旧 2010-05-20, 13:36     #1
gooniepool 的头像
gooniepool gooniepool 当前离线
帅哥 级别:25 | 在线时长:732小时 | 升级还需:48小时级别:25 | 在线时长:732小时 | 升级还需:48小时级别:25 | 在线时长:732小时 | 升级还需:48小时级别:25 | 在线时长:732小时 | 升级还需:48小时
Uid: 7114
注册日期: 2005-10-28, 23:26
8 个帖子获得 16 次感谢
声望: 10 gooniepool 向着好的方向发展
gooniepool 的头像
Uid: 7114
8 个帖子获得 16 次感谢
默认 Ipex 2010 news
Hot News page for Ipex Exabition
CTP for everyone: Lüscher delivers direct imaging for all printing methods
Gretzenbach, Switzerland, May 2010. – Lüscher, the Swiss CTP specialist, has expanded its portfolio. It now includes hybrid platesetters of a new and revolutionary design. The newly-developed XPose! Flex and Multi DX lines offer very attractive solutions for many printers, especially those who employ multiple printing methods.
The XPose! Flex lets a printer use a single CTP system for producing plates and screens for a variety of printing methods: flexography, letterpress, offset, and rotary screen printing. The versatility of the XPose! Flex is complemented by the unprecedented technology of the Multi DX.
Like the XPose! Flex product line, the Multi DX can image a variety of plates and screens through the use of a combination of different types of laser diodes. With its flat-bed construction, this exceptionally compact machine takes flexibility one step further: It can image anything from a postage stamp to a maximum size of 800 x 600 mm. In particular, the Multi DX can image plates based on rigid materials (steel or aluminum) up to 50mm thick. It is thus especially suited for use in combination with the imaging of both printing plates and screens for screen-printing - a level of flexibility that no CTP system has achieved until now.
Because of the unique design of these CTP systems, Lüscher calls them SWISS CTX, Computer-to-Xposure - where the “X” stands for any desired type of plate or substrate.
The new, compact CTX system
There are three types of devices within the Multi DX product line:
- Multi DXUV with blue UV laser diodes (405 nm)
- Multi DXIR with infrared thermal laser diodes (940 nm)
- Multi DXHybird with a combination of blue UV diodes and IR
thermal diodes
The Multi DXUV can image dry offset plates (as well as the time-tested conventional UV plates). It can also handle the Gallus Screeny material (for rotary screen printing) as well as flat screen-printing screens. The Multi DXUV is just as well suited for label printers and those who print objects (tubes, bottles, and CDs for example) as it is for technical screen-printing.
Because of its new technology, the Multi DXIR makes possible the production of digital letterpress plates, digital flexo plates, and digital varnish plates (all using ablation layers). Ablation films can also be imaged.
The Multi DXHybrid combines both types of lasers, which makes it a perfect choice for label printers, who generally use more than one printing method.
Because of its high-precision engineering and its standard resolution of 2400 dpi, the Multi DX can also be applied in many other industries that use photo-sensitive coatings (such as solar panel technology, flat-screen displays and the production of electronics).
All of this is accomplished by a single device. The diversity of imaging options provided by the new CTX system is truly unique.
The customer can choose among various configurations of the Multi DX models. They can be equipped with as few as 8 or as many as 64 laser diodes, depending on the application and the type of diode. The modularity of the units makes it easy to update and refit them. The machine can grow along with the user’s requirements, providing the customer with a lot of flexibility and security of investment.
Diverse application opportunities – exceptional cost-effectiveness
Plates can be imaged much faster digitally than with conventional processes. Because the Multi DX can be equipped with custom pin-register blocks, very accurate register can be achieved which significantly reduces both job-changeover times and start-up waste. Finally, the quality of the plate itself is significantly improved, resulting in better reproduction, increased color gamut and an overall improvement in print quality.
Of course, there is still the question of the cost-effectiveness of such an investment. For many specialized printers, an important factor is the fact that often only a limited volume of a given type of plate is produced. Many plants using multiple printing methods find they can’t manage the high capital cost of CTP, because the relatively small volume of plates makes it impossible to justify the investment.
This is particularly true if you need to buy a separate platesetter for each different printing method! At the same time, companies find themselves under increasing pressure to invest in digital technology, in order to make the production process more standardized and the company more competitive.
Lüscher’s Nelson Schneider says of the new Multi DX: “The return on investment calculations we have done so far have shown a pay-back period of well under two years, depending on the device configuration and the volume of plates. For a screen printer who produces 40 screens a day, the machine can even pay for itself in as little as 11 months.”
Companies that are interested in the new, flexible CTP and CTX systems from Lüscher can see them from May 18-25 at the Ipex printing trade fair in Birmingham (UK), Hall 9, Stand D359. Also shown at Ipex will be the company’s flagship CTP model, the Xpose! UV 260 offset platesetter with 64 laser diodes, along with its compact plate deloader. The XPose! UV product line is already among the best-selling CTP systems in the world, with more than 450 installations. In addition, Ipex will also be the premiere of the XPose! 4FLEX 230. Only a month after Ipex, the new Lüscher Multi DX will have its official world premiere at the FESPA trade fair in Munich (June 22-26).
In either case (May in Birmingham or June in Munich), there are many good reasons for printers to stop by and visit the Lüscher exhibit.
gooniepool 当前离线
旧 2010-05-20, 13:39   只看该作者   #2
gooniepool 的头像
Uid: 7114
8 个帖子获得 16 次感谢
gooniepool 的头像
Uid: 7114
8 个帖子获得 16 次感谢
默认 K-Zone
Kodak's K-Zone at Ipex 2010 Features Live Discussions with Industry Experts on Latest Market Trends and Opportunities
Panels include “Change Inspires Innovation” with Kodak Chairman and CEO Antonio M. Perez and “The Future of Print in the 21st Century” with Frank Romano
BIRMINGHAM, UK, May 12—Kodak’s K-Zone, which debuted at Print 09 with great success, will be a main highlight of Kodak’s stand 09-E320 at Ipex 2010. The K-Zone is a live talk-show set where dynamic unscripted discussions with industry experts, print service providers and marketing professionals take place daily throughout the Ipex show. The sessions will provide key insights and information that commercial printers, publishers, package printers, and data printers can use to help their businesses increase profitability and open doors to new opportunities.
“The K-Zone is redefining the tradeshow experience for our customers, creating a forum for people to address the impact of the many innovations affecting our industry,” said Chris Payne, Director and Vice President, Business to Business Marketing, Kodak. “Each panel session is designed to reflect current industry trends and focus on the success of real organizations and real people who use our technology to fuel creativity throughout their business.”
The K-Zone kicks off at 11 a.m. on Tuesday, May 18, with a keynote panel titled “Change Inspires Innovation,” featuring Antonio M. Perez, Kodak Chairman and CEO; Giovanni Antonuzzo, Rotomail CEO; Giorgio Albertini, Rotomail General Manager; and Tom Fenske, Fenske Media CEO. The panel will discuss the impact of digital marketing on the industry and how KODAK Stream Inkjet Technology is shaking things up with a wide variety of innovative applications.
Following the keynote panel on Tuesday, May 18, at 12 p.m. is “Once Upon a Time: The Story Behind the Invention of Stream.” Attendees will learn from Kodak Chief Technical Officer, Terry Taber, how the idea for Stream Inkjet Technology came about and the fundamental concepts behind this revolutionary printing system.
Special K-Zone sessions at 4 p.m. on Tuesday, May 18, and Thursday, May 20, will introduce Frank Romano’s new book, “The Future of Print in the 21st Century.” Print plays an important role in society and reflects the habits and needs of consumers, but new print technologies are transforming the way we interact with print. In this segment, Romano will talk about these changes and share insights from his new book. A book signing will follow and all attendees will receive a complimentary autographed copy.
In addition, a revealing panel discussion called “What We Think – The Analyst Viewpoint” will take place Wednesday, May 19, at 2 p.m. Well-known industry experts will talk about the worldwide economic situation and how the printing industry is evolving as a result.
On Thursday, May 20, at 5 p.m. the K-Zone will also feature the presentation of the Lifetime Print Ambassador Award to The Rt. Hon. the Lord Heseltine CH, Chairman, Haymarket Group Limited.
Other sessions will cover a wide range of topics including sustainability, workflow and social media. For more information and a complete schedule, please visit www.kodak.com/go/ipex. All K-Zone sessions will be recorded and can be viewed at www.kodak.com/go/ipex by clicking on the “Video Gallery” tab.
About Kodak
As the world’s foremost imaging innovator, Kodak helps consumers, businesses, and creative professionals unleash the power of pictures and printing to enrich their lives.
To learn more, visit http://www.kodak.com and follow our blogs and more at http://www.kodak.com/go/followus.
More than 75 million people worldwide manage, share and create photo gifts online at KODAK Gallery—join today at www.kodakgallery.com
In the graphic communications market, Kodak offers the broadest portfolio of integrated solutions to help customers grow their business. For more information, visit www.graphics.kodak.com. For downloading photos and videos from Kodak’s image library, visit www.kodak.com/go/gcimages.
(Kodak is a trademark of Eastman Kodak Company.)
gooniepool 当前离线
柯达在IPEX 2006展会上表现超出预期 rocks2000 ◆- 业界新闻与评论 0 2006-05-13 22:09
首台网屏报纸CTP系统将亮相Ipex 2006 cd2 ◆- CTP综合讨论区 0 2006-05-03 11:44
IPEX展会上的免处理CTP shmily0051 ◆- CTP综合讨论区 1 2006-04-13 14:15
爱克发于 IPEX 展示创新技术和产品 fullmace ◆- 业界新闻与评论 0 2006-03-22 08:26
爱克发将于 IPEX 展示新技术 jsntpx ◆- 业界新闻与评论 0 2006-03-07 20:53
所有时间均为 +8, 现在的时间是 2025-12-01 02:17.
