2021-06-29, 14:13 | #77 | ||
When a 3rd party PIM/DAM solution called Censhare is used to manage art files and images, a JPG or PNG image file is placed into an Adobe Illustrator file (even a new blank file) and the image is stored in Censhare. When you try to save the file (to the desktop or anywhere), Adobe Illustrator locks up and must be force quit. When saving a file with a JPG or PNG file placed from a Censhare depot, Adobe Illustrator locks up and must be force quit. If the image file is a TIFF or PSD Adobe Illustrator does not lock up. HOTFIX 202103022 for ArtPro+ On Big Sur (macOS 11), with language set to Japanese, launch ArtPro or ArtPro+ 21.03 and try to open a document. The application will quit. No such issue occurs when the language is set to any of the other supported languages. No issue on macOS 11.0.x, but it does occur on the later updates of macOS 11 (currently, the latest released version is macOS 11.4). |
回复时引用此帖 |
右列会员因为此帖价值甚高向 RealX11 表示感谢: |
重庆&老鬼 (2021-06-29)
2021-07-09, 20:14 | #78 | ||
Apple M1: The biggest change is hidden deep inside PACKZ 7. The application natively runs on Apple M1 and the newest Mac computers. Environments bring an extra level of comfort to the already personalized multi-screen user interface and workspaces. The entire behaviour of PACKZ 7 can be set with a single click and aligned with the brand you are producing for, such as screen sets, barcode presets, preflight checks, color profiles and books, mark libraries, and much more. Snapping: Snap sets make transformations and artwork element alignment easier than ever before. MARS: Starting with PACKZ 7, the user community can search and discover solutions in MARS. The in-app platform contains predefined dynamic marks, digital proof templates, preflight reports and more much… Solutions can be downloaded and are immediately available for use. Patchworker Variable Data: Nothing impacts business growth more than a direct customer connection according to brands. HYBRID Software expands the Variable Data Printing wizard with Patchworker, an innovative and unique approach that shifts and changes design features in the same variable data production run regardless of the digital printing press. Press owners can produce an unlimited variation of personalized labels or seasonal packaging, and increase their addressable market size. Pactions workstation automation: Pactions has been enhanced with even more parameterizable actions. The new actions will contribute to an even more improved productivity and profitability. Packzimizer has become more powerful. The technology gangs multiple jobs on quantity respecting layout templates or diecut libraries. Packzimizer outputs print-ready impositions for digital presses with a maximum substrate usage and press uptime. ColorLogic: PACKZ 7’s fully ICC compliant color management is now powered by ColorLogic. The combination of ColorLogic’s unparalleled range of spectral color technology combined with HYBRID Software’s high level of automation and integration possibilities, brings supreme color matching for any printing technology in PACKZ and the workflows. Barcodes: The barcode recognition can now detect barcodes under any angle, while the GS1 QR, Japanese Mail Code and GS1 Digital Link is added to the already wide range of codes that can be generated. Analyze and Fix can now exclude soft masks when performing a preflight and even check objects that are too close to the trim path. |
回复时引用此帖 |
2022-01-14, 18:00 | #83 | ||
回复时引用此帖 |
2022-05-18, 14:59 | #86 | ||
When I try to open the program, it gives the error in the attached picture 1. When I try to open the program from the terminal, it gives the error in picture 2. how can i fix this? My System is 10.15.7 Catalina |
回复时引用此帖 |
2022-05-20, 14:30 | #87 | ||
回复时引用此帖 |
