| 论坛帮助 |
| 日历事件 |
#1 | ||
精装书规格 平装书规格 (1)16K精装书成品尺寸: 260X185mm;版心尺寸: 215X138mm;订口对订口:46mm;地脚对地脚:40mm;翻口对翻口:60mm (2)16K平装书成品尺寸: 260X185mm;版心尺寸: 215X138mm;订口对订口:50mm;地脚对地脚:40mm;翻口对翻口:60mm (3)大16K精装书成品尺寸: 297X210mm;版心尺寸: 245X165mm;订口对订口:48mm;地脚对地脚:40mm;翻口对翻口:54mm (4)大16K平装书成品尺寸: 297X210mm;版心尺寸: 245X165mm;订口对订口:50mm;地脚对地脚:40mm;翻口对翻口:52mm (5)32K精装书成品尺寸: 184X130mm;版心尺寸: 153X100mm;订口对订口:32mm;翻口对翻口:36mm;地脚对地脚:30mm;天头对天头:48mm (6)32K平装书成品尺寸: 184X130mm;版心尺寸: 158X100mm;订口对订口:36mm;翻口对翻口:36mm;地脚对地脚:30mm;天头对天头:48mm (7)大32K精装书成品尺寸: 204X140mm;版心尺寸: 165X107mm;订口对订口:34mm;翻口对翻口:42mm;地脚对地脚:38mm;天头对天头:52mm (大32K平装书成品尺寸: 204X140mm;版心尺寸: 159X103mm;订口对订口:42mm;翻口对翻口:32mm;地脚对地脚:34mm;天头对天头:54mm (9)64K精装书成品尺寸: 130X92mm;版心尺寸: 103X70mm;订口对订口:24mm;翻口对翻口:28mm;地脚对地脚:26mm;天头对天头:40mm (10)64K平装书成品尺寸: 130X92mm;版心尺寸: 103X70mm;订口对订口:27mm;翻口对翻口:27mm;地脚对地脚:26mm;天头对天头:40mm |
