旧 2016-01-02, 16:31     #1
hrj7889 hrj7889 当前离线
级别:27 | 在线时长:892小时 | 升级还需:4小时级别:27 | 在线时长:892小时 | 升级还需:4小时级别:27 | 在线时长:892小时 | 升级还需:4小时级别:27 | 在线时长:892小时 | 升级还需:4小时级别:27 | 在线时长:892小时 | 升级还需:4小时级别:27 | 在线时长:892小时 | 升级还需:4小时
Uid: 240501
注册日期: 2011-07-18, 21:12
现金: 304金币
资产: 304金币
声望: 10 hrj7889 向着好的方向发展
Uid: 240501
现金: 304金币
资产: 304金币
默认 施乐小风神走输稿器错误,不能用,打印。稿台正常。
文件类型: jpg QQ图片20160102163150.jpg (128.9 KB, 6 次查看)
hrj7889 当前离线
旧 2016-01-03, 23:04   只看该作者   #2
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
作者: hrj7889 查看帖子
给你参考一下吧,段落太长了,你自己翻译吧
065-221 (DADF-150) CIS AGC Fail (DC Models)
Bsd-on: CH5.8
AGC (Automatic Gain Control) of CIS processing is not completed/resolved. Or, the white level does not reach the specified value.
Procedure
1. Enter Diag Mode and check the value of DC131 NVM[716-579] and [716-589]. Based on the displayed values, proceed with the following steps. When there is no failure, "0" is displayed.
When [716-579] is 1 or [716-589] is 1.
2. Turn OFF the power. Disconnect and reconnect the 1P Dup PWB cable J740/ J745 and tighten the screws securely.
3. If it is "NG" at 2, reconnect the FPC between the CIS J1 and the CIS DC/DC Convert PWB J746 properly.
4. If it is "NG" at 3, pull out the IIT Carriage and reconnect the FPC between the 1P Dup PWB J7421 and the IIT/IPS PWB J7401 properly.
Take note of the top and bottom of the FPC.
5. If it is "NG" at 4, enter the Diag Mode. If any of the values in NVM[716-540~547] is not within 20~45, change the values to "31" and turn the power OFF and ON.
6. If the problem persists, replace the following components in sequence:
(1) CIS (PL 52.2 )
(2) CIS DC/DC Convert PWB (PL 52.3 )
(3) 1P Dup PWB (PL 1.16 )
(4) IIT/IPS-1P Dup PWB Cable (PL 1.16), DC/DC Convert PWB-1P Dup PWB Cable (PL 52.1), CIS-CIS DC/DC Convert PWB Cable (PL 52.3)
(5) IIT/IPS PWB (PL 1.16)
When [716-579] is 2 or the [716-589] is 2.
3. If it is "NG" at 2, enter the Diag Mode. If any of the values in NVM[716-540~547] is not within 20~45, change the values to "31" and turn the power OFF and ON.
4. When it is "NG" at 3, record down the values of NVM[716-523~528] and replace the CIS. (PL 52.2)
5. If any of the values in NVM[716-540~547] is not within 20~45, change the value of NVM[716-600] to "0" and turn the power OFF and ON.
6. If the value in NVM[716-579] is "2", check the connections of the IIT/IPS-1P Dup PWB Cable (PL 1.16), DC/DC Convert PWB-1P Dup PWB Cable (PL 52.1), and CIS-CIS DC/DC Convert PWB Cable (PL 52.3).
7. If the value in NVM[716-579] is other than "2", record down the values of NVM[716-523~528] and replace the CIS. (PL 52.2)
8. If the problem persists, replace the 1P Dup PWB (PL 52.1), followed by the IIT /IPS PWB (PL 1.16).
balenofeng 当前离线
旧 2016-01-04, 07:56   只看该作者   #3
Uid: 240501
现金: 304金币
资产: 304金币
Uid: 240501
现金: 304金币
资产: 304金币
作者: balenofeng 查看帖子
Bsd-on: CH5.8
Procedure
1. Enter Diag Mode and check the value of DC131 NVM[716-579] and [716-589]....
非常感谢!!!!!!!!!!!!
hrj7889 当前离线
旧 2016-01-14, 23:12   只看该作者   #4
单车男孩婵 的头像
单车男孩婵 单车男孩婵 当前离线
级别:21 | 在线时长:567小时 | 升级还需:5小时级别:21 | 在线时长:567小时 | 升级还需:5小时级别:21 | 在线时长:567小时 | 升级还需:5小时
Uid: 409327
注册日期: 2014-06-14, 19:45
感谢: 170
49 个帖子获得 57 次感谢
现金: 382金币
资产: 382金币
声望: 10 单车男孩婵 向着好的方向发展
单车男孩婵 单车男孩婵 当前离线
单车男孩婵 的头像
Uid: 409327
感谢: 170
49 个帖子获得 57 次感谢
现金: 382金币
资产: 382金币
作者: hrj7889 查看帖子
065-221(DADF-150) CIS AGC Fail(DC机种) [IMG]file:///C:/Edoc/images/memo.gif[/IMG] [IMG]file:///C:/Edoc/images/topicback.gif[/IMG]
参考:CH5.8
说明
CIS的AGC(自动Gain调整)处理不结束。或白色水平未达到规定值。
步骤
  • <LI id=svc.ap7000_sc.0007463543>1. 进入诊断,检查DC131 NVM[716-579]及[716-589]的值。根据显示的值,进入以下步骤。若未发生故障,则显示为“0”。
    <LI id=svc.ap7000_sc.0007463546>[716-579]=1或[716-589]=1时
    <LI id=svc.ap7000_sc.0007463548>2. 关闭电源,拔出/插入1P Dup PWB的电缆 J740/ J745,重新锁紧Screw。
    <LI id=svc.ap7000_sc.0007463552>3. 2为NG时,正确重新连接CIS J1和CIS DC/DC Convert PWB J746之间的FPC。
    <LI id=svc.ap7000_sc.0007463556>4. 3为NG时,拉出IIT Chassis,正确重新连接1P Dup PWB J7421和IIT/IPS PWB J7401之间的FPC。
    注释
    注意FPC的正反。
    <LI id=svc.ap7000_sc.0007463562>5. 4为NG时,进入诊断,若NVM[716-540~547]的其中一个值为20~45以外,则将NVM[716-540~547]的值全部输入“31”,关闭/打开电源。
    <LI id=svc.ap7000_sc.0007463564>6. 若无法修复,则按以下顺序更换零件。
    • <LI id=svc.ap7000_sc.0007463567>(1)CIS(PL 52.2 )
      <LI id=svc.ap7000_sc.0007463570>(2)CIS DC/DC Convert PWB(PL 52.3 )
      <LI id=svc.ap7000_sc.0007463573>(3)1P Dup PWB(PL 1.16 )
      <LI id=svc.ap7000_sc.0007463576>(4)IIT/IPS-1P Dup PWB Cable(PL 1.16)、DC/DC Convert PWB-1P Dup PWB Cable(PL 52.1)、CIS-CIS DC/DC Convert PWB Cable(PL 52.3 )
    • (5)IIT/IPS PWB(PL 1.16 )
    <LI id=svc.ap7000_sc.0007463585>[716-579]=2或[716-589]=2时
    <LI id=svc.ap7000_sc.0007463587>2. 关闭电源,拔出/插入1P Dup PWB的电缆 J740/ J745,重新锁紧Screw。
    <LI id=svc.ap7000_sc.0007463591>3. 2为NG时,进入诊断,若NVM[716-540~547]的其中一个值为20~45以外,则将NVM[716-540~547]的值全部输入“31”,关闭/打开电源。
    <LI id=svc.ap7000_sc.0007463593>4. 3为NG时,记录NVM[716-523~528]的值,更换CIS。(PL 52.2)
    <LI id=svc.ap7000_sc.0007463596>5. NVM[716-540~547]的其中一个值为20~45时,在NVM[716-600]写入“0”,关闭/打开电源。
    <LI id=svc.ap7000_sc.0007463598>6. 若NVM[716-579]的值是“2”,则检查 IIT/IPS-1P Dup PWB Cable(PL 1.16)、DC/DC Convert PWB-1P Dup PWB Cable(PL 52.1)、CIS-CIS DC/DC Convert PWB Cable(PL 52.3)的连接。
    <LI id=svc.ap7000_sc.0007463603>7. 若NVM[716-579]的值为其它,则记录NVM[716-523~528]的值,更换CIS。(PL 52.2)
  • 8. 若无法修复,则依序更换1P Dup PWB(PL 52.1)、IIT/IPS PWB(PL 1.16)。
单车男孩婵 当前离线
所有时间均为 +8, 现在的时间是 2025-12-04 11:12.
