旧 2010-09-17, 23:56     #1
Razzvanel Razzvanel 当前离线
级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时级别:71 | 在线时长:5338小时 | 升级还需:134小时
Uid: 176761
注册日期: 2010-07-31, 00:44
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
声望: 11 Razzvanel 向着好的方向发展
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
默认 Varnishes in Duotones?
Is it possible to use varnishes in duotones? I mean, not with duotones, covering them; but in duotones (or tritones, or quadtones), as the colors used to define them?
Razzvanel 当前离线
旧 2010-09-17, 23:59   只看该作者   #2
atilio atilio 当前离线
级别:1 | 在线时长:7小时 | 升级还需:5小时
Uid: 184347
注册日期: 2010-09-13, 01:46
声望: 10 atilio 向着好的方向发展
atilio atilio 当前离线
Uid: 184347
Sure. Just not sure what effect you're going to get. (or are trying to achieve)
atilio 当前离线
旧 2010-09-18, 00:20   只看该作者   #3
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
What effect? A higher dynamic range and three-dimensionality. Say, matte varnish on a curve identical with black (perhaps, even dot-on-dot) and glossy varnish on the opposite ("negative") curve. What do you think?
Razzvanel 当前离线
旧 2010-09-18, 00:24   只看该作者   #4
ayman_alya ayman_alya 当前离线
Uid: 185227
注册日期: 2010-09-18, 00:14
声望: 10 ayman_alya 向着好的方向发展
Uid: 185227
Sounds interesting. Just keep in mind that when a varnish is run in-line some of the gloss/matte effect is lost when it soaks into the ink. Certainly not a reason not to do it, but it might be a factor in the final product if you do the dot on dot.
I don't want to sound negative because we printers love doing stuff like this, but you're not going to be able to see what the final piece is going to look like until it's dry. By then you've put money into something that maybe didn't give you the effect you wanted.
Just an FYI.
ayman_alya 当前离线
旧 2010-09-18, 00:26   只看该作者   #5
atilio atilio 当前离线
Uid: 184347
atilio atilio 当前离线
Uid: 184347
That's my point...he says with a smile.....this isn't the type of process that you're printer is going to be able to proof unless you want to pay for a press run to proof it. You could do a press check when it actually goes to press, but you're not going to get the final effect of how it's going to look until 3 or 4 hours after it's run and by that time it will be too late.
Again....I think it sounds like a great idea and I'm not trying to talk you out of it, but since it's not commonplace and there's no way to proof it before it goes to press that leaves a lot of room for "that's not what I was looking for...." and somehow the printer always seems to lose money when that line is uttered. :-(
With that said......it's going to have SOME effect. If you're willing to try it for maybe a self promotion piece then you'll know and you should be able to work off of that for other projects. Also...there might be printers out there that have done this. Maybe you could call around in your/our area.
atilio 当前离线
旧 2010-09-18, 15:41   只看该作者   #6
Darius Darius 当前离线
级别:15 | 在线时长:297小时 | 升级还需:23小时级别:15 | 在线时长:297小时 | 升级还需:23小时级别:15 | 在线时长:297小时 | 升级还需:23小时级别:15 | 在线时长:297小时 | 升级还需:23小时级别:15 | 在线时长:297小时 | 升级还需:23小时级别:15 | 在线时长:297小时 | 升级还需:23小时
Uid: 175666
注册日期: 2010-07-25, 06:28
年龄: 44
感谢: 12
4 个帖子获得 9 次感谢
声望: 10 Darius 向着好的方向发展
Darius Darius 当前离线
Uid: 175666
年龄: 44
感谢: 12
4 个帖子获得 9 次感谢
The printer may not be able to directly proof your job, unless they do a press proof. However, any good printer should have samples of similar work that they've done before that they could show you. If you discuss the effect that you're after they could likely steer you in the right direction as to what will work and what may not.
Darius 当前离线
旧 2010-09-18, 15:43   只看该作者   #7
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
Thanks, guys! Don't be concerned over sounding too negative. Your advice is well taken. This is what I'm looking here for.
Btw, do you think a UV process would be a good idea to use for that? UV varnishes look better and, more importantly, UV inks dry faster. Maybe I'd not have to wait 3-4 hours to see a proof, after all.
Razzvanel 当前离线
旧 2010-09-18, 15:45   只看该作者   #8
atilio atilio 当前离线
Uid: 184347
atilio atilio 当前离线
Uid: 184347
A UV varnish or coat will yield higher gloss, but it also costs more to do (quite a bit more). You are only limited by your budget.
atilio 当前离线
旧 2010-09-19, 17:20   只看该作者   #9
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
Uid: 176761
感谢: 135
117 个帖子获得 1014 次感谢
现金: 1947金币
资产: 1947金币
Yes. I'm curious about the full UV process, though. Not just the varnish, but the process inks too. How much more expensive is that? I've read somewhere that, even though UV inks are more expensive, less of ink is necessary, so the final cost is actually less. I imagine UV varnish may be more efficient on a full-UV press too, if only because it could be applied inline over already dry ink (UV ink dries in seconds, if not less).
Razzvanel 当前离线
所有时间均为 +8, 现在的时间是 2025-01-01 18:28.
