旧 2010-08-03, 17:02     #1
sbynimtd sbynimtd 当前离线
Uid: 144365
注册日期: 2010-02-02, 03:35
年龄: 40
声望: 10 sbynimtd 向着好的方向发展
Uid: 144365
年龄: 40
默认 海德堡四组520处都有同样的杠子
海德堡四组520处都有同样的杠子:
我们在印盒子时,第3组520处有一杠子。搞了很长时间没有好,我们只调色组,但是这一组在同一位也有,最后又调一组还有在同一位。没有办法!+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
sbynimtd 当前离线
旧 2010-08-03, 22:31   只看该作者   #2
HOMEZHENG HOMEZHENG 当前离线
帅哥 级别:2 | 在线时长:12小时 | 升级还需:9小时级别:2 | 在线时长:12小时 | 升级还需:9小时
Uid: 177009
注册日期: 2010-08-01, 23:05
年龄: 53
声望: 10 HOMEZHENG 向着好的方向发展
Uid: 177009
年龄: 53
没看明白,说说清楚,也好帮你。
HOMEZHENG 当前离线
旧 2010-08-06, 20:46   只看该作者   #3
exiled2304 exiled2304 当前离线
级别:4 | 在线时长:34小时 | 升级还需:11小时
Uid: 177164
注册日期: 2010-08-02, 18:33
现金: -1金币
资产: -1金币
声望: 10 exiled2304 向着好的方向发展
Uid: 177164
现金: -1金币
资产: -1金币
看不懂 看明白,说说清楚,也好帮你。
exiled2304 当前离线
旧 2010-08-06, 22:24   只看该作者   #4
yanquan76 yanquan76 当前离线
帅哥 级别:8 | 在线时长:115小时 | 升级还需:2小时级别:8 | 在线时长:115小时 | 升级还需:2小时
Uid: 177594
注册日期: 2010-08-05, 01:40
来自: 西安
感谢: 19
11 个帖子获得 12 次感谢
声望: 10 yanquan76 向着好的方向发展
Uid: 177594
来自: 西安
感谢: 19
11 个帖子获得 12 次感谢
1.检查胶辊2压力及轴承2.检查窜墨换向时间与改变窜墨量,看有无位置变化3.润版液指标、油墨指标4.检查压力5.检查齿轮及过桥齿轮6.检查滚筒轴承
yanquan76 当前离线
旧 2010-08-14, 16:31   只看该作者   #5
ggf987654 ggf987654 当前离线
Uid: 74000
注册日期: 2008-08-22, 22:29
感谢: 94
79 个帖子获得 107 次感谢
声望: 13 ggf987654 向着好的方向发展
Uid: 74000
感谢: 94
79 个帖子获得 107 次感谢
换一种规格的纸,看看是不是杠子随纸宽度在变,如是建议你查一下压力是不是太大,有冲击杠,还要看看传墨辊压力有没有偏大。
ggf987654 当前离线
旧 2010-08-21, 16:15   只看该作者   #6
OoGOoO OoGOoO 当前离线
帅哥 级别:20 | 在线时长:493小时 | 升级还需:32小时级别:20 | 在线时长:493小时 | 升级还需:32小时
Uid: 86995
注册日期: 2009-03-10, 15:38
感谢: 55
声望: 10 OoGOoO 向着好的方向发展
OoGOoO OoGOoO 当前离线
Uid: 86995
感谢: 55
作者: yanquan76 查看帖子
如果这样的检查都差不多了,我想是整是有跳动了,不然没理由每一座都都有都是同一个位的,这样我见意你查一下主动轴还有是主动马达呢〜!!
还有一个就是纸的问题都有,是不厚纸,纸纹是不是顺,不然可以反打,这样多在后面呢!!?墨大不大,湿不湿〜!!
OoGOoO 当前离线
所有时间均为 +8, 现在的时间是 2025-12-02 19:36.
