旧 2016-01-13, 16:51     #1
鱼儿爱上猫 鱼儿爱上猫 当前离线
帅哥 级别:3 | 在线时长:26小时 | 升级还需:6小时级别:3 | 在线时长:26小时 | 升级还需:6小时级别:3 | 在线时长:26小时 | 升级还需:6小时
Uid: 417322
注册日期: 2014-08-02, 17:26
声望: 10 鱼儿爱上猫 向着好的方向发展
鱼儿爱上猫 鱼儿爱上猫 当前离线
Uid: 417322
默认 施乐4112卡纸,代码是077-111
施乐4112卡纸,有时候几张就卡,有的时候1、2千张都没事,每次的卡纸代码都是077-111,请问是哪里的问题?
鱼儿爱上猫 当前离线
旧 2016-01-13, 17:29   只看该作者   #2
balenofeng 的头像
balenofeng balenofeng 当前离线
Uid: 80820
注册日期: 2008-12-15, 12:18
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
声望: 10 balenofeng 向着好的方向发展
balenofeng 的头像
Uid: 80820
来自: 大中华
感谢: 18
107 个帖子获得 122 次感谢
现金: 508金币
资产: 508金币
作者: 鱼儿爱上猫 查看帖子
077-111 IOT Exit Sensor ON Jam (Invert)
Bsd-on:CH10.10
In Invert Output Mode, IOT Exit Sensor does not turn ON in a spec time.
DC330 Code to Check
[077-108] IOT Exit Sensor
[077-013] Invert Motor
[077-202] Invert Release Home Sensor
[077-016] Release Motor
[077-010] Exit Motor
Check Items
Paper Path for a foreign object/burr/piece of paper
Invert In Roll for dirt/paper particles/wear/a poor rotation
Invert Roll for dirt/paper particles/wear/a poor rotation
Drive gears for wear/breakage
Check for out-of-spec paper.
Drawer Connectors P/J608 contact points for foreign objects/bent pins/burnout
Check the wire-wound resistance of Exit Motor is approx. 2.6 ohms at the measurement points below.
P222-2 pin to pins 1/3
P222-5 pin to pins 4/6
Check the wire-wound resistance of Invert Motor is approx. 2.6 ohms at the measurement points below.
P221-2 pin to pins 1/3
P221-5 pin to pins 4/6
Check the wire-wound resistance of Release Motor is approx. 10 ohms at the measurement points below.
P224-2 pin to pins 1/3
P224-5 pin to pins 4/6
Check the following for an open wire or poor contact:
IOT Exit Sensor J111-2 to IOT PWB J438-A8
IOT Exit Sensor J111-1 to IOT PWB J438-A9
IOT Exit Sensor J111-3 to IOT PWB J438-A7
If the above wires are good, replace IOT Exit Sensor (PL 16.2) and Flexible Print Cable (PL 2.1) in order.
If the results of the above checks are OK, replace IOT PWB (PL 2.1) and MCU PWB (PL 2.1) in order.
balenofeng 当前离线
所有时间均为 +8, 现在的时间是 2025-12-02 13:12.
