旧 2009-12-05, 17:49     #1
jsntpx jsntpx 当前离线
Uid: 5146
注册日期: 2005-09-04, 20:58
年龄: 56
1 个帖子获得 2 次感谢
现金: 8金币
资产: 8金币
声望: 10 jsntpx 向着好的方向发展
jsntpx jsntpx 当前离线
Uid: 5146
年龄: 56
1 个帖子获得 2 次感谢
现金: 8金币
资产: 8金币
默认 Trendsetter 3244 Error Messages
Trendsetter 3244
Error Messages
See also Search Form
This content is generated by scripts that pull information directly from Firmware Engineering's support site. The scripts were last run: 31 Jan 2005 05:00:02
Number Error Message
00000 MISC:
00001 MISC: Reserved
00002 MISC: Reserved
00003 MISC: Reserved
00004 MISC: Reserved
00005 MISC: Reserved
00006 MISC: Reserved
00007 MISC: Reserved
00020 MISC: Specified test is not defined
00021 MISC: Workstation communications lost
00030 MISC: Requested command is not defined
00100 MISC: MPE Code checksum is faulty
00101 MISC: LCA module checksum is faulty
00102 MISC: LCA module incompatable format
00103 MISC: Module not found in version list
00104 MISC: Firmware module checksum is faulty
00105 MISC: Error opening firmware module
00106 MISC: Invalid or unneeded code bundled with firmware
00107 MISC: Missing required code in the firmware bundle
00108 MISC: Product version not found in version list
00109 MISC: Invalid version of overwriting pattern
00200 MISC: Code bank selected for loadingis current code bank
00201 MISC: Flash memory program failed
00202 MISC: Address <hex address> out of memory bank range
00203 MISC: Unsupported memory type detected
00204 MISC: Flash memory erase failed
00500 MISC: Temperature log: Engine = <Celcius x 10> Leadscrew = <Celcius x 10>
00501 MISC: Password not set!
00502 MISC: NVS modified and saved, but not backed up!
00511 MISC: Dongle not responding
00512 MISC: Config: %s %s owner %s
01000 RESET: cause unknown
01001 RESET: induced by test submodule
01002 RESET: induced by RESET opcode, possible warm reset requested at monitor
01004 RESET: induced by loss of clock
01016 RESET: induced by halt monitor
01032 RESET: induced by software watchdog, possible cold reset requested at monitor
02000 NVS: checksum error in <NVS subsystem> calibration block
02040 NVS: checksum error in <NVS subsystem> configuration block
02080 NVS: checksum error in mode <number> table
02200 NVS: low battery in NVS detected
02201 NVS: NVS automatically upgraded to version 2
02202 NVS: subscan size nvs config parameter is invalid
03000 WSCOMM: All faults cleared
03001 WSCOMM: Invalid command letter
03002 WSCOMM: Parameter syntax error
03003 WSCOMM: Defined WS command is currently unsupported
03004 WSCOMM: Character pacing timeout, WS transmitting too slowly
03005 WSCOMM: too many characters in command string
03006 WSCOMM: Could not open serial communications interface for workstation
03007 WSCOMM: Resume or clear received when not suspended
03008 WSCOMM: Command received for idle image ID
03009 WSCOMM: Specified image ID is already active
03010 WSCOMM: Maximum active image commands surpassed
03011 WSCOMM: Resolution specified is not available
03012 WSCOMM: Already aborting
03014 WSCOMM: Abort received when no command active
03015 WSCOMM: Already imaging
03016 WSCOMM: Recorder is flushing, can't accept new commands
03017 WSCOMM: Door is open
03018 WSCOMM: Door is closed
03019 WSCOMM: ABORT switch on
03020 WSCOMM: ABORT switch off
03021 WSCOMM: Operation aborted at recorder - check that abort switch is released
03022 WSCOMM: Operation aborted by workstation
03023 WSCOMM: ABORT complete
03024 WSCOMM: Abort request not heeded within timeout, possible hung subsystem
03025 WSCOMM: Task(s) <task codes> did not finish initializing on time
03026 WSCOMM: Operation preempted
03027 WSCOMM: Cassette bay door open
03028 WSCOMM: Cassette bay door closed
03047 WSCOMM: Resolution does not exist
03048 WSCOMM: Image too wide for plate
03055 WSCOMM: Workstation software error - Invalid packet number
03056 WSCOMM: Workstation software error - Invalid total packets number
03057 WSCOMM: Workstation software error - Out of sequence packet received
03058 WSCOMM: Workstation software error - Invalid packet length
03059 WSCOMM: Workstation software error - Invalid Media Imaging Mode ID (MIMID)
03060 WSCOMM: Packet fails CRC check
03061 WSCOMM: Total packet data exceeding firmware buffer capacity
04001 MSG: Command parameter error
04002 MSG: Parameter is out of range
04003 MSG: Defined command is currently unsupported
04004 MSG: Requested test pattern not defined
04005 MSG: <subsystem> is already reserved
04006 MSG: Reserved message in message pool
04007 MSG: Task releasing message owned by another task
04008 MSG: Task releasing unreserved message
04009 MSG: Task sending message owned by another task
04010 MSG: Task sending unreserved message
04011 MSG: Task received message that was not sent
04012 MSG: Reserved string in string pool
04013 MSG: Task releasing unreserved string
04014 MSG: Task releasing string owned by another task
04015 MSG: Task reserving released string
04016 MSG: <task name> timed out while waiting for command <hex command code>
04017 MSG: <task name> received an invalid command (command = <hex command code>)
04018 MSG: Wrong number of parameters
04019 MSG: Inactive list sent
04020 MSG: Unexpected list type sent
04021 MSG: Invalid list entry number sent - Possible version incompatabilities
04022 MSG: Plot mode not specified before plot parameters
04024 MSG: Task received msg with unexpected id (code = %X)
04028 MSG: suspended - waiting for Resume or Clear
04029 MSG: plate thickness too large
04030 MSG: one or both plate dimensions too large
04031 MSG: media type out of range
04032 MSG: one or both plate dimensions too small
04034 MSG: media %d not supported
06000 DRUM: Timeout on drum operation
06001 DRUM: Illegal command state machine state
06002 DRUM: Timeout waiting for drum move
06003 DRUM: Received invalid command
06004 DRUM: drum not initialized - can't execute that command
06005 DRUM: Unexpected status returned from function
06006 DRUM: Timeout during active braking
06007 DRUM: Timeout on velocity settling
06008 DRUM: Timeout on velocity acceleration
06009 DRUM: Sample interrupt failure
06011 DRUM: Servo amp fault
06012 DRUM: Cable from motherboard to drum servo amp not detected
06013 DRUM: Index not detected
06014 DRUM: Extra Tach A pulse detected
06015 DRUM: Missing Tach A pulse
06016 DRUM: Extra Tach B pulse detected
06017 DRUM: Missing Tach B pulse
06018 DRUM: Drive direction incorrect - check motor wiring
06019 DRUM: Tach encoder cable not detected
06020 DRUM: Aborted
06021 DRUM: Timeout on hold
06022 DRUM: Motor current exceeded limit
06023 DRUM: Velocity error - drum rotation blocked or PID gain settings wrong
06024 DRUM: Position error is greater than 1000 ticks
06025 DRUM: Hall velocity error - drum rotation blocked or PID gain settings wrong
06026 DRUM: Timeout waiting for TPU hall sensor PW measurement
06027 DRUM: Plate not loaded correctly on drum, obstruction detected below LEC actuator
06028 DRUM: ALE actuators on drum
06029 DRUM: Hall mode overspeed error - possible TPU failure
06030 DRUM: Drum hall velocity does not match encoder velocity to within tolerance.
06031 DRUM: Drum is spinning.
06033 DRUM: Index detected prematurely - clean encoder disc or re-align encoder
06034 DRUM: Drum won't settle with zero torque applied - requires drum cal
06036 DRUM: Drum Position error during Velocity mode, (check acceleration setting)
06037 DRUM: Drum velocity greater than xx rpm in Position mode, possible runaway
06038 DRUM: LCA tick counter annomaly, premature index or spurious counter reset
06039 DRUM: Drum Position error during Velocity mode, (extra index possible cause, check monitor values)
06040 DRUM: Encoder counted extra ticks
06041 DRUM: Index occurred at xx, more than 3 ticks before normal ticks per rotation
06042 DRUM: Hall velocity error - more than 20 percent during drum init.
07000 CARRIAGE: Limit switches reporting carriage is both HOME and AWAY
07001 CARRIAGE: stuck in HOME position
07002 CARRIAGE: stuck in AWAY position
07003 CARRIAGE: unexpectedly arrived at HOME position
07004 CARRIAGE: unexpectedly arrived at AWAY position - image size may have been too large
07005 CARRIAGE: operation timed out
07006 CARRIAGE: timed out while waiting for LCA position
07007 CARRIAGE: position register not accurate
07008 CARRIAGE: LCA's not configured at startup
07009 CARRIAGE: ALE not taken out of reset
07010 CARRIAGE: Unexpected error: 0x%x
07011 CARRIAGE: could not find edge of platecheck that plate size is entered correctly
07012 CARRIAGE: did not reach target speed
07013 CARRIAGE: step synth position register reserved
07015 CARRIAGE: Head Stage is at it's away position, unsafe to move carriage
07016 CARRIAGE: ALE board timed out during carriage position read
07017 CARRIAGE: Carriage state error. Current state: <description>, jog_count = <n> JOG = <number> PLOT = <number>
07018 CARRIAGE: Carriage illegal dest. Current %lu, Dest %lu Stop Dist %lu
07019 CARRIAGE: Specified Speed exceeds maximum of %lu
07020 CARRIAGE: Carriage control board error: cable not detected or undervoltage
07021 CARRIAGE: Carriage control board error: over current
07022 CARRIAGE: Carriage control board error: over temperature
08000 PROC: Processor not present or turned off
08001 PROC: Processor is not ready
08002 PROC: Processor fault requires immediate attn.
08003 PROC: Processor warning will need attention
08004 PROC: Processor type unknown
08005 PROC: Illegal processor number used
10012 HARDWARE: Carriage limit switch
10019 HARDWARE: ALE is not plugged in
10020 HARDWARE: DPE is not plugged in
10022 HARDWARE: MPE LCA's not configured at startup
10023 HARDWARE: DPE will not initialize, may be stuck in reset
10025 HARDWARE: DPE LCA's not configured at startup
10026 HARDWARE: Incorrect DPE version installed
10050 HARDWARE: RAM DAC Incrementing Address Test fail - Address = <fault address>, Write data = <hex data>, Readdata = <hex data>
10051 HARDWARE: DPE failure - dpath control write = <hex data>, read = <hex data>
10060 HARDWARE: External Debris Blower Filters Not Present
10061 HARDWARE: External Debris Blower Filters Full
10062 HARDWARE: External Debris Blower Filters Almost Full (Vacuum Level %d is below %d)
10063 HARDWARE: External Debris Blower System Blocked (Vacuum Level %d is above %d)
10064 HARDWARE: External Debris Blower Not Connected or Filters Full (Vacuum Level %d is below %d)
10065 HARDWARE: DBlower Filter Fault.
11000 CABLE: HA-BP cbl, Carriage Home/Away
11002 CABLE: EH-BP: Exposure Head - Backplane
11003 CABLE: TE-BP: Tach Encoder - Backplane
11004 CABLE: MD-BP: Drum Motor - Backplane
11005 CABLE: Chiller/Blower sensor cbl.
11504 CABLE: SPR-BP
11575 CABLE: Operator Interface not connected
11576 CABLE: Pushbutton not connected
11582 CABLE: CD-D-BP: Carriage Drive Digital
11583 CABLE: CD-A-BP: Carriage Drive Analog
11584 CABLE: CM-CDB: Carriage Drive to Motor
11593 CABLE: Sensors not connected (J7)
11594 CABLE: Air Valves not connected (J20)
11595 CABLE: LR plate sensor not connected (J3)
11596 CABLE: Fly-off cable not connected (J2)
11597 CABLE: Temp Sensors not connected (J13)
12000 POWER: ALE +12V
12001 POWER: ALE -12V
12002 POWER: Carriage power
12006 POWER: Carriage Amp Fault
12007 POWER: Exposure Head power
12008 POWER: Drum Amp Fault
12701 POWER: TEE +24V
13000 EHBOOT: internal message timeout
13001 EHBOOT: datalink terminated the program sequence prematurely
13002 EHBOOT: format error detected during data transfer
13003 EHBOOT: sumcheck error detected during data transfer
13004 EHBOOT: datalink programming sequence taking too long
13005 EHBOOT: LOADER echo mismatch during bootstrap sequence
13006 EHBOOT: LOADER not echoed during bootstrap sequence
13007 EHBOOT: no break detected after forcing head into bootstrap mode
13008 EHBOOT: cannot perform requested operation, no LOADER present
13009 EHBOOT: LOADER prompt for next primitive did not arrive
13010 EHBOOT: communications error
13011 EHBOOT: failed to program location <hex data> with data <hex data>
13012 EHBOOT: failed to erase device, stopped at location <hex data>
13013 EHBOOT: failed to respond to programming command
13014 EHBOOT: Timeout on byte <byte #> while waiting for exposure head to complete response string
13015 EHBOOT: ENQ expected and not received
13016 EHBOOT: ACK expected and not received
13017 EHBOOT: incorrect response length
13018 EHBOOT: incorrect version length
13019 EHBOOT: incorrect version response in byte <byte #>
13020 EHBOOT: incorrect response address
13021 EHBOOT: incorrect response data
14000 SAT: Satellite error cleared
14002 SAT: Unknown Satellite Output Register: <hex number>
14003 SAT: Satellite SW corrupted Buffer
14004 SAT: Buffer Restore error during Output Command
14050 SAT: QSPI error during configuration
14051 SAT: Timeout during SPI enable
14052 SAT: Timeout during QSPI disable
14053 SAT: Timeout during SPI execution
14054 SAT: SPI Mode Fault error
14055 SAT: QSPI Update Watchdog timeout
14056 SAT: <Satellite Board> Error: <Output Name>
14057 SAT: Error Detection Error: Address <address>, Bit = <bit number>
14100 SAT: Temperature Filter Error: Out of range
14101 SAT: LUE Analog testpoint exceeded allowed maximum
14102 SAT: LUE Analog testpoint exceeded allowed minimum
14103 SAT: Engine Frame temperature out of range
14104 SAT: Engine Leadscrew temperature out of range
14105 SAT: Spare sensor 0 temperature out of range
14106 SAT: Spare sensor 1 temperature out of range
14107 SAT: Timeout waiting for conveyor roller speed to update
14108 SAT: Timeout waiting for conveyor belt speed to update
14150 SAT: Cassette Bay <bay number> invalid, autoloader currently configured for <max> bays
14151 SAT: Cassette Bay <bay number> Error: <device>
14200 SAT: PPE Analog testpoint exceeded allowed maximum
14201 SAT: PPE Analog testpoint exceeded allowed minimum
14202 SAT: Software error: invalid lamp state %d in sat_set_lamp_state()
14203 SAT: Software error: invalid image task state %d in sat_update_lamps()
15059 ALE: Autoloader is not initialized, possibly due to an opened door
15062 ALE: plate loaded incorrectly, remove plate from drum
15068 ALE: move clamps to park position, then select RESUME
15071 ALE: remove plate from drum
15072 ALE: remove plate partially on drum
15073 ALE: trailing edge clamp status conflict, setting te state flag to<0|1>. ( "1" indicates "on drum", "0" indicates "on tec backbone" )
15074 ALE: trailing edge clamps failed to unlock
15075 ALE: trailing edge clamps failed to lock
15076 ALE: trailing edge clamps not on actuator
15077 ALE: trailing edge clamps already on actuator, possible sensor or software error.
15078 ALE: no plate on drum
15079 ALE: timeout moving leading edge cylinder
15080 ALE: timeout moving trailing edge cylinder
15082 ALE: timeout moving roller cylinder
15085 ALE: roller on drum
15086 ALE: leading-edge actuator on drum
15087 ALE: trailing-edge actuator on drum
15250 ALE: timeout waiting for load button to be pressed
15251 ALE: plate not detected on load ramp
15252 ALE: plate larger than expected
15253 ALE: plate smaller than expected
15254 ALE: remove plate detected on load ramp
15259 ALE: load ramp is tilted into drum no-fly zone
15281 ALE: Please load plate
15283 ALE: Please unload plate
16005 IMAGE: update received after load started
16006 IMAGE: task received incorrect ID
16007 IMAGE: Inactive image task received image update
16008 IMAGE: Total mainscan shift less than or equal to zero
16009 IMAGE: Total subscan shift less than zero
16010 IMAGE: Total mainscan shift too large
16011 IMAGE: PLL is not able to track drum motion
16012 IMAGE: PLL was not able to maintain drum motion tracking
16013 IMAGE: Specified \"around drum\" image size too large
16018 IMAGE: exposure too low
16021 IMAGE: mainscan length must be a multiple of 16
16022 IMAGE: command received when already suspended
16023 IMAGE: plate exposed by open door
16025 IMAGE: Stroke must be flat when calibrating scorr
16026 IMAGE: Scorr must be initialized in current mode before calibrating
16027 IMAGE: TPG not idle after imaging, DPE reset
16028 IMAGE: Series plot completed
16030 IMAGE: Series strip width is set to zero
16038 IMAGE: Total number of retraces: <retraces>
16050 IMAGE: DPE orthog slope less than 0, check plate rotation
16051 IMAGE: DPE orthog slope larger than max, check plate rotation
16054 IMAGE: Attempt to image B-side before A-side
16056 IMAGE: Plate imaging has begun
16068 IMAGE: Unable to initialize plot for mode set to 0 DPI
16073 IMAGE: Negative media (inverted data) requires FDPE
17000 HEAD: No mailbox defined for datalink task
17001 HEAD: Error while sending to datalink mailbox
17002 HEAD: Datalink synchronization lost
17003 HEAD: Datalink failed while retrying send
17004 HEAD: Datalink in programming mode, command not valid
17005 HEAD: Datalink already in programming mode
17006 HEAD: Datalink timed out waiting for break
17007 HEAD: fault code = <hex data>, status byte = <hex data>
17008 HEAD: command timed out
17009 HEAD: task received unexpected head message <mailbox>, message code <msgtype>h
17010 HEAD: command acknowledge fault = <hex number>
17013 HEAD: couldn't find plate edge due to dirty edge strip on drum
17014 HEAD: won't come online
17015 HEAD: did not signal end of initialization
17016 HEAD: is not responding
17021 HEAD: break detected, exposure head has reset
17046 HEAD: multiple edges detected - verify image position
17501 HEAD: temperature out of range
17502 HEAD: value out of range
17503 HEAD: missing laser on parameters
17504 HEAD: attempted write blocked
17505 HEAD: failure to write to memory
17506 HEAD: unsupported message
17507 HEAD: message length incorrect
17508 HEAD: invalid control message
17509 HEAD: operation was aborted
17532 HEAD: no more room in mailbox
17533 HEAD: ran out of buffers
17534 HEAD: all retries failed on chnl 0
17535 HEAD: all retries failed on chnl 1
17536 HEAD: sync lost on chnl 0
17537 HEAD: sync lost on chnl 1
17548 HEAD: CONFIG register incorrect
17549 HEAD: flash memory checksum error
17550 HEAD: LCA won't init for reprogram
17551 HEAD: LCA won't admit being loaded
17552 HEAD: SRAM memory check failure
17596 HEAD: software error
17597 HEAD: LCA config unavailable
17692 HEAD: Light level too low for Beam Pointing
17693 HEAD: Timeout waiting for LASER OK
17694 HEAD: Light valve high voltage fault
17695 HEAD: LV Positive 12V fault (bipolar)
18017 LASER: Cannot continue, laser is not ready
19000 PDB: Air Supply Below Threshold
21000 SCSI: SCSI bus reset while imaging
21001 SCSI: SCSI parity error while imaging, check plate for artifacts
21002 SCSI: SCSI driver error, invalid initiator
21003 SCSI: SCSI Driver Error, line <line number>
21004 SCSI: SCSI asynchronous transfer requested, line <line number>
21005 SCSI: timed out waiting for SCSI complete
30000 TPG: memory overflow
30001 TPG: too many scans
30002 TPG: write to closed scan
30003 TPG: write to unopened scan
30004 TPG: write to undefined scan
30005 TPG: close of closed scan
30006 TPG: close of unopen scan
30007 TPG: open of NULL scan
30008 TPG: Undefined pattern number, use "list pattern"
30009 TPG: Call with NULL pattern struct
30010 TPG: Pattern write call error
30011 TPG: Too many cells in pattern
30012 TPG: timed out waiting for stripe to complete
31002 LCA: DONE signal stuck low while programming
31003 LCA: READY signal stuck low while programming
31004 LCA: did not accept programming data
31006 LCA: INIT signal stuck low while programming
31007 LCA: INIT signal stuck high while programming
31008 LCA: Required LCA file is not in firmware
31009 LCA: Required LCA master file is not in firmware
31010 LCA: Length of LCA diff file does not match master
32200 SW: Ink Key buffers out of synch
32201 SW: Image shutdown error
32202 SW: NCO update timeout
32203 SW: Resolution mode not defined
32301 SW: Unknown ID code in firmware directory
32302 SW: undefined subsystem in NVS list
32401 SW: Could not open console interface for serial communications
32403 SW: Could not open head interface for serial communications
32404 SW: Could not open laser interface for serial communications
32450 SW: Out of memory
32480 SW: WS data list unexpectedly in use
32481 SW: WS command pattern incorrect
32490 SW: AL Sched: pick sync error
32491 SW: AL Sched: unload sync error
32492 SW: AL Sched: load sync error
32493 SW: AL Sched: process sync error
32500 SW: Unexpected SW failure - general exception
32600 SW: executive call failed
32601 SW: executive call tsk_create() failed
32602 SW: executive call tsk_delete() failed
32603 SW: executive call tsk_suspend() failed
32604 SW: executive call tsk_resume() failed
32605 SW: executive call tsk_set_priority() failed
32606 SW: executive call mbx_create() failed
32607 SW: executive call mbx_delete() failed
32608 SW: executive call mbx_send() failed
32609 SW: executive call mbx_receive() failed
32610 SW: executive call mbx_flush() failed
32611 SW: executive call buf_alloc() failed
32612 SW: executive call buf_free() failed
32613 SW: executive call tmr_create() failed
32614 SW: executive call tmr_delete() failed
32615 SW: executive call pip_create() failed
32616 SW: executive call pip_delete() failed
32617 SW: mbx_send failed, NULL mailbox
32618 SW: mbx_send failed, mailbox full
32700 SW: all tasks suspended
32701 SW: Unexpected message in mailbox <mailbox name>, message code <hex message code>
32702 SW: message buffer request failed
32703 SW: message buffer release failed
32704 SW: string buffer request failed
32705 SW: string buffer release failed
32706 SW: unexpected case - file:<filename> line:<line number>
32707 SW: image command received by active task
32708 SW: procedure call has invalid parameters
32709 SW: status mask has duplicate flags defined
32710 SW: Invalid status code for this command code: <hex command code>
32711 SW: Unexpected message type for this command. type: <hex message type>
32766 SW: Non-specific error
jsntpx 当前离线
旧 2009-12-05, 19:19   只看该作者   #2
Smhily 的头像
Smhily Smhily 当前离线
Uid: 108804
注册日期: 2009-08-19, 16:21
来自: 火星中转站
感谢: 523
239 个帖子获得 410 次感谢
现金: -5504金币
资产: -5489金币
声望: 14 Smhily 向着好的方向发展
Smhily Smhily 当前离线
Smhily 的头像
Uid: 108804
来自: 火星中转站
感谢: 523
239 个帖子获得 410 次感谢
现金: -5504金币
资产: -5489金币
可否有中文解说。或是上传。非常谢谢。英文的毕竟还是看不懂。。。。
Smhily 当前离线
旧 2009-12-06, 10:31   只看该作者   #3
zamdy 的头像
zamdy zamdy 当前离线
美女 级别:5 | 在线时长:57小时 | 升级还需:3小时级别:5 | 在线时长:57小时 | 升级还需:3小时
Uid: 129705
注册日期: 2009-11-25, 20:13
来自: Shanghai
15 个帖子获得 20 次感谢
声望: 10 zamdy 向着好的方向发展
zamdy zamdy 当前离线
zamdy 的头像
Uid: 129705
来自: Shanghai
15 个帖子获得 20 次感谢
怪不得啊怪不得,原来在这里,全胜1代?
zamdy 当前离线
旧 2009-12-07, 09:25   只看该作者   #4
xcj_xu 的头像
xcj_xu xcj_xu 当前离线
帅哥 级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时级别:135 | 在线时长:18786小时 | 升级还需:254小时
Uid: 28829
注册日期: 2006-11-14, 14:32
来自: 安徽省合肥市
感谢: 2213
1038 个帖子获得 2121 次感谢
现金: 41952金币
资产: 42039金币
声望: 28 xcj_xu 向着好的方向发展
xcj_xu xcj_xu 当前离线
xcj_xu 的头像
Uid: 28829
来自: 安徽省合肥市
感谢: 2213
1038 个帖子获得 2121 次感谢
现金: 41952金币
资产: 42039金币
好东西,不过是中文的就更好了。
xcj_xu 当前离线
旧 2009-12-20, 15:14   只看该作者   #5
tianyubox tianyubox 当前离线
级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时级别:47 | 在线时长:2429小时 | 升级还需:67小时
Uid: 30206
注册日期: 2006-12-04, 10:44
感谢: 27
24 个帖子获得 26 次感谢
声望: 10 tianyubox 向着好的方向发展
Uid: 30206
感谢: 27
24 个帖子获得 26 次感谢
很好的资料,英文水平有限要慢慢翻释
tianyubox 当前离线
请教CTP柯达3244的速度 glunz ◆- CTP综合讨论区 0 2009-11-26 08:58
求全胜 3244系列资料 jsntpx ◆- CTP综合讨论区 3 2009-11-03 12:59
Trendsetter 3244 aa81501478 ◆- 印刷设备、器材、耗材、软件、维修、培训等商业信息 2 2009-11-03 12:58
所有时间均为 +8, 现在的时间是 2025-12-05 06:00.
