旧 2011-11-11, 09:35     #1
shhapx shhapx 当前离线
Uid: 222429
注册日期: 2011-04-21, 17:34
80 个帖子获得 111 次感谢
现金: 4407金币
资产: 4407金币
声望: 10 shhapx 向着好的方向发展
shhapx shhapx 当前离线
Uid: 222429
80 个帖子获得 111 次感谢
现金: 4407金币
资产: 4407金币
默认 柯达全胜设备配件编号
Trendsetter Part Product Number
Trendsetter Head new Laser
Creo Solder Side Board
FAST DPE 17-3672B-B
OPERATOR INTERFACE
POWER SUPPLY
ACCELSPEED DECEL
DDB-1-N 503D2L695S
MPG Back Plane Trendsetter 17-1411E-A
TEC CONTROLLER
CREO TRENDSETTER CTP POWER
DISTRIBUTION BOARD
TEE BOARD 10-3627C
RELAY DELAY CUT BOARD 17 370 1D
TRENDSETTER HEAD 20W 603M
TRENDSETTER PS BOARD MP4-21N 00
TRENDSETTER PL 9834629
TRENDSETTER CARRAGE MOTOR DRIVE 171312C-A
TRENDSETTER POWER SUPPLY ALC12011101011
Trendsetter Auto load cntrol 17-1311B-A
Trendsetter CTP-MPE 307026
Trendsetter Board D99024
TRENDSETTER SENSOR
Tee Board 10-3627C-A1
TRENDSETTER FAST DPE
TRENDSETTER 3244 291304
TRENDSETTER CABLE
Trendsetter Head
TEE BOARD 10-3627B-A
FAST DPE 17-367C-A
CAB ASSY 2 EA
TRENDSETTER HEAD KIT Parts
MASTER PROCESSOR PLL ERROR
LASER DETECTOR 7553-6260
Trendsetter 3230 D 24107
AUTO LOADER CONT 171311B-A
TRENDSETTER PRINT CONSOLE
AUTOLOADER 17-1311B-A
SCSI SWITCH
CREO RIP
Master Processor 10-3692B-B
Fast Dpe trendsetter 17-367c-a
MASTER PROCESSOR FAST DPE 17-07338-A
Powe Supply - Creo Trensetter
laser data 272A9175863
Kit, PM, Autoloader, Picker 50-2400A
FTG, Muffler, TRS Autopunch 55-0897
Brkt, Conn TS to TRS Autopunch 55-0900
Sw, Limit, TRS Autopunch 15-3375
Rel, SPDT, TRS Autopunch 15-3373
Rel, DPDT, TRS Autopunch 15-3374
Assy, Mech, Valve/solenoid, TRS Autopunch 55-0898
Assy, Mech, Ball nut, TRS Autopunch 50-1930
Cyl, 1-1/6"*2.0",DB ACT, SG Rod, Port ROT 55-0619
Assy, Mech, Unload Table, Maint Kit 50-2341A
Cylinder 55-0712
Sw, Micro, Roller, Lever, NA 15-3135
Cyl, Gas spring strut, 267N 127STK 55-0672
Elbow, 90deg, 10-32-3/32, Hose barb, Nylon 55-0204
Cyl, 7/8"*1"DB AL, Uni Mt 55-0574
Photo, sens, reflect modulated, 2-30 MM+ 36-3210
Wire W/ threaded piece on end 50-1616A-A
Filt, Air, Vacuum generator replacement 55-0214
Vacuum Genrtr, 1/8 NPT, N4tune straight 55-0597
Fab, Le, clamp pivot, short TS 57-7698B
Cab Assy, Opto Switch, TS-A 10-3683A
Nuts, Bolts (no threads), Pins 55-0605
Suction Cup, 40 Dia, Nitrile w/o valve 55-0295
Suction Cup, Fxd, Antistactic silicone 40mm 55-0541
Elbow, Air, Male, 10-32, 1/16", Ext Hex, Barb 55-0643
FTG, Tjoint, 1.5mm Hose barb 10-32 THD, nyl 55-0743
SW, Micro, Lever, SPST, No, 10MA, 12VDC 15-3478
Valve, Air, Double solenoid, 24VDC 55-0089
Cyl, 9/16"*1/2", DBL AC, SG RD DB & PVT mnt 55-1210
Brkt, TE Actuator, Cylinder , steel 57-2189A
Valve, Air, Sngl solenoid, spring Rtn 24VDC 55-0088
Sens, Reed switch, No, 200-250VDC, 5A 15-3063
Hinge, offset, lift-off, left mounting 59-3292
Hinge, offset, lift-off, right mounting 59-3291
Kit, Upgrade, Eco E120, TEC Backbone 8pg 05-2024_
Cyl, 2"*1-3/4", DBL Act, SGLrod, RR Trn Mnt 55-0056
shhapx 当前离线
所有时间均为 +8, 现在的时间是 2025-12-09 16:41.
