2014-02-13, 20:16 | 只看该作者 #2 | ||
Abstract 摘要 ISO 12647-2:2013 specifies a number of process parameters and their values to be applied when producing colour separations, printing formes and print production for four- colour sheet-fed and web-fed offset printing presses excluding coldset offset lithography on newsprint. ISO 12647-2:2013规定了应用于四色分色生成,制作印版和四 色单张纸和卷筒纸胶印印刷生产处理的一些工艺参数和数值, 但不包括冷固型新闻纸胶印应用。 The parameters and values are chosen in view of the typical process covering the process stages "colour separation", "proof production", "making of the printing forme", "OK print" and "production printing" on all kinds of commercially available production substrates. 可基于典型的涵盖了“分色”,“打样生产”,“制作印 版”,“合格印刷”和“印刷生产”工艺阶段过程,针对各类 市售的承印物选择参数和数值。 ISO 12647-2:2013: is directly applicable to press proof prints and printing processes that use colour separation printing formes as input; ISO 12647-2:2013: 直接用于印刷打样和使用分色印版作为输入处理的印刷工艺; is applicable to press proof prints and printing processes with more than four process colours as long as direct analogies to four-colour printing are maintained, such as for data and screening, for print substrates and printing parameters; 用于印刷打样和四个以上的原色的印刷处理,只要直接类比于 四色印刷,例如用于数据和加网,印刷承印物和印刷参数; is applicable to printing on cardboard material for packaging; 用于包装印刷纸板材料; is applicable for all kinds of drying methods such as heat-set, infrared, and ultraviolet; 适用于各种干燥方法,例如热固型,红外线和紫外线; provides references for quality assurance and quality management. 提供质量保证和质量管理的参考。 |
2014-03-05, 21:13 | 只看该作者 #9 | |||
G7&PSO专家
[隐藏内容]:
右列 7 位会员因为此帖价值甚高向 Joeric 表示感谢: |
Bloodsaler (2014-03-10),
enprint (2014-03-05),
foreverinwind (2014-03-18),
quiet (2014-03-13),
reilong (2024-05-14),
奋斗吧 (2018-05-06),
小郭郭 (2014-03-06)
