旧 2013-07-01, 10:34     #1
longyu918 longyu918 当前离线
Uid: 347535
注册日期: 2013-05-29, 16:25
声望: 10 longyu918 向着好的方向发展
Uid: 347535
默认 施乐6060报003-393代码怎么解决
我们店的施乐6060机器,每天早上解除待机状态都会报003-393代码,以前的处理方法都是关一会机再开就好了,现在这个方法不行了,开老半天也开不起来,求救!最好有一劳永逸的解决方法,谢谢!
longyu918 当前离线
旧 2013-07-02, 08:47   只看该作者   #2
Uid: 347535
Uid: 347535
这个问题很棘手吗?渺似木有人来回答哦,机器停了几天了!
longyu918 当前离线
旧 2013-07-02, 18:26   只看该作者   #3
zw9612 zw9612 当前离线
级别:8 | 在线时长:99小时 | 升级还需:18小时级别:8 | 在线时长:99小时 | 升级还需:18小时
Uid: 154243
注册日期: 2010-04-03, 20:56
现金: 49金币
资产: 49金币
声望: 10 zw9612 向着好的方向发展
zw9612 zw9612 当前离线
Uid: 154243
现金: 49金币
资产: 49金币
3-393 EPC Fan 1 Fail RAP
Description
Fault Code 3-393 indicates that the IOT PWB has detected an irregularity in rotation rate of EPC Fan 1.
Initial Action
Refer to BSD 3.4 in the following procedure
Procedure
PO/PO the Machine
Fault Code 3-393 is still declared.
Yes No Unanswered
If an intermittent condition is suspected, inspect and reseat connectors P/J 654 and J382. If the fault persists, go to OF2 Intermittent Fault RAP.
+12 VDC is measured between J382-1 and J382-4 EPC Fan 1 Power Input.
Yes No Unanswered
Go to the LVPS A +12 VDC RAP.
+5 VDC is measured between J655-10 and GND.
Yes No Unanswered
Disconnect P/J655.
+5 VDC is measured between P655-10 and GND.
Yes No Unanswered
Replace the System PWB ( PL 19.2).
Perform the following:
Check the wire at Flag 1 in BSD 3.4 for a short circuit.
Replace the EPC Fan 1 ( PL 19.7).
+5 VDC is measured between J382-2 and GND.
Yes No Unanswered
Replace the Motherboard PWB Assembly ( PL 19.2).
Go to Flag 2 in BSD 3.4 and check for an open circuit.
该风扇位系统模块放置硬盘的位置。
zw9612 当前离线
右列会员因为此帖价值甚高向 zw9612 表示感谢:
疯狂的小螺丝 (2013-07-03)
旧 2013-07-02, 18:30   只看该作者   #4
zw9612 zw9612 当前离线
Uid: 154243
现金: 49金币
资产: 49金币
zw9612 zw9612 当前离线
Uid: 154243
现金: 49金币
资产: 49金币
图片好难弄,只能这样子上传附件了。
文件类型: jpg 风扇位置图.jpg (205.0 KB, 6 次查看)
zw9612 当前离线
旧 2013-07-03, 13:32   只看该作者   #5
Uid: 347535
Uid: 347535
问题解决了,确实是EPC FAN2的问题。风扇不转了,拆下来清洁加上润滑油后,风扇能正常运转,症状消失。感谢zw9612......
longyu918 当前离线
右列会员因为此帖价值甚高向 longyu918 表示感谢:
疯狂的小螺丝 (2013-07-03)
所有时间均为 +8, 现在的时间是 2025-12-09 07:03.
