旧 2012-08-25, 12:40     #1
零点HJG 零点HJG 当前离线
级别:12 | 在线时长:202小时 | 升级还需:19小时级别:12 | 在线时长:202小时 | 升级还需:19小时级别:12 | 在线时长:202小时 | 升级还需:19小时
Uid: 143067
注册日期: 2010-01-25, 15:43
13 个帖子获得 15 次感谢
声望: 10 零点HJG 向着好的方向发展
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
默认 施乐黑白DC4110内部故障42-332 10-315
施乐黑白DC4110 打印过程中或待机状态下报042-332 表现为抽屉转动手柄2位置风扇停止运转 关机重新开机后则变成了10-315 这两个代码情况下 定影风扇运转正常 独抽屉转动手柄2位置风扇没有运转(没报代码时运转正常) 求解
零点HJG 当前离线
旧 2012-08-25, 13:15   只看该作者   #2
AQBJ12 AQBJ12 当前离线
级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时
Uid: 255348
注册日期: 2011-09-26, 18:59
35 个帖子获得 142 次感谢
声望: 10 AQBJ12 向着好的方向发展
AQBJ12 AQBJ12 当前离线
Uid: 255348
35 个帖子获得 142 次感谢
042-332 Fuser Intake X'fer Intake Fan Fail
BSD on:CH9.11, CH10.6
Description
A Fuser Intake Fan or X'fer Intake Fan failure
Initial Action
Check the Fan Blade of the Fuser Exhaust Fan for foreign objects and deformation causing a poor rotation.
Check that Connector J256 on the Fuser Intake Fan and Connector J257 on the Transfer Intake Fan are properly connected.
Procedure
Turn on the power. Open the Front Door. Cheat the Front Door Interlock Switch.
The Fuser Intake Fan has rotated.
Yes No
+12VDC is measured between J256-5 (+) and -4(-) on the Fuser Intake Fan.
Yes No
+12VDC is measured between J442-5 (+) and -6(-) on the IOT PWB.
Yes No
CR5 (GRN) on the IOT PWB is lighting.
Yes No
Seeing BSD CH1.6, check the +12VDC circuit to J430-6 on the IOT PWB.
Replace the IOT PWB (PL 2.1).
Check the circuits between J442-5 on the IOT PWB and J256-5 on the Fuser Intake Fan, and between J442-6 on the IOT PWB and J256-4 on the Fuser Intake Fan.
+12VDC is measured between J256-2 (+) on the Fuser Intake Fan and GND (-).
Yes No
+12VDC is measured between J442-8 (+) on the IOT PWB and GND (-).
Yes No
Disconnect and reconnect the cable between J432 on the IOT PWB and J402 on the MCU PWB. If this does not resolve the problem, replace the Flexible Print Cable (PL 2.1), IOT PWB (PL 2.1) and MCU PWB (PL 2.1) in order.
Check for an open wire or poor contact between J256-2 on the Fuser Intake Fan and J442-8 on the IOT PWB.
Replace the Fuser Intake Fan (PL 15.6).
Enter the Diag. Enter DC330 [042-001](Fuser Intake Fan High/Low). Select Start.
The Fuser Intake Fan comes to rotate at high speed.
Yes No
With DC330 [042-001] ON, approx. +2.73VDC is measured between J256-3 (+) on the Fuser Intake Fan and GND (-).
Yes No
Approx. +2.73VDC is measured between J442-7 (+) on the IOT PWB and GND (-).
Yes No
Check for an open wire or poor contact between J442-7 on the IOT PWB and J256-3 on the Fuser Intake Fan.
Turn off the power. Disconnect and reconnect the cable between J432 on the IOT PWB and J402 on the MCU PWB. If this does not resolve the problem, replace the Flexible Print Cable (PL 2.1), IOT PWB (PL 2.1) and MCU PWB (PL 2.1) in order.
Exit the Diag. Remove the Front Cover from the Marking Drawer.
The Transfer Intake Fan is rotating.
Yes No
+24VDC is measured between J257-4 (+) and -1(-) on the Transfer Intake Fan.
Yes No
+24VDC is measured between J442-1 (+) and -4(-) on the IOT PWB.
Yes No
+24VDC is measured between J430-2 (+) on the IOT PWB and GND (-).
Yes No
Seeing BSD CH1.16, check the +24VDC circuit to J430-2 on the IOT PWB.
Check the circuits between J442-1 on the IOT PWB and J257-4 on the Transfer Intake Fan, and between J442-4 on the IOT PWB and J257-1 on the Transfer Intake Fan.
Replace the Transfer Intake Fan (PL 13.13).
At service call, the Fuser Intake Fan and the Transfer Intake Fan appear to be normally rotating. Perform the following again:
Check the Fan Blade each of the Fuser Intake Fan and the Transfer Intake Fan for foreign objects and deformation causing a poor rotation.
If the problem reoccurs, replace the Fuser Intake Fan (PL 15.6) and Transfer Intake Fan (PL 13.13).
010-315 Fuser Latch Contact Fail
BSD on:CH9.14, CH10.2
Description
Nip Sensor does not turn ON a spec time after the Latch On signal is sent.
Initial Action
Check that the half-moon shaped plate that blocks the Fuser Nip Sensor is not broken.
Check that the couplings are engaged.
Check that the Drawer Connectors (P/J612) connecting the Fuser Unit and the main unit are free from bent pins, foreign objects and burnout.
Procedure
Turn off the power. Remove the Fuser Unit. (REP 15.1.1) Manually rotate the Fuser Nip Cam couplings.
The Fuser normally nips (to such a degree that the P-Roll slightly contacts the Heat Roll).
Yes No
Remove causes preventing the Fuser from nipping, such as a mechanical load like binding gears, which results from the latch operation; a foreign object in the nip drive area; and binding Cam Shaft bearings.
Turn on the power. Enter the Diag. Enter DC330 [010-202] (Fuser Nip Sensor). Select Start. Block the sensor with the half-moon shaped plate (no nipping) and push in the Drawer. Observe the display (H is displayed). Next removing the sensor along with the bracket, make the sensor receive light and hold the state, then push in the Drawer. (L is displayed.)
The display changes between H and L.
Yes No
Using 2.2.3.2 Permeable Sensor Failure FIP, troubleshoot the Fuser Nip Sensor.
Cheat the Front Door.
Enter DC330 [042-008] (Fuser Auger Motor). Select Start.
The Fuser Auger Motor is heard to operate.
Yes No
Open the PWB Chassis. (REP 2.1.1)
The Fuser Auger Motor tries to rotate.
Yes No
+24VDC is measured between J209-1 (+) and -2(-) on the Auger Motor.
Yes No
+24VDC is measured between J435-A14 (+) and -A13 (-) on the IOT PWB.
Yes No
+24VDC is measured between J433-1 (+) on the IOT PWB and GND (-).
Yes No
Seeing BSD CH1.16, check the +24VDC circuit to J433-1 on the IOT PWB.
Check the circuits each between J435-A14 on the IOT PWB and J209-1 on the Auger Motor, and between J435-A13 on the IOT PWB and J209-2 on the Auger Motor for an open wire or poor contact.
+5VDC is measured between J209-4 (+) and -5(-) on the Auger Motor.
Yes No
+5VDC is measured between J435-A11 (+) and -A10 (-) on the IOT PWB.
Yes No
Check the circuits each between J435-A11 on the IOT PWB and J209-4 on the Auger Motor, and between J435-A10 on the IOT PWB and J209-5 on the Auger Motor for an open wire or poor contact.
With DC330 [042-008] (Fuser Auger Motor) ON, +5VDC is measured between J209-3 (+) on the Auger Motor and GND (-).
Yes No
Replace the Auger Motor (PL 10.4).
+5VDC is measured between J435-A12 (+) on the IOT PWB and GND (-).
Yes No
Check the circuit between J435-A12 on the IOT PWB and J209-3 on the Auger Motor for an open wire or poor contact.
Replace the following parts in order:
MCU PWB (PL 2.1)
IOT PWB (PL 2.1)
Check the following:
Auger for a poor rotation due to toner blocking.
Inverter In Roll for an improper operation
Drive gears for binding
Enter the Diag. Enter DC330 [010-006] (Fuser Nip Clutch). Select Start.
The Fuser Nip Clutch is heard to operate.
Yes No
Using 2.2.3.4 Solenoid/Clutch Not Energized Failure FIP, troubleshoot the Fuser Nip Clutch.
Recheck if the latch operation has no problem; the couplings are properly engaged; the Clutch does not slip off. If no problem is found, replace the MCU PWB (PL 2.1) and the IOT PWB (PL 2.1) in order.
AQBJ12 当前离线
右列会员因为此帖价值甚高向 AQBJ12 表示感谢:
零点HJG (2012-08-25)
旧 2012-08-25, 15:37   只看该作者   #3
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
注册日期: 2010-04-19, 17:09
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
声望: 24 修施乐的海贼 向着好的方向发展
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
感觉楼上的狠详细了
俺这会不方便查手册
晚些时候回复
声 明 如 下:
TEL:15565218000 [V信同号];
[抖音号:zenjusthaizei(V信同号)];
TaoBao:正品施乐耗材旗舰店
←请点击
修施乐的海贼 当前离线
右列会员因为此帖价值甚高向 修施乐的海贼 表示感谢:
四季花开 (2017-09-07)
旧 2012-08-25, 16:30   只看该作者   #4
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
作者: AQBJ12 查看帖子
Description
Initial Action
Check that Connector J256 on the Fuser Inta...
很是详细 但让人费解的是 一会儿可以打印 一会儿又报错 有点点让人摸不着头绪 报错代码不是一直存在
零点HJG 当前离线
旧 2012-08-25, 16:36   只看该作者   #5
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
作者: 修施乐的海贼 查看帖子
感觉楼上的狠详细了
俺这会不方便查手册
晚些时候回复
机器不是一直报代码 报代码后通过开机前人为用纸挡住传感器让机器开机就报卡纸 然后取走卡纸 机器又能完全可以打印东西 运行一段时间后才报代码042-332 关机什么都不动再开机就变成了10-315 有时候正常开机也不会报错 这种时好时坏 不好查证 期待海贼兄高见
零点HJG 当前离线
旧 2012-08-26, 11:26   只看该作者   #6
huataixiang huataixiang 当前离线
级别:1 | 在线时长:11小时 | 升级还需:1小时
Uid: 313515
注册日期: 2012-08-26, 10:54
声望: 10 huataixiang 向着好的方向发展
Uid: 313515
机器由于不是一直报吧代码,而是频繁报这个代码的话,可能是定影的排气风扇不好了,轴承卡死了(就好像我们用的电风扇不好的时候就是有时转有时不转),可以取下来清洁下。还有检查下J256,J257插头接触好不
huataixiang 当前离线
旧 2012-08-26, 11:27   只看该作者   #7
tongwei121 tongwei121 当前离线
帅哥 级别:9 | 在线时长:125小时 | 升级还需:15小时级别:9 | 在线时长:125小时 | 升级还需:15小时级别:9 | 在线时长:125小时 | 升级还需:15小时
Uid: 129481
注册日期: 2009-11-25, 00:33
7 个帖子获得 18 次感谢
声望: 10 tongwei121 向着好的方向发展
Uid: 129481
7 个帖子获得 18 次感谢
我觉得是042-332的代码导致了后面的10-315的代码,而造成042-332代码的产生,怀疑风扇有问题。运行一段时间内,风扇处于较低转速,但过一段时间之后,由于定影器温度持续升高,需要风扇加大转速来排除更多的气体。然而,由于风扇的问题,不能够达到更高的转速,而报错。
至于10-315,我觉得你把042-332代码解决了,应该不会再报了。
tongwei121 当前离线
旧 2012-08-26, 15:04   只看该作者   #8
ncjingxi ncjingxi 当前离线
Uid: 90831
注册日期: 2009-04-10, 15:03
感谢: 93
92 个帖子获得 109 次感谢
现金: 453金币
资产: 453金币
声望: 10 ncjingxi 向着好的方向发展
Uid: 90831
感谢: 93
92 个帖子获得 109 次感谢
现金: 453金币
资产: 453金币
楼主不妨用手转动风扇试试,有问题的风扇会有迟滞感,如感觉明显的迟滞感,滴点油进去应该就不会再报错。但既使如此,也应备好风扇,滴油只能短时解决问题,时间长了还是会报错。
ncjingxi 当前离线
旧 2012-08-31, 09:08   只看该作者   #9
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
零点HJG 零点HJG 当前离线
Uid: 143067
13 个帖子获得 15 次感谢
非常感谢大家的分析帮助 问题终于给解决了 前门连锁开关导致24V供应出问题
零点HJG 当前离线
右列 2 位会员因为此帖价值甚高向 零点HJG 表示感谢:
brooks_yu (2021-05-10), 疯狂的小螺丝 (2012-09-02)
所有时间均为 +8, 现在的时间是 2025-12-09 19:50.
