2006-06-10, 11:47 | #1 | ||
桃花仙人
颜色空间转换为JapanStandard(俺常用的,比较适合印前),保留专色,叠印黑色。 软件环境:ab7+Heidelberg.toolbox汉化版 1,打开prinect color edit 测试文件: 以后会常发相关贴,望大家支持! (下班咯!)
未经审视的生命不值一活。 此帖于 2006-06-10 11:55 被 jememouse 编辑. |
右列 4 位会员因为此帖价值甚高向 jememouse 表示感谢: |
2006-06-10, 11:50 | 只看该作者 #2 | ||
桃花仙人
Page is color controlled with Prinect Color Editor 2.0.36 Copyright 2004 Heidelberger Druckmaschinen AG To view actual document colors and color spaces, please download free Prinect Color Editor (Viewer) Plug-In from: http://www.heidelberg.com Applied Color Management Settings: Output Intent (Press Profile): JapanStandard.icc RGB Image: Profile: AdobeRGB1998.icc Rendering Intent: Perceptual Black Point Compensation: no RGB Graphic: Profile: AdobeRGB1998.icc Rendering Intent: Perceptual Black Point Compensation: no CMYK Image: Profile: Japan Standard v2.icc Rendering Intent: Perceptual Black Point Compensation: no Preserve Black: Special CMYK Graphic: Profile: Japan Standard v2.icc Rendering Intent: Perceptual Black Point Compensation: no Preserve Black: Special Device Independent Image: Rendering Intent: Perceptual Black Point Compensation: yes Device Independent Graphic: Rendering Intent: Perceptual Black Point Compensation: yes Turn R=G=B (Tolerance 0.5%) Graphic into Gray: yes CMM for overprinting CMYK graphic: yes Gray Image: Apply CMYK Profile: no Gray Graphic: Apply CMYK Profile: no Treat Calibrated RGB as Device RGB: no Treat Calibrated Gray as Device Gray: yes Remove embedded non-CMYK Profiles: no Remove embedded CMYK Profiles: yes Applied Miscellaneous Settings: All Colors to knockout: no Pure black to overprint: yes Limit: 95% Turn Overprint CMYK White to Knockout: yes Turn Overprinting Device Gray to K: no Enable Overprint in Device CMYK: no Create "All" from 4x100% CMYK: yes Delete "All" Colors: no Convert "All" to K: no 第一次发这种学习贴,不妥之处,请指出! (晕,我怎么不能在图片间插入文字!) 此帖于 2006-06-10 11:58 被 jememouse 编辑. |
右列会员因为此帖价值甚高向 jememouse 表示感谢: |
三木设计 (2020-07-22)
2006-06-10, 16:08 | 只看该作者 #3 | ||
P.S.受楼主启发.我解决了另一个问题:https://www.cnprint.org/bbs/showthre...685#post219009 这算不算打广告.哈哈.
love is an expensive shopwindow
I open my life,If i can find you, then I'll know how rich I am. |
