... 关闭Illustrator。 单击补丁程序中的【Add to hosts】 ***现在你有一个无期限的试用*** 不成功的朋友请按照此顺序重试... |
