2016-01-05, 11:17 | #1 | ||
2、支持13种条码生成、可以生成EAN8\EAN13\EAN128\UPC-A\UPC-E\CODE 39\CODE 93\CODE 128\CODE 128A\CODE 128B\CODE 128C\ITF 14\ITF 25条形码脚本。 3、支持扩大比例:0.8-2.0倍。小于或大于将于100%显示。 4、支持高度:5-50mm范围内调整。小于或大于将于默认高度。 5、支持宽度比例:2、2.5、3条码比率。 6、支持添加上下边的黑色外框。 7、支持动态条码生成----首先ai要有选择对象(如:首先选择好一个距形) 8、支持自动关闭窗口、方便批量生成条码。 9、温馨提示:如没有必要尽量使用默认制作条码、在进行二次修改。 |
回复时引用此帖 |
右列 93 位会员因为此帖价值甚高向 zyyclove 表示感谢: |
007-gigi (2017-08-12),
13055505598 (2017-01-10),
13669806735 (2016-10-24),
1515390048 (2016-06-03),
234228715 (2018-02-08),
2b king andy (2017-01-11),
502254289 (2017-06-22),
584498588 (2016-01-05),
73729h (2016-01-13),
A-J (2016-01-05),
abcab (2016-10-30),
amin1974 (2016-01-05),
b305 (2017-09-01),
baggio3230 (2016-01-29),
bjtyh2008 (2016-01-06),
BO8100 (2016-01-05),
cmmac (2016-01-06),
CPC中文印刷 (2017-09-12),
ctp静 (2023-10-21),
dotsec (2016-08-29),
duanfeiping (2022-12-31),
Fi_ (2019-09-10),
foxgou (2017-09-12),
GC007 (2016-09-02),
guojianfeg (2016-04-25),
hanksh1976 (2018-12-01),
hjhisbest (2016-05-13),
huangsijun17 (2017-11-16),
huchqi520 (2020-03-27),
igotit (2023-01-16),
inderten (2020-12-07),
itubay (2016-01-06),
jayanto284 (2020-08-03),
jianzike (2016-10-22),
kinrei518 (2016-01-05),
LH03 (2016-12-31),
lijunzhou (2017-11-27),
lkw200000 (2016-02-16),
loveon126 (2020-11-04),
luxuexia (2016-05-12),
m_enguang (2016-01-05),
mlz06 (2016-01-05),
nickwang (2016-01-20),
py.brandon (2017-03-04),
REM1X (2017-07-23),
Rich (2017-06-13),
river1010 (2016-01-05),
rpe12456 (2017-05-10),
sxan8249 (2019-10-30),
tiantian1998 (2022-01-22),
tonk (2020-09-01),
tzm1018 (2016-01-05),
vfoggp (2016-02-27),
vsayang (2020-03-28),
w2017 (2023-05-08),
wangyu1314 (2016-01-05),
wawds (2018-05-07),
wengmeixian (2016-07-21),
xcj_xu (2016-01-05),
xiaochunpan (2017-06-12),
xiaohaiwu (2016-01-07),
xingyi (2018-03-03),
xinjie66 (2021-03-29),
xixikiller (2016-03-28),
xmt67xmt (2016-03-31),
yshasha (2020-10-28),
yuyang1683 (2019-01-27),
zdjyang (2022-04-29),
zhizun99 (2016-01-29),
zqflive (2016-12-03),
zwc8201 (2016-01-05),
傲气江南 (2019-06-04),
力量源自分享 (2020-10-03),
大乖猫 (2017-06-02),
天高凯旋 (2016-09-06),
战神重现 (2018-07-02),
房上草 (2016-01-05),
新人一枚 (2018-11-17),
木棉树下 (2017-10-19),
海燕宫爆鸡丁 (2020-05-14),
深山太保 (2016-10-21),
火星来客 (2016-01-05),
牧人 (2019-08-13),
给力未来 (2018-05-10),
编号9527 (2017-03-14),
苏澈 (2020-02-29),
野小葵0 (2018-09-06),
金帛 (2016-01-15),
雲洲大儒俠 (2019-10-30),
風輕雲澹 (2016-08-24),
飞翔 (2017-08-05),
骑着羊打狼 (2016-01-06),
龙海骑士 (2017-04-24)
2016-01-06, 19:14 | 只看该作者 #13 | |||
能让面板不用退出吗,就是说可以继续打其它的条码,不影响做其它的事,不用重新载入,像其它人做的面板脚本一样的停在一边。 此帖于 2016-01-06 19:32 被 lou 编辑. |
回复时引用此帖 |
2016-01-06, 20:05 | 只看该作者 #14 | ||
#target illustrator #targetengine com.adobe.illustrator.demo.flashplayer 主窗口= new Window('palette','自己集成的');//也可以把大小写在这边 主窗口.bounds = [0,0,200,120];//窗口大小 按钮_条形码生成 = 主窗口.add("button",[10,20,190,50], "条形码生成"); 按钮_计量矩形标注 = 主窗口.add("button",[10,70,190,100], "计量矩形标注"); function 执行脚本(脚本_内容) { var 脚本_执行 = new BridgeTalk; 脚本_执行.target = "illustrator"; 脚本_执行.body = 脚本_内容; 脚本_执行.send() } 按钮_条形码生成.onClick=function(){ //网上的下载的脚本,用记事本打开,在每行尾加上\这个符号,最后一行不用加的。然后复制全部内容到---脚本内容---变量里就可了。如:计量矩形标注那样的。 var 脚本_内容=" "; 执行脚本(脚本_内容); }; 按钮_计量矩形标注.onClick=function(){ var 脚本_内容="@JSXBIN@ES@2.0@MyBbyBn0ADJAnABjzDjEjPjDBfXzOjBjDjUjJjWjFiEjPjDjVjNjFjOjUCfjzDjBj\ QjQDfnfJBnABjzJjUjIjFiTjFjMjFjDjUEfXzJjTjFjMjFjDjUjJjPjOFfjBfnfaCbDn0AhQJDnABjz\ BjYGfXzEjMjFjGjUHfQzAIfjEfjzBjJJfnfJEnABjzBjZKfXzDjUjPjQLfQIfjEfjJfnfJFnABjzBjX\ MfXzFjXjJjEjUjINfQIfjEfjJfnfJGnABjzBjIOfXzGjIjFjJjHjIjUPfQIfjEfjJfnfJHnABjzBjTQ\ fnd8XkLmFjClRiYhciAfJInASzCjNjNRyBnd8hbmAnWiAnJkTmWhfftJJnABjzFjBjTjJjajFSfndUf\ JKnABjzFjUjTjJjajFTfndSfOLbMn0ADJMnABjSfndKfJNnABjTfndIfJOnABjQfnd8XkLmFjClRiYh\ MiAfAUzCjcjcUCzBhcVjOfnnd8iJhESkJiEhCiTiACVjMfnnd8iJhESkJiEhCiTiAnnnJQnABjzIjSj\ FjEiDjPjMjPjSWfEjzJiDiNiZiLiDjPjMjPjSXfntnfJRnABXzEjDjZjBjOYfjWfndAfJSnABXzHjNj\ BjHjFjOjUjBZfjWfndAfJTnABXzGjZjFjMjMjPjXgafjWfndAfJUnABXzFjCjMjBjDjLgbfjWfndjEf\ JVnASzCjHhRgcyBEXzDjBjEjEgdfXzKjHjSjPjVjQiJjUjFjNjTgefjBfnfnftJWnASzFjMjJjOjFhR\ gfyBEXgdfXzJjQjBjUjIiJjUjFjNjThAfVgcfyBnfnftJXnAEXzNjTjFjUiFjOjUjJjSjFiQjBjUjIh\ BfVgffyBRBEjzFiBjSjSjBjZhCfRCEjhCfRCCzBhLhDChDjGfjMfnnjQfnnjKfftEjhCfRCChDChDjG\ fjMfnnjQfnnCzBhNhEjKfjOfnnftftffJgcnABXzLjTjUjSjPjLjFiDjPjMjPjShFfVgffyBjWfnfJg\ dnASgfyBEXgdfXhAfVgcfyBnfnftJgenAEXhBfVgffyBRBEjhCfRCEjhCfRCChDChDChDjGfjMfnnjQ\ fnnCzBhPhGjQfnndCnnjKfftEjhCfRCChDChDjGfjMfnnChGjQfnndCnnjKfftftffJhDnABXhFfVgf\ fyBjWfnfJhEnASgfyBEXgdfXhAfVgcfyBnfnftJhFnAEXhBfVgffyBRBEjhCfRCEjhCfRCChDChDChD\ jGfjMfnnjQfnnChGjQfnndCnnChEjKfjOfnnftEjhCfRCChDChDjGfjMfnnChGjQfnndCnnChEjKfjO\ fnnftftffJhKnABXhFfVgffyBjWfnfJiCnASzCjUhRhHyBEXgdfXzKjUjFjYjUiGjSjBjNjFjThIfVg\ cfyBnfnftJiDnABXzIjDjPjOjUjFjOjUjThJfVhHfyBChDEXzFjSjPjVjOjEhKfjzEiNjBjUjIhLfRB\ CzBhKhMjOfnnd8hbmAnWiAnJkTmWhfffnneDhAjNjNnfJiEnABXzEjTjJjajFhNfXzTjDjIjBjSjBjD\ jUjFjSiBjUjUjSjJjCjVjUjFjThOfXzJjUjFjYjUiSjBjOjHjFhPfVhHfyBjTfnfJiFnABXzJjGjJjM\ jMiDjPjMjPjShQfXhOfXhPfVhHfyBjWfnfJiGnABXzIjUjFjYjUiGjPjOjUhRfXhOfXhPfVhHfyBEXz\ JjHjFjUiCjZiOjBjNjFhSfjzJjUjFjYjUiGjPjOjUjThTfRBFeOiNjJjDjSjPjTjPjGjUiZjBiIjFjJ\ ffnfJiHnAEXzGjSjPjUjBjUjFhUfVhHfyBRBFdyiaffJiInABXHfVhHfyBChEChDChDjGfjMfnnChMn\ jQfdCnnnXNfVhHfyBnnnfJiJnABXLfVhHfyBChDChEjKfChGjOfnndCnnChGXPfVhHfyBnndCnnnfJi\ LnASzFjMjJjOjFhShVyBEXgdfXhAfVgcfyBnfnftJiMnAEXhBfVhVfyBRBEjhCfRCEjhCfRCjGfChDj\ KfjQfnnftEjhCfRCChDjGfjMfnnChDjKfjQfnnftftffJiRnABXhFfVhVfyBjWfnfJiSnAShVyBEXgd\ fXhAfVgcfyBnfnftJiTnAEXhBfVhVfyBRBEjhCfRCEjhCfRCjGfChDChDjKfjQfnnChGjQfnndCnnft\ EjhCfRCjGfChDjKfChGjQfnndCnnftftffJiYnABXhFfVhVfyBjWfnfJiZnAShVyBEXgdfXhAfVgcfy\ BnfnftJianAEXhBfVhVfyBRBEjhCfRCEjhCfRCChDjGfjMfnnChDChDjKfjQfnnChGjQfnndCnnftEj\ hCfRCChDjGfjMfnnChDjKfChGjQfnndCnnftftffJifnABXhFfVhVfyBjWfnfJjXnASzCjUhShWyBEX\ gdfXhIfVgcfyBnfnftJjYnABXhJfVhWfyBChDEXhKfjhLfRBChMjMfnnd8hbmAnWiAnJkTmWhfffnne\ DhAjNjNnfJjZnABXhNfXhOfXhPfVhWfyBjTfnfJjanABXhQfXhOfXhPfVhWfyBjWfnfJjbnABXhRfXh\ OfXhPfVhWfyBEXhSfjhTfRBFeOiNjJjDjSjPjTjPjGjUiZjBiIjFjJffnfJjcnABXHfVhWfyBChEChD\ jGfChGjMfnndCnnChGXNfVhWfyBnndCnnnfJjdnABXLfVhWfyBChDjKfChMnjQfdCnnnnfAjJfAXzGj\ MjFjOjHjUjIhXfjEfByBVAGR40BiAgc4B0AiAhH4D0AiAgf4C0AiAhV4E0AiAhW4F0AiAAGAIByB"; 执行命令(脚本_内容); }; 主窗口.center() 主窗口.show(); |
回复时引用此帖 |
2016-01-06, 20:12 | 只看该作者 #15 | |||
之前那个CS4还能行,这个改后CS4怎么不能运行呢! 此帖于 2016-01-06 20:43 被 lou 编辑. |
回复时引用此帖 |
