旧 2013-06-15, 23:23     #1
poet33 的头像
poet33 poet33 当前离线
帅哥 级别:9 | 在线时长:118小时 | 升级还需:22小时级别:9 | 在线时长:118小时 | 升级还需:22小时级别:9 | 在线时长:118小时 | 升级还需:22小时
Uid: 251378
注册日期: 2011-09-04, 00:02
来自: 赵国
感谢: 22
声望: 10 poet33 向着好的方向发展
poet33 poet33 当前离线
poet33 的头像
Uid: 251378
来自: 赵国
感谢: 22
默认 施乐C800 出现45-381代码 不知道是哪里有问题啊 电话给工程师 又遇上周末救命啊
poet33 当前离线
旧 2013-06-16, 00:52   只看该作者   #2
AQBJ12 AQBJ12 当前离线
级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时级别:40 | 在线时长:1773小时 | 升级还需:72小时
Uid: 255348
注册日期: 2011-09-26, 18:59
35 个帖子获得 142 次感谢
声望: 10 AQBJ12 向着好的方向发展
AQBJ12 AQBJ12 当前离线
Uid: 255348
35 个帖子获得 142 次感谢
045-381 PH_1 MD PWB Fuse Fail
Detection Condition
The Fuse on the PH_1 MD PWB has blown.
Warning
Before doing any procedure other than such checks as diagnostic ones that are made with the machine alive, be sure to turn OFF the machine.
Electrical Parts to Check
The table shows the electrical parts related to this Fault Code for display. Utilize information on the table below for making a decision as to whether an electric part is good or not. After making a decision, replace the part as required.
When checking electrical parts, check connectors as well.
To decide whether individual parts such as sensors and motors are defective, go to 2.2.4 Generic FIPs.
Table 1 No.
Related Electrical Part
Location
Condition Check
Ref. BSD/WN
PL
PH_1 MD PWB
7.4.2-18
Refer to 2.2.1
CH1.40, CH1.27, CH1.28, CH1.29, CH1.30 / 7.2.1.64, 7.2.1.66, 7.2.1.69, 7.2.1.72
PL 18.2
DST 1 (IOT-L) PWB
7.4.1-6
Refer to 2.2.1
CH1.27, CH1.28, CH1.29, CH1.30, CH1.12, CH1.13, CH1.14, CH1.15 / 7.2.1.64, 7.2.1.66, 7.2.1.69, 7.2.1.72, 7.2.1.55, 7.2.1.56
PL 18.11
FLY 1 PWB
7.4.1-16
CH1.12 / 7.2.1.55
PL 18.11
LVPS S24-1
7.4.17-37
REP 18.12.2
CH1.12 / 7.2.1.55
PL 18.12
FLY 3 PWB
7.4.1-15
CH1.13 / 7.2.1.55
PL 18.11
LVPS S24-2
7.4.17-38
REP 18.12.2
CH1.13 / 7.2.1.55
PL 18.12
LVPS S24-3
7.4.17-16
REP 18.12.2
CH1.14 / 7.2.1.56
PL 18.12
FLY 6 PWB
7.4.1-11
CH1.15 / 7.2.1.55
PL 18.11
AQBJ12 当前离线
右列 2 位会员因为此帖价值甚高向 AQBJ12 表示感谢:
poet33 (2013-06-16), 修施乐的海贼 (2013-06-16)
旧 2013-06-16, 09:55   只看该作者   #3
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
注册日期: 2010-04-19, 17:09
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
声望: 24 修施乐的海贼 向着好的方向发展
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
奇怪了 为何我和楼上这位查到的信息居然是有些出入的
不过大致差不多的
难道800的手册还有狠多版本吗
从代码来看
似乎是这个 PH 1 MD PWB 板子上的保险管 或者 电容有短路
导致了某个驱动转动有问题
EXAMPLE: (coordinates D-1 on BSD 1.40)
CR41 not lit
Fuse F8 is indicated on BSD 1.48
BSD 1.40 shows V-Tra Motor 1 Fuse 8 status can be troubleshot using BSD 10.1
根据以上提示 目测 CR41的电容灯是否正常
然后看 F8这个地方
PH 1 MD PWB 是下图所示的位置的10号
不过建议楼主暂时忍了吧 还是工程师来了再说
或者重启就好了 或许真的是板子有问题
声 明 如 下:
TEL:15565218000 [V信同号];
[抖音号:zenjusthaizei(V信同号)];
TaoBao:正品施乐耗材旗舰店
←请点击
修施乐的海贼 当前离线
右列会员因为此帖价值甚高向 修施乐的海贼 表示感谢:
poet33 (2013-06-16)
旧 2013-06-16, 10:22   只看该作者   #4
poet33 的头像
poet33 poet33 当前离线
Uid: 251378
来自: 赵国
感谢: 22
poet33 poet33 当前离线
poet33 的头像
Uid: 251378
来自: 赵国
感谢: 22
是纸槽有问题额 放纸过多导致的 。。。唉
poet33 当前离线
旧 2013-06-16, 10:24   只看该作者   #5
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
作者: poet33 查看帖子
800 有这么脆弱?
那么大个鸡鸡 搞多一些纸张就会报错?
修施乐的海贼 当前离线
旧 2013-06-16, 12:07   只看该作者   #6
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
先检查这个电路板哪个贴片保险烧了,我再帮你查那一路有问题,另外话先说明白:这个问题不好搞,熟练的工程师也需要耗一段时间才能搞掂,还有这个问题不是因为纸放多了导致的
balenofeng 当前离线
右列会员因为此帖价值甚高向 balenofeng 表示感谢:
poet33 (2013-06-16)
旧 2013-06-16, 14:13   只看该作者   #7
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
那就是说 楼主的问题还没好喽
那到底到哪一步了?
修施乐的海贼 当前离线
旧 2013-06-16, 14:59   只看该作者   #8
poet33 的头像
poet33 poet33 当前离线
Uid: 251378
来自: 赵国
感谢: 22
poet33 poet33 当前离线
poet33 的头像
Uid: 251378
来自: 赵国
感谢: 22
只能等周一的时候 工程师过来才能解决了。。。现在暂时把纸槽拉出来 用另外一个纸槽 机器就可以使用了。。。要是两个纸槽一起推进去 机器都不能正常启动。。。
poet33 当前离线
旧 2013-06-16, 16:41   只看该作者   #9
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
楼主的问题应该是1号纸盒烧保险
处理这个代码的方法:
要看到这个板子,先要把抽风模块拆掉,打开后盖板,就可以看到
在每个贴片保险旁边有个绿色的小灯,只要那个小灯不亮了,就知道是那个保险烧掉了。然后在顺着电路图查这个保险是管哪几路的电,然后挨个替换或者检查。
balenofeng 当前离线
右列 2 位会员因为此帖价值甚高向 balenofeng 表示感谢:
旧 2013-06-16, 21:33   只看该作者   #10
看见神了吧 看见神了吧 当前离线
帅哥 级别:16 | 在线时长:341小时 | 升级还需:16小时
Uid: 139042
注册日期: 2010-01-03, 17:39
28 个帖子获得 39 次感谢
现金: 36金币
资产: 36金币
声望: 10 看见神了吧 向着好的方向发展
看见神了吧 看见神了吧 当前离线
Uid: 139042
28 个帖子获得 39 次感谢
现金: 36金币
资产: 36金币
没错,确实是保险烧了,解决办法见如下施乐Ti
文件类型: jpg 1.JPG (290.6 KB, 50 次查看)
看见神了吧 当前离线
右列会员因为此帖价值甚高向 看见神了吧 表示感谢:
woshilon (2019-03-12)
所有时间均为 +8, 现在的时间是 2025-12-02 15:17.
