2005-09-22, 00:19 | #1 | |||
注意:修改后一定要反复测试,确保没错才可以投入使用,否则出问题了就别找我。 1、修改网线,分辩率与网角: 查找以下的内容: *% For 200 lpi ===================================================== *ColorSepScreenAngle ProcessBlack.200lpi.2400dpi/200 lpi / 2400 dpi: "45.0" *ColorSepScreenAngle CustomColor.200lpi.2400dpi/200 lpi / 2400 dpi: "45.0" *ColorSepScreenAngle ProcessCyan.200lpi.2400dpi/200 lpi / 2400 dpi: "15" *ColorSepScreenAngle ProcessMagenta.200lpi.2400dpi/200 lpi / 2400 dpi: "75" *ColorSepScreenAngle ProcessYellow.200lpi.2400dpi/200 lpi / 2400 dpi: "0.0" *ColorSepScreenFreq ProcessBlack.200lpi.2400dpi/200 lpi / 2400 dpi: "200" *ColorSepScreenFreq CustomColor.200lpi.2400dpi/200 lpi / 2400 dpi: "200" *ColorSepScreenFreq ProcessCyan.200lpi.2400dpi/200 lpi / 2400 dpi: "200" *ColorSepScreenFreq ProcessMagenta.200lpi.2400dpi/200 lpi / 2400 dpi: "200" *ColorSepScreenFreq ProcessYellow.200lpi.2400dpi/200 lpi / 2400 dpi: "200.00" *% For 175 lpi ===================================================== *ColorSepScreenAngle ProcessBlack.175lpi.2400dpi/175 lpi / 2400 dpi: "45.0" *ColorSepScreenAngle CustomColor.175lpi.2400dpi/175 lpi / 2400 dpi: "45.0" *ColorSepScreenAngle ProcessCyan.175lpi.2400dpi/175 lpi / 2400 dpi: "15" *ColorSepScreenAngle ProcessMagenta.175lpi.2400dpi/175 lpi / 2400 dpi: "75" *ColorSepScreenAngle ProcessYellow.175lpi.2400dpi/175 lpi / 2400 dpi: "0.0" *ColorSepScreenFreq ProcessBlack.175lpi.2400dpi/175 lpi / 2400 dpi: "175" *ColorSepScreenFreq CustomColor.175lpi.2400dpi/175 lpi / 2400 dpi: "175" *ColorSepScreenFreq ProcessCyan.175lpi.2400dpi/175 lpi / 2400 dpi: "175" *ColorSepScreenFreq ProcessMagenta.175lpi.2400dpi/175 lpi / 2400 dpi: "175" *ColorSepScreenFreq ProcessYellow.175lpi.2400dpi/175 lpi / 2400 dpi: "175.00" 大家可以看到 *% For 175 lpi 或者 *% For 200 lpi ,这是为175与200网的设定,内容已经很清楚了,可以自己新增一个段落: *% For 199 lpi ===================================================== *ColorSepScreenAngle ProcessBlack.199lpi.3000dpi/199 lpi / 3000 dpi: "5.0" *ColorSepScreenAngle CustomColor.199lpi.3000dpi/199 lpi / 3000 dpi: "10.0" *ColorSepScreenAngle ProcessCyan.199lpi.3000dpi/199 lpi / 3000 dpi: "15" *ColorSepScreenAngle ProcessMagenta.199lpi.3000dpi/199 lpi / 3000 dpi: "20" *ColorSepScreenAngle ProcessYellow.199lpi.3000dpi/199 lpi / 3000 dpi: "30.0" *ColorSepScreenFreq ProcessBlack.199lpi.3000dpi/199 lpi / 3000 dpi: "5" *ColorSepScreenFreq CustomColor.199lpi.3000dpi/199 lpi / 3000 dpi: "10" *ColorSepScreenFreq ProcessCyan.199lpi.3000dpi/199 lpi / 3000 dpi: "15" *ColorSepScreenFreq ProcessMagenta.199lpi.3000dpi/199 lpi / 3000 dpi: "20" *ColorSepScreenFreq ProcessYellow.199lpi.3000dpi/199 lpi / 3000 dpi: "30.00" 这样你将得到一个自定义的网线与网角段,分别为199lpi,3000dpi,CMYK与专色的网角分别为: 15 20 30 5 10。但修改时不要改错或改漏,否则出出来撞网可别找我。 改变PPD默认的最大输出尺寸: 查找以下内容 *%=== Custom Page Sizes ================================== . . . *ParamCustomPageSize Width: 1 points 1 14400 *ParamCustomPageSize Height: 2 points 1 14400 . . . *MaxMediaWidth: "14400" *?CurrentMediaWidth: "save statusdict /mediawidth get exec = flush restore" *MaxMediaHeight: "14400" *?CurrentMediaHeight: "save statusdict /medialength get exec = flush restore" Width 为宽度, Height 为高度,单位为points,此PPD的最大输出尺寸是 14400 point,可以修改该值,使其可以输出更大的尺寸。 删除多余的页面选项: 删除这些页面时比较麻烦,因为要删除多个段落,可以分别查找例如 A4 A5 等页成内容,例如: *DefaultPaperDimension: Letter *PaperDimension Letter: "612 792" *PaperDimension Legal: "612 1008" *PaperDimension Executive: "522 756" *PaperDimension ARCHE3/ARCH E3: "1944 2808" *PaperDimension A4: "595 842" *PaperDimension A3: "842 1191" *PaperDimension A2: "1191 1684" *PaperDimension A1: "1684 2384" *PaperDimension A0: "2384 3370" 将不需要的语句删掉后,再查找PPD中另外的地方是否有类似的内容,如果有就要删除相对应的内容。 最后就是将PPD文件保存,然后在输出软件中测试结果。看看是否出现对应的网线,网度是否正确,DPI是否正确等,如果正确后,恭喜了,你有了自己个性化的一个PPD了。 相信很多有经验的输出人员已经知道这个方法了,但是还是要献给一些为此而烦恼的同行们。 此帖于 2005-09-24 21:44 被 LWF 编辑. |
2005-09-24, 23:14 | 只看该作者 #10 | ||
*PaperDimension A3: "842 1191" *PaperDimension A2: "1191 1684" *PaperDimension A1: "1684 2384" *PaperDimension A0: "2384 3370" 页面尺寸是怎样的关系。如A4(595 842)的,A3是A4的2倍,那应该是A3(842 1190),怎么会这样A3(842 1191);A1,A2,A0那尺寸怎都会不是刚好两倍的呢?之间是怎样换算出来的。谢谢。 |
