旧 2013-08-19, 18:08     #1
永念快印 永念快印 当前离线
帅哥 级别:21 | 在线时长:526小时 | 升级还需:46小时级别:21 | 在线时长:526小时 | 升级还需:46小时级别:21 | 在线时长:526小时 | 升级还需:46小时
Uid: 255640
注册日期: 2011-09-27, 23:59
来自: 南京市浦口区
感谢: 17
18 个帖子获得 20 次感谢
现金: 123金币
资产: 123金币
声望: 10 永念快印 向着好的方向发展
永念快印 永念快印 当前离线
Uid: 255640
来自: 南京市浦口区
感谢: 17
18 个帖子获得 20 次感谢
现金: 123金币
资产: 123金币
默认 施乐4112 报代码077—142
每个纸盒都卡纸,基本都是报077-142,哪位师傅知道是什么问题,谢谢了
永念快印 当前离线
旧 2013-08-19, 22:25   只看该作者   #2
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
给你查了一下手册,自己先看看吧,好像有点长,有空再来补充
077-142 Pre Transfer Sensor On Jam
BSD on:CH8.12
Description
A specified time after Regi Motor On, the Pre Transfer Sensor does not turn On. (H stays displayed.)
Procedure
Enter DC330[077-113](Pre Transfer Sensor). Press Start. Slide out the Marking Drawer and place a piece of paper on the sensor.
Push in the Marking Drawer.
The display is L.
Yes No
Turn off the power. Check the following:
The wire between IOT PWB J439-B1 and Pre Transfer Sensor J191-1 for conductivity
The wire between IOT PWB J439-B2 and Pre Transfer Sensor J191-2 for an open wire or poor contact
The wire between IOT PWB J439-B3 and Pre Transfer Sensor J191-3 for conductivity
The Flexible Print Cable between IOT PWB J432 and MCU PWB J402 for poor connection
Drawer Connector P/J601 for bent pins/breakage/foreign objects
The sensor for dirt/improper installation
If no problem is found, replace the following parts in order.
Pre Transfer Sensor (PL 13.5)
Flexible Print Cable (PL 2.1)
IOT PWB (PL 2.1)
MCU PWB (PL 2.1)
Slide out the Marking Drawer and remove the paper from the sensor.
The display has changed to H.
Yes No
The wire between IOT PWB J439-B2 and Pre Transfer Sensor J191-2 for a short circuit.
The sensor for improper installation/light from outside
IOT PWB (PL 2.1)
MCU PWB (PL 2.1)
Press Stop.
Cheat the IOT Front Door Interlock Switch.
Turn On DC330[077-006](Regi Motor). Press Start.
The motor is heard operating.
Yes No
Remove the IOT Rear Upper/Lower Cover. (PL 1.2)
+24VDC is measured between IOT PWB J441-11(+) and GND(-).
Yes No
+24VDC is measured between IOT PWB J433-1(+) and GND(-).
Yes No
Seeing CH1.12, check the INTLK +24VDC circuit to IOT PWB J433-1.
Turn off the power. Measure the resistance across Chip Fuse F3 on IOT PWB, using the tester. If 1 ohm or more is measured (normally 0.1 ohm - 0.5 ohm), the fuse has blown. Check that the Regi Motor has no excessive load. Replace the IOT PWB. (PL 2.1)
Turn off the power. Remove the Regi Unit. (REP 13.1.2)
Disconnect Connector J230 from the Regi Motor. Measure the motor winding resistance.
P230-2 to P230-1/ P230-3
P230-5 to P230-4/ P230-6
Each resistance is approx. 2.2ohms+/-0.22 ohm (25 deg.C).
Yes No
Replace the Regi Motor. (PL 13.4)
Reconnect Connector J230 to the Regi Motor. Reinstall the Regi Unit. Push in the Marking Drawer.
Disconnect Connector J441 on the IOT PWB.
Check the following for conductivity.
IOT PWB J441-11 to IOT PWB J441-10/12
IOT PWB J441-8 to IOT PWB J441-7/9
Yes No
Check either problem wire for an open wire or poor contact.
Check if the Flexible Print Cable is properly connected between IOT PWB J432 and MCU PWB J402. If no problem is found, replace the following parts in order.
IOT PWB (PL 2.1)
MCU PWB (PL 2.1)
Regi Roll for dirt/wear/poor rotation (PL 13.4)
Regi Pinch Roll for dirt/wear/poor rotation (PL 13.15)
Whether Tension Spring is out of place/has deteriorated. (PL 13.15)
Gear for wear/breakage (PL 13.4)
Inlet Chute for deformation (PL 13.5)
Whether the Seal is peeling off. (PL 13.5)
balenofeng 当前离线
右列会员因为此帖价值甚高向 balenofeng 表示感谢:
永念快印 (2013-08-20)
旧 2013-08-20, 10:47   只看该作者   #3
jickysky99 jickysky99 当前离线
级别:9 | 在线时长:121小时 | 升级还需:19小时级别:9 | 在线时长:121小时 | 升级还需:19小时级别:9 | 在线时长:121小时 | 升级还需:19小时
Uid: 352745
注册日期: 2013-07-03, 09:47
1 个帖子获得 2 次感谢
声望: 10 jickysky99 向着好的方向发展
Uid: 352745
1 个帖子获得 2 次感谢
给你查了一下手册,自己先看 ​​看吧,好像有点长,有空再来补充 077-142预传输传感器卡纸 BSD:CH8.12 说明 ,前转让后的指定时间注册查询汽车传感器不开启。(H保持显示) 程序 输入DC330 [077-113](预传输传感器)。按下开始。滑出标记抽屉放一张纸传感器。 推扣分抽屉。 显示为L 是否 关闭电源。检查下列各项: IOT PWB J439-B1和预传输传感器J191-1电导率 IOT PWB J439-B2和预传输传感器J191-2明线或接触不良 IOT PWB J439之间的导线之间的导线线之间B3和预传输传感器J191-3导电 柔性印刷IOT PWB J432和J402 MCU板之间的电缆连接不良 抽屉连接器的针脚是否弯曲/破损/ 污垢/安装不当异物传感器P/J601 如果没有发现问题,以下几部分组成,以取代。 预传输传感器(PL 13.5) 灵活的打印电缆(PL 2.1) IOT PWB(PL 2.1) MCU板(PL 2.1) 滑出扣分抽屉,取出纸张传感器 推入标记抽屉。 显示变为H. 是否 关闭电源。检查下列各项: 线之间的IOT PWB J439-B2和预传输传感器J191-2短路。 IOT PWB J432和J402 MCU板之间的连接不良 抽屉连接P/J601的为灵活的打印电缆弯曲的针脚/破损/异物 传感器安装不当/光从外面 如果没有发现问题,为了取代以下几部分组成。 预传输传感器(PL 13.5) 灵活的打印电缆(PL 2.1) IOT PWB(PL 2.1) MCU板(PL 2.1) 按“停止”。 欺骗IOT接待门联锁开关 打开DC330 [077-006](注册查询汽车)。按下启动。 听到电机运行。 是否 取出物联网后上/下盖。(PL 1.2) +24 VDC IOT PWB J441-11(+)和GND( - )之间测得的 是无 +24 VDC IOT PWB J433-1(+)和GND( - )之间测得的 是没有 看到CH1.12检查的INTLK +24 V电路IOT PWB J433-1, 关闭电源。测量之间的电阻贴片保险丝F3 IOT PWB,使用测试仪。如果超过1欧姆或测量(通常为0.1欧姆- 0.5欧姆),保险丝烧断。检查注册查询汽车有没有过多的负荷。更换IOT的工作计划和预算。(PL 2.1) 关闭电源。删除注册查询单位。(REP 13.1.2) 断开连接器J230的注册查询汽车。测量电机绕组电阻。 P230-2,P230-1 / P230- P230-P230-4 / P230-6 每个电阻约。2.2ohms + / -0.22欧姆(25℃)。 是否 更换电机注册查询。(PL 13.4) 重新连接器J230的注册查询电机。重新安装注册查询单位。推扣分抽屉 上断开连接器J441 IOT PWB 检查以下电导率。 IOT PWB J441-11 物联网PWB J441-7/9 IOT PWB J441-10/12的IOT PWB J441-8 每阻力约。2.2ohms + / -0.22欧姆(25℃)。 是否 检查要么电线明线或接触不良问题。 检查IOT PWB J432和J402 MCU板之间的灵活的打印电缆是否正确连接。如果没有发现问题,更换以下几部分组成,以 灵活的打印电缆(PL 2.1) IOT PWB(PL 2.1) MCU板(PL 2.1) 检查以下内容: 注册查询辊为污垢/磨损/旋转差(PL 13.4) 注册查询 拉簧夹送辊为污垢/磨损/旋转差(特等13.15)无论是出于地方/已经恶化。(特等13.15) 齿轮磨损/破损(PL 13.4) 进口溜槽变形(PL 13.5) 的印章是否剥落。(PL 13.5)
jickysky99 当前离线
右列 2 位会员因为此帖价值甚高向 jickysky99 表示感谢:
永念快印 (2013-08-20), 疯狂的小螺丝 (2013-08-20)
旧 2013-08-20, 10:50   只看该作者   #4
Uid: 352745
1 个帖子获得 2 次感谢
Uid: 352745
1 个帖子获得 2 次感谢
如果每个纸盒都卡 就要找共同的地方 是不是卡在翻面进纸传感器那呢
jickysky99 当前离线
旧 2013-08-20, 18:40   只看该作者   #5
永念快印 永念快印 当前离线
Uid: 255640
来自: 南京市浦口区
感谢: 17
18 个帖子获得 20 次感谢
现金: 123金币
资产: 123金币
永念快印 永念快印 当前离线
Uid: 255640
来自: 南京市浦口区
感谢: 17
18 个帖子获得 20 次感谢
现金: 123金币
资产: 123金币
问题已近解决,是对位组件传动电机的齿轮碎了,吧原来塑料的,换成金属就OK了,谢谢帮忙!
永念快印 当前离线
旧 2013-08-21, 11:38   只看该作者   #6
Uid: 352745
1 个帖子获得 2 次感谢
Uid: 352745
1 个帖子获得 2 次感谢
078-103 HCF Exit Sensor ON Jam
BSD-ON:CH8.13
HCF Exit Sensor does not turn ON a spec time (which depends on the tray) after the Feed Out Sensor of
an appropriate one of the trays in HCF turns ON.
DC330Code to Check
• [078-140] HCF Exit Sensor
• [078-040] HCF Takeaway Motor
• [078-050] HCF Exit Clutch
Check Items
• Paper Path for a foreign object/burr/piece of paper
• HCF Transport Belt for a poor tension
• HCF Transport Roll for dirt/paper particles/wear/a poor rotation
• HCF Takeaway Rolls 1-3 for dirt/paper particles/wear/a poor rotation
• HCF Exit Roll for dirt/paper particles/wear/a poor rotation
• HCF Exit Clutch for an improper operation/slippage
• Check for poorly latched HCF T/A Chute
• Drive gears for wear/breakage
• Check for out-of-spec paper.
• Check the following for an open wire or poor contact. If the wires are good, replace HCF Exit Sen-sor (PL 9.18).
– HCF Exit Sensor PF64-2«HCF PWB JF1-B5
– HCF Exit Sensor PF64-1«HCF PWB JF1-B6
– HCF Exit Sensor PF64-3«HCF PWB JF1-B4
• If the results of the above checks are OK, replace HCF PWB (PL 9.14).
jickysky99 当前离线
旧 2013-08-21, 16:24   只看该作者   #7
修施乐的海贼 的头像
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
Uid: 157606
注册日期: 2010-04-19, 17:09
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
声望: 24 修施乐的海贼 向着好的方向发展
修施乐的海贼 修施乐的海贼 当前离线
正嘉数码●施乐正品
修施乐的海贼 的头像
Uid: 157606
来自: 广州正嘉数码
感谢: 923
1013 个帖子获得 2492 次感谢
现金: 107金币
资产: 107金币
声 明 如 下:
TEL:15565218000 [V信同号];
[抖音号:zenjusthaizei(V信同号)];
TaoBao:正品施乐耗材旗舰店
←请点击
修施乐的海贼 当前离线
所有时间均为 +8, 现在的时间是 2025-12-08 17:21.
