2017-03-31, 18:28 | #1 | ||
theSelect = doc.selection; //对已选择的物体进行标注 sizelayer=doc.layers.add(); //新建图层 sizelayer.name = '尺寸标注层'; //设置图层名称 for (i=0;i<theSelect.length;i++){ //批处理所有对象 x=theSelect[i].left; y=theSelect[i].top; w=theSelect[i].width; h=theSelect[i].height; s=30;//标尺距离物体边沿宽度 asize=10;//箭头大小 if(h<50 || w<50){asize=10;}//简单的自适应,太小的物体用小箭头 tsize=30; //标尺字体大小 redColor = new CMYKColor();//标尺用色 redColor.black = 80; redColor.cyan = 0; redColor.magenta =0; redColor.yellow = 0; var g1 = sizelayer.groupItems.add();//将标尺群组,将标注画在标注图层上。 var line1=g1.pathItems.add(); //画高度标尺 line1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s, y-h), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y), new Array(x-s/2, y), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y-h), new Array(x-s/2, y-h), ) ) ; line1.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s-asize/2,y-asize), new Array(x-s+asize/2,y-asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y-h), new Array(x-s-asize/2,y-h+asize), new Array(x-s+asize/2,y-h+asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t1 = g1.textFrames.add(); t1.contents = Math.round(h*0.35277778)+" mm"; //小数位四舍五入取整数 t1.textRange.characterAttributes.size=tsize; t1.textRange.characterAttributes.fillColor= redColor; t1.left = x-s-t1.width/1.2; t1.top = y-h/2+t1.height/2; t1.rotate(90); //文字旋转90度 var line2=g1.pathItems.add(); //画长度标尺 line2.setEntirePath( new Array( new Array(x, y-h-s), new Array(x+w, y-h-s), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x, y-h-s-s/2), new Array(x, y-h-s/2), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x+w, y-h-s-s/2), new Array(x+w, y-h-s/2), ) ) ; line2.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x,y-h-s), new Array(x+asize,y-h-s-asize/2), new Array(x+asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x+w,y-h-s), new Array(x+w-asize,y-h-s-asize/2), new Array(x+w-asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t2 = g1.textFrames.add(); t2.contents = Math.round(w*0.35277778)+" mm"; //小数位四舍五入取整数 t2.textRange.characterAttributes.size=tsize; t2.textRange.characterAttributes.fillColor= redColor; t2.left = x+w/2-t2.width/2; t2.top = y-h-s*1.2; } |
2017-04-01, 16:13 | 只看该作者 #3 | ||
标注在下 doc = app.activeDocument; //在当前文件进行操作 theSelect = doc.selection; //对已选择的物体进行标注 sizelayer=doc.layers.add(); //新建图层 sizelayer.name = '尺寸标注层'; //设置图层名称 for (i=0;i<theSelect.length;i++){ //批处理所有对象 x=theSelect[i].left; y=theSelect[i].top; w=theSelect[i].width; h=theSelect[i].height; s=30;//标尺距离物体边沿宽度 asize=10;//箭头大小 if(h<50 || w<50){asize=10;}//简单的自适应,太小的物体用小箭头 tsize=30; //标尺字体大小 redColor = new CMYKColor();//标尺用色 redColor.black = 80; redColor.cyan = 0; redColor.magenta =0; redColor.yellow = 0; var g1 = sizelayer.groupItems.add();//将标尺群组,将标注画在标注图层上。 /* var line1=g1.pathItems.add(); //画高度标尺 line1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s, y-h), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y), new Array(x-s/2, y), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y-h), new Array(x-s/2, y-h), ) ) ; line1.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s-asize/2,y-asize), new Array(x-s+asize/2,y-asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y-h), new Array(x-s-asize/2,y-h+asize), new Array(x-s+asize/2,y-h+asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t1 = g1.textFrames.add(); t1.contents = Math.round(h*0.35277778)+" mm"; //小数位四舍五入取整数 t1.textRange.characterAttributes.size=tsize; t1.textRange.characterAttributes.fillColor= redColor; t1.left = x-s-t1.width/1.2; t1.top = y-h/2+t1.height/2; t1.rotate(90); //文字旋转90度 */ var line2=g1.pathItems.add(); //画长度标尺 line2.setEntirePath( new Array( new Array(x, y-h-s), new Array(x+w, y-h-s), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x, y-h-s-s/2), new Array(x, y-h-s/2), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x+w, y-h-s-s/2), new Array(x+w, y-h-s/2), ) ) ; line2.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x,y-h-s), new Array(x+asize,y-h-s-asize/2), new Array(x+asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x+w,y-h-s), new Array(x+w-asize,y-h-s-asize/2), new Array(x+w-asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t2 = g1.textFrames.add(); t2.contents = Math.round(w*0.35277778)+" mm"; //小数位四舍五入取整数 t2.textRange.characterAttributes.size=tsize; t2.textRange.characterAttributes.fillColor= redColor; t2.left = x+w/2-t2.width/2; t2.top = y-h-s*1.2; } 标注在左 doc = app.activeDocument; //在当前文件进行操作 theSelect = doc.selection; //对已选择的物体进行标注 sizelayer=doc.layers.add(); //新建图层 sizelayer.name = '尺寸标注层'; //设置图层名称 for (i=0;i<theSelect.length;i++){ //批处理所有对象 x=theSelect[i].left; y=theSelect[i].top; w=theSelect[i].width; h=theSelect[i].height; s=30;//标尺距离物体边沿宽度 asize=10;//箭头大小 if(h<50 || w<50){asize=10;}//简单的自适应,太小的物体用小箭头 tsize=30; //标尺字体大小 redColor = new CMYKColor();//标尺用色 redColor.black = 80; redColor.cyan = 0; redColor.magenta =0; redColor.yellow = 0; var g1 = sizelayer.groupItems.add();//将标尺群组,将标注画在标注图层上。 var line1=g1.pathItems.add(); //画高度标尺 line1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s, y-h), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y), new Array(x-s/2, y), ) ) ; line1.strokeColor= redColor; var line1=g1.pathItems.add(); line1.setEntirePath( new Array( new Array(x-s-s/2, y-h), new Array(x-s/2, y-h), ) ) ; line1.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y), new Array(x-s-asize/2,y-asize), new Array(x-s+asize/2,y-asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x-s, y-h), new Array(x-s-asize/2,y-h+asize), new Array(x-s+asize/2,y-h+asize), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t1 = g1.textFrames.add(); t1.contents = Math.round(h*0.35277778)+" mm"; //小数位四舍五入取整数 t1.textRange.characterAttributes.size=tsize; t1.textRange.characterAttributes.fillColor= redColor; t1.left = x-s-t1.width/1.2; t1.top = y-h/2+t1.height/2; t1.rotate(90); //文字旋转90度 /* var line2=g1.pathItems.add(); //画长度标尺 line2.setEntirePath( new Array( new Array(x, y-h-s), new Array(x+w, y-h-s), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x, y-h-s-s/2), new Array(x, y-h-s/2), ) ) ; line2.strokeColor= redColor; var line2=g1.pathItems.add(); line2.setEntirePath( new Array( new Array(x+w, y-h-s-s/2), new Array(x+w, y-h-s/2), ) ) ; line2.strokeColor= redColor; //画箭头 var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x,y-h-s), new Array(x+asize,y-h-s-asize/2), new Array(x+asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var ar1=g1.pathItems.add(); ar1.setEntirePath( new Array( new Array(x+w,y-h-s), new Array(x+w-asize,y-h-s-asize/2), new Array(x+w-asize,y-h-s+asize/2), ) ) ; ar1.strokeColor= NoColor; ar1.fillColor= redColor; ar1.closed=true; var t2 = g1.textFrames.add(); t2.contents = Math.round(w*0.35277778)+" mm"; //小数位四舍五入取整数 t2.textRange.characterAttributes.size=tsize; t2.textRange.characterAttributes.fillColor= redColor; t2.left = x+w/2-t2.width/2; t2.top = y-h-s*1.2;*/ } |
2017-04-24, 12:28 | 只看该作者 #5 | ||
t2.contents = Math.round(w*0.35277778)+" mm"; //小数位四舍五入取整数 t2.textRange.characterAttributes.size=tsize; t2.textRange.characterAttributes.fillColor= redColor; t2.left = x+w/2-t2.width/2; t2.top = y-h-s*1.2; } //标注在左 这里修改一下就可以了&&&&&&&&&&&&&&&& doc = app.activeDocument; //在当前文件进行操作 theSelect = doc.selection; //对已选择的物体进行标注 sizelayer=doc.layers.add(); //新建图层 sizelayer.name = '尺寸标注层'; //设置图层名称 |
