| 论坛帮助 |
| 日历事件 |
只看该作者 #2 | |||
VIP会员
can you upload problem photo to CPC web site? i want more detail your issue. i have upload picture to you, you can clear the sensors, may be it had very dirty. after you test again, if error again, you will replace new Y laser unit? 1.png best regards, bananababy 此帖于 2011-08-11 19:37 被 banana167c 编辑. 原因: add picture |
只看该作者 #5 | |||
VIP会员
have you check the Fixing belt and Fixing unit?? can you upload the "listprint" text file to CPC web site? i want to read it. i upload "How to Save the List file into USB memory" guide to you. i waiting your listprint file. 1.png Save the List file into USB memory.pdf best regards bananababy |
