2016-02-19, 21:51 | #1 | |||
已和谐注册及水印 安装程序→复制和谐补丁覆盖原文件 即可! [隐藏内容]:
此帖于 2016-02-24 16:53 被 wangyu1314 编辑. |
右列 17 位会员因为此帖价值甚高向 superabbite 表示感谢: |
200726892 (2017-09-12),
baren123 (2019-06-27),
DuoKe (2016-02-19),
ggyy520258 (2017-10-13),
hnowj (2017-12-06),
itubay (2016-02-19),
kim l (2018-11-05),
lanyu9527 (2017-07-28),
likeyi492 (2019-04-30),
univers (2017-05-05),
wingqian (2018-09-30),
Xne (2017-09-26),
yougetsle (2020-09-06),
zlj20 (2017-05-19),
zqflive (2016-02-21),
金帛 (2016-03-04),
龙生初九 (2017-07-08)
2016-05-17, 17:07 | 只看该作者 #13 | ||
DUN-14(Distribution Unit Number)不是一个真正意义上的条码类型。它是为使用集装箱使用其他条码符号的一种编码系统。DUN采用的条码类型为ITF 或者EAN 128,现在设施使用EAN 128条码类型。DUN-14条码可使用SmartVizor条码软件采用ITF 14或EAN 128条码类型制作。 以下为DUN-14英文介绍: DUN is not really a barcode type. It’s a Distribution Unit Number. However, it is frequently constructed from 12/13 digit retail barcode numbers, and uses a special check digit. DUN-14 numbers may be represented by ITF or EAN 128 barcode, and modern implementation should use EAN128. DUN-14 in EAN128 barcode form may be created by providing 13 digits (the Logisitcal Variant digit – normally 0 in the UK) followed by the first 12 of the retail digits (eg. from EAN-13 numbers but without EAN's check digit). The DUN check digit is then calculated and the barcode symbol produced using EAN128 symbology. |
