旧 2014-12-17, 13:19     #1
CXBSTWKY CXBSTWKY 当前离线
Uid: 429867
注册日期: 2014-10-26, 19:11
声望: 10 CXBSTWKY 向着好的方向发展
Uid: 429867
酷 求救施乐高手,风神1100卡纸
施乐风神1100卡纸老是报077-111代码,我的天,这是风神吗,简直是疯神好了,开这么多年的店,从没见过比这还卡纸的机器了,有时候印个几千张一张都不卡,要卡就是要几张就卡,要么一张的过不了,卡纸代码是077-111,要疯了,哪位大侠碰到过这问题没啊
CXBSTWKY 当前离线
旧 2014-12-20, 11:46   只看该作者   #2
封江 封江 当前离线
帅哥 级别:56 | 在线时长:3425小时 | 升级还需:52小时级别:56 | 在线时长:3425小时 | 升级还需:52小时级别:56 | 在线时长:3425小时 | 升级还需:52小时级别:56 | 在线时长:3425小时 | 升级还需:52小时级别:56 | 在线时长:3425小时 | 升级还需:52小时
Uid: 258470
注册日期: 2011-10-14, 15:35
来自: 温州
感谢: 56
88 个帖子获得 105 次感谢
现金: 513金币
资产: 513金币
声望: 10 封江 向着好的方向发展
封江 封江 当前离线
Uid: 258470
来自: 温州
感谢: 56
88 个帖子获得 105 次感谢
现金: 513金币
资产: 513金币
声望: 10 封江 向着好的方向发展
077-111 IOT Exit Sensor ON Jam (Invert)
BSD-ON:CH10.10
In Invert Output Mode, IOT Exit Sensor does not turn ON in a spec time.
DC330 Code to Check
• [077-108] IOT Exit Sensor
• [077-013] Invert Motor
• [077-202] Invert Release Home Sensor
• [077-016] Release Motor
• [077-010] Exit Motor
Check Items
• Paper Path for a foreign object/burr/piece of paper
• Invert In Roll for dirt/paper particles/wear/a poor rotation
• Invert Roll for dirt/paper particles/wear/a poor rotation
• Drive gears for wear/breakage
• Check for out-of-spec paper.
• Drawer Connectors P/J608 contact points for foreign objects/bent pins/burnout
• Check the wire-wound resistance of Exit Motor is approx. 2.6 ohms at the measurement points
below.
– P222-2 pin to pins 1/3
– P222-5 pin to pins 4/6
• Check the wire-wound resistance of Invert Motor is approx. 2.6 ohms at the measurement points
below.
– P221-2 pin to pins 1/3
– P221-5 pin to pins 4/6
• Check the wire-wound resistance of Release Motor is approx. 10 ohms at the measurement points
below.
– P224-2 pin to pins 1/3
– P224-5 pin to pins 4/6
• Check the following for an open wire or poor contact:
– IOT Exit Sensor J111-2 to IOT PWB J438-A8
– IOT Exit Sensor J111-1 to IOT PWB J438-A9
– IOT Exit Sensor J111-3 to IOT PWB J438-A7
If the above wires are good, replace IOT Exit Sensor (PL 16.2) and Flexible Print Cable (PL 2.1) in
order.
• If the results of the above checks are OK, replace IOT PWB (PL 2.1) and MCU PWB (PL 2.1) in
order.
封江 当前离线
旧 2014-12-20, 11:47   只看该作者   #3
封江 封江 当前离线
Uid: 258470
来自: 温州
感谢: 56
88 个帖子获得 105 次感谢
现金: 513金币
资产: 513金币
声望: 10 封江 向着好的方向发展
封江 封江 当前离线
Uid: 258470
来自: 温州
感谢: 56
88 个帖子获得 105 次感谢
现金: 513金币
资产: 513金币
声望: 10 封江 向着好的方向发展
代码表是这样,海贼版主说的对呀,风神风神,如疯如神,用过的人都知道
封江 当前离线
旧 2014-12-20, 21:02   只看该作者   #4
Uid: 429867
Uid: 429867
这东东看不明白呢,有没有中文的啊
CXBSTWKY 当前离线
旧 2014-12-20, 22:05   只看该作者   #5
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
作者: CXBSTWKY 查看帖子
这东东看不明白呢,有没有中文的啊
自己查查金山词霸吧
balenofeng 当前离线
所有时间均为 +8, 现在的时间是 2025-12-09 09:33.
