旧 2014-02-21, 21:50     #1
cpclgw cpclgw 当前在线
帅哥 级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时级别:87 | 在线时长:7989小时 | 升级还需:107小时
Uid: 333099
注册日期: 2013-03-11, 13:56
感谢: 756
427 个帖子获得 704 次感谢
资产: 4042金币
声望: 10 cpclgw 向着好的方向发展
cpclgw cpclgw 当前在线
Uid: 333099
感谢: 756
427 个帖子获得 704 次感谢
资产: 4042金币
默认 今天刚收到的 最新 CGS 2.06下载地址:
最新 CGS 2.06下载地址:
http://www.cgs-oris.com/index.php/en...olor-tuner-web
User name: athen
Password: zappion
更新内容:
ORIS COLOR TUNER // WEB Version 2.0.6
RELEASE NOTES
© CGS Publishing Technologies International GmbH – 02/18/2014
This file describes the additions and bug fixes in ORIS Color Tuner//Web Version 2.0.6.
Licensing
Version 2.0.6 is license-protected and requires the input of a new code for your dongle. A new code for Version 2.0.6 is not required if you are already using Version 2.0.
Operating System
Installing ORIS Color Tuner//Web requires Windows XP SP3 or higher.
System Recommendations
We recommend the following computer equipment for optimum performance and high throughput:
Intel® Core i7 or similar
4 GB RAM or more
500 GB hard disk capacity (system disk) or more
Windows 7
Internet Explorer Version 10
Contents
1. Additions
Support for Roland VersaCAMM VS-i Printers
Installing the Printer Driver
New Color Modes for Roland SOLJET PRO4 XR-640
Localization
2. Bug Fixes
RGB Proofing
Align Points (Roland Printers)
Bleed Pages
ORIS Certified//Web
1. Additions
ORIS Color Tuner//Web 2.0.6 additionally supports the following Roland DG inkjet printers/cutters:
Roland VersaCAMM VS-640i
Roland VersaCAMM VS-540i
Roland VersaCAMM VS-300i
Supported printing methods:
Continuous tone if printers are equipped with ECO-SOL MAX2 ink
Continuous tone, ScreenDot and ScreenDot Plus if eco-solvent XG INKS are used
Colors: 8
Cyan, magenta, yellow, black, light cyan, light magenta, white, metallic silver (ECO-SOL MAX2 ink)
Cyan, magenta, yellow, black, orange, green, white, metallic silver (eco-solvent XG INKS)
Maximum resolution: 1440 dpi
Maximum media width:
64 inch (163 cm) for VS-640i
54 inch (137 cm) for VS-540i
30 inch (76 cm) for VS-300i
There are no Windows printer drivers available for Roland printers. Do the following to create a generic TCP/IP printer:
Select the following command on the Windows Start menu:
Devices and Printers (Windows 7)
Control Panel | Hardware and Sound | Printers (Windows Vista)
Printers and Faxes (Windows XP)
Click Add a printer.
Select Local printer.
Create a new Standard TCP/IP Port.
Enter the printer’s IP address.
Leave the standard device type set at Generic Network Card.
Select the printer manufacturer Generic and the printer Generic/Text Only.
Enter the printer name:
If MAX2 ink is used:
Roland VS-640i or
Roland VS-540i or
Roland VS-300i
If XG INKS are used:
Roland VS-640i XGINKS or
Roland VS-540i XGINKS or
Roland VS-300i XGINKS
Make sure to use exactly this spelling. The program uses the Windows printer name to identify the ink set installed in the printer.
The following color modes are now additionally available for Roland SOLJET PRO4 XR-640 printers used with the printing method Continuous tone:
CMYK
CMYK + White
CMYK + Metallic silver
CMYK + White + Metallic silver
CMYK + White + Metallic silver (Multi pass)
CMYKOrGr (XG INKS) + White
CMYKOrGr (XG INKS) + Metallic silver
CMYKOrGr (XG INKS) + White + Metallic silver
Localization
The Japanese language files have been updated.
2. Bug Fixes
RGB Proofing
RGB images and documents with images defined in the RGB color space are now interpreted and color-matched correctly even if scatter proofing is enabled.
Applying align points caused the printed image to be stretched horizontally under certain conditions.
Bleed Pages
Color separation names defined on a bleed page are now printed completely as expected.
ORIS Certified//Web
Delta E values for single-patch measurements are calculated correctly now.
cpclgw 当前在线
右列 12 位会员因为此帖价值甚高向 cpclgw 表示感谢:
2018 (2014-02-22), bbbhhh (2014-02-22), DuoKe (2014-02-22), jememouse (2016-05-06), jimmy (2014-02-24), kinrei518 (2014-12-26), shyanjl (2014-02-23), wangyu1314 (2014-02-22), wjzoufeng (2014-02-21), worm (2014-02-25), xcj_xu (2014-02-22), 旋風 (2014-02-22)
旧 2014-02-22, 11:12   只看该作者   #2
fgpwu 的头像
fgpwu fgpwu 当前离线
帅哥 级别:20 | 在线时长:487小时 | 升级还需:38小时级别:20 | 在线时长:487小时 | 升级还需:38小时
Uid: 294626
注册日期: 2012-04-18, 23:36
7 个帖子获得 7 次感谢
现金: 21金币
资产: 21金币
声望: 10 fgpwu 向着好的方向发展
fgpwu fgpwu 当前离线
fgpwu 的头像
Uid: 294626
7 个帖子获得 7 次感谢
现金: 21金币
资产: 21金币
是升级安装还是完整安装 ?完整安装好像有一个多G吧?
fgpwu 当前离线
旧 2014-02-22, 13:22   只看该作者   #3
2018 的头像
2018 2018 当前离线
帅哥 级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时级别:83 | 在线时长:7357小时 | 升级还需:35小时
Uid: 225786
注册日期: 2011-05-10, 12:24
感谢: 226
96 个帖子获得 128 次感谢
现金: 0金币
声望: 10 2018 向着好的方向发展
2018 2018 当前离线
2018 的头像
Uid: 225786
感谢: 226
96 个帖子获得 128 次感谢
现金: 0金币
就一个CTW206_16.exe安装文件!
2018 当前离线
旧 2014-02-22, 13:54   只看该作者   #4
帅哥 级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时级别:234 | 在线时长:56110小时 | 升级还需:55小时
感谢: 9309
2688 个帖子获得 17147 次感谢
现金: 3273金币
资产: 13508金币
感谢: 9309
现金: 3273金币
资产: 13508金币
加密倒是改的很快,中文乱码还是没有改正过来。。
wangyu1314 当前离线
旧 2014-02-22, 14:18   只看该作者   #5
小郭郭 的头像
小郭郭 小郭郭 当前离线
金币充值入口
帅哥 级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时级别:108 | 在线时长:12112小时 | 升级还需:205小时
Uid: 21960
注册日期: 2006-09-05, 22:32
来自: 东莞数码印刷
感谢: 1045
955 个帖子获得 2886 次感谢
现金: 8858金币
资产: 67630金币
声望: 33 小郭郭 是将要出名的人啊
小郭郭 小郭郭 当前离线
金币充值入口
小郭郭 的头像
Uid: 21960
来自: 东莞数码印刷
感谢: 1045
955 个帖子获得 2886 次感谢
现金: 8858金币
资产: 67630金币
声望: 33 小郭郭 是将要出名的人啊
CGS软件功能效果倒是挺不错的,就是这写软件的质量真垃圾。。。
--专业印刷机色彩管理、CTP连线、CIP3、数码影像色彩管理--
专业印能捷维修,专治疑难杂症,出售二手稳定耐用服务器
电话微信:13794990185
小郭郭 当前离线
旧 2014-02-22, 17:02   只看该作者   #6
qujunming 的头像
qujunming qujunming 当前离线
级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时级别:159 | 在线时长:26027小时 | 升级还需:213小时
Uid: 34617
注册日期: 2007-02-26, 12:56
来自: Hangzhou.Zhejiang
感谢: 307
249 个帖子获得 639 次感谢
现金: 677金币
资产: 677金币
声望: 14 qujunming 向着好的方向发展
qujunming 的头像
Uid: 34617
感谢: 307
249 个帖子获得 639 次感谢
现金: 677金币
资产: 677金币
谁下好了 百度网盘发下 共享吧
QQ群 5320898 欢迎前来交流
qujunming 当前离线
旧 2014-02-22, 18:31   只看该作者   #7
旋風 的头像
旋風 旋風 当前离线
级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时级别:104 | 在线时长:11377小时 | 升级还需:68小时
Uid: 85434
注册日期: 2009-02-24, 17:23
感谢: 613
521 个帖子获得 881 次感谢
现金: 5703金币
资产: 25703金币
声望: 18 旋風 向着好的方向发展
旋風 旋風 当前离线
旋風 的头像
Uid: 85434
感谢: 613
521 个帖子获得 881 次感谢
现金: 5703金币
资产: 25703金币
声望: 18 旋風 向着好的方向发展
这个下载速度有点慢,
旋風 当前离线
旧 2014-02-22, 22:16   只看该作者   #8
风岭2011 的头像
风岭2011 风岭2011 当前离线
顽石之中良玉隐焉
帅哥 级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时级别:173 | 在线时长:30697小时 | 升级还需:275小时
Uid: 714
注册日期: 2004-08-09, 20:01
感谢: 764
380 个帖子获得 661 次感谢
现金: 218金币
资产: 555金币
声望: 13 风岭2011 只能期待他慢慢抹去身上的污点
风岭2011 风岭2011 当前离线
顽石之中良玉隐焉
风岭2011 的头像
Uid: 714
感谢: 764
380 个帖子获得 661 次感谢
现金: 218金币
资产: 555金币
下载速度不慢呀!
生产不干胶贴纸,双面胶EVA,珍珠棉,海棉等电子绝缘材料等业务!树下春包装材料:https://shuxc1688.taobao.com/
风岭2011 当前离线
旧 2014-02-22, 22:22   只看该作者   #9
旋風 的头像
旋風 旋風 当前离线
Uid: 85434
感谢: 613
521 个帖子获得 881 次感谢
现金: 5703金币
资产: 25703金币
声望: 18 旋風 向着好的方向发展
旋風 旋風 当前离线
旋風 的头像
Uid: 85434
感谢: 613
521 个帖子获得 881 次感谢
现金: 5703金币
资产: 25703金币
声望: 18 旋風 向着好的方向发展
作者: 风岭2011 查看帖子
下载速度不慢呀!
挺慢的20M光纤下载速度才80多K,下了一个多小时还没下好。晕死
旋風 当前离线
旧 2014-02-22, 22:42   只看该作者   #10
wzx0216 的头像
wzx0216 wzx0216 当前离线
级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时级别:71 | 在线时长:5455小时 | 升级还需:17小时
Uid: 224744
注册日期: 2011-05-05, 09:46
感谢: 30
92 个帖子获得 107 次感谢
现金: 7金币
资产: 7金币
声望: 10 wzx0216 向着好的方向发展
wzx0216 的头像
Uid: 224744
感谢: 30
92 个帖子获得 107 次感谢
现金: 7金币
资产: 7金币
作者: 风岭2011 查看帖子
下载速度不慢呀!
我下载一天都没有下载完,就差几十兆了,又突然从零开始下
wzx0216 当前离线
旧 2014-02-23, 10:32   只看该作者   #11
corkcork corkcork 当前离线
级别:4 | 在线时长:37小时 | 升级还需:8小时
Uid: 347858
注册日期: 2013-05-31, 15:45
来自: ewr
声望: 10 corkcork 向着好的方向发展
Uid: 347858
来自: ewr
我下的好慢,有人分享网盘了吗?
corkcork 当前离线
旧 2014-02-24, 12:22   只看该作者   #12
wzx0216 的头像
Uid: 224744
感谢: 30
92 个帖子获得 107 次感谢
现金: 7金币
资产: 7金币
wzx0216 的头像
Uid: 224744
感谢: 30
92 个帖子获得 107 次感谢
现金: 7金币
资产: 7金币
今天终于下载了,发布一下网盘有需要没有。http://yunpan.cn/Q4VyHAddFghTm 访问密码 50cc
wzx0216 当前离线
右列会员因为此帖价值甚高向 wzx0216 表示感谢:
12111121212 (2014-02-24)
旧 2014-02-24, 13:09   只看该作者   #13
chentype chentype 当前离线
帅哥 级别:19 | 在线时长:449小时 | 升级还需:31小时级别:19 | 在线时长:449小时 | 升级还需:31小时级别:19 | 在线时长:449小时 | 升级还需:31小时级别:19 | 在线时长:449小时 | 升级还需:31小时
Uid: 248
注册日期: 2004-05-30, 20:49
7 个帖子获得 7 次感谢
资产: 25金币
声望: 10 chentype 向着好的方向发展
Uid: 248
7 个帖子获得 7 次感谢
资产: 25金币
更新的好快,下来试一试吧……。
chentype 当前离线
旧 2014-02-24, 17:02   只看该作者   #14
Gprint Gprint 当前离线
帅哥 级别:19 | 在线时长:459小时 | 升级还需:21小时级别:19 | 在线时长:459小时 | 升级还需:21小时级别:19 | 在线时长:459小时 | 升级还需:21小时级别:19 | 在线时长:459小时 | 升级还需:21小时
Uid: 313465
注册日期: 2012-08-25, 13:24
来自: DG
感谢: 16
5 个帖子获得 5 次感谢
声望: 10 Gprint 向着好的方向发展
Gprint Gprint 当前离线
Uid: 313465
来自: DG
感谢: 16
5 个帖子获得 5 次感谢
2.0的狗能用得上吗?
Gprint 当前离线
旧 2014-02-24, 18:03   只看该作者   #15
印刷交流 的头像
印刷交流 印刷交流 当前离线
级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时级别:113 | 在线时长:13240小时 | 升级还需:212小时
Uid: 183192
注册日期: 2010-09-05, 16:06
感谢: 430
342 个帖子获得 586 次感谢
现金: 1264金币
资产: 1264金币
声望: 10 印刷交流 向着好的方向发展
印刷交流 印刷交流 当前离线
印刷交流 的头像
Uid: 183192
感谢: 430
342 个帖子获得 586 次感谢
现金: 1264金币
资产: 1264金币
还是上传到百度下载方便链接:http://pan.baidu.com/s/1mgqeOu0 密码:5kiz
印刷交流 当前离线
右列 5 位会员因为此帖价值甚高向 印刷交流 表示感谢:
2008.asp (2014-03-07), boya (2014-02-24), shyanjl (2014-02-24), xiaolinjob (2014-03-08), 依然印刷系 (2014-02-27)
所有时间均为 +8, 现在的时间是 2025-01-01 15:42.
