旧 2017-05-06, 16:27     #1
roychen roychen 当前在线
级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时级别:102 | 在线时长:10814小时 | 升级还需:207小时
Uid: 9
注册日期: 2004-05-10, 12:00
151 个帖子获得 403 次感谢
现金: 6金币
资产: 90金币
声望: 10 roychen 向着好的方向发展
Uid: 9
151 个帖子获得 403 次感谢
现金: 6金币
资产: 90金币
默认 neoStampa - Version 8.1.4
Release
Professional textile rip & print software with innovative color management
  • Date: 27/04/2017
  • Requirements:
    4GB of RAM (16GB recommended)
    500GB of hard disk
  • Compatibilities:
    Microsoft Windows XP (Service Pack 3)
    Microsoft Windows 7
    Microsoft Windows 8
    Microsoft Windows 10
    New features & Enhancements
    - Applications can make use up to 4Gb of RAM (before was possible to use up to 2Gb)
    - Target measurement dialog shows better patch simulation (if available)
    - Save CP5 name defaults to first object source path
    - Faster processing if there are color replacements configured in the job
    Bug fixes
    - PrintServer crashes due huge amount of memory usage
    - PrintServer crashes randomly at the end of a print job
    - XJB jobs not processed if source files contain special characters (encoding issue)
    - Rapport view not showing intial offset
    - Spot color replacement in PDF/EPS issue when color name contains '(' ')' characters
    - CMYK profiling error
    - CalibrationWizard black addition chart printout limited to the number of Hueman channels
    Drivers (updates)
    NKT Drivers update
    Fedar 6194E new print modes and pass selection
    S.Roque CTS driver update
    S.Roque RoqHybrid driver update
    Arioli Arioprint tiled TIFF
    Negijet TX R1900 fix dot support
    Imprimo Hybrid R200 changed maximum width and colors
    Epson SC-P5000 paper path selection
    DIP J4 and Twinjet drop control
    Flora TSP resolutions
    Konica Minolta 8/10 drop sizes
    FY TEXxxx print mode names
    Zimmer Colaris 3 new print resolutions
    Drivers (Bug fixes)
    Some Epson HTM drivers crashing
    Epson SC-P10000/SC-P20000 HTM error
http://www.inedit.com/neostampa/soft....1.4-Setup.exe
roychen 当前在线
右列 2 位会员因为此帖价值甚高向 roychen 表示感谢:
quyu (2017-05-06), wangyu1314 (2017-05-06)
所有时间均为 +8, 现在的时间是 2025-12-08 13:53.
