2018-03-20, 21:14 | #1 | |||
麻烦版主给合并到顶楼吧!! PressSign Version 8.3.3.3688 安装文件无和谐! 可以申请个Demo lic 安装了解一下! Version 8.3.3.3688 [Client Fixes] - Job URL's are encoded properly for non western languages. - G7 NPDC scoring is only applied if a paper & Solid CMY are measured - AutoMode full file Template aliases are matched first. - Spot colour selection without clicking. - Manroland measurements with combined density and lab solids calculated properly. - Delta D can be turned off in a target independently - Multiline strip info window measured/target colours full strip view is consistent with the summary view. - Range checking when exporting / Updating Esko Intellicurve .ted XML files - EasyTrax dud patches are ignored. - Export Patches and Colour Libraries as CxF - Heidelberg Prinect API Auto Mode Timezone error - {MAC} Device frameworks are located properly. [Web Server Fixes] - YTD (year to Date) view fixed when you view on a day which is later than the number of days in the next month. - YTD always starts Midnight on the 1st of the month. [隐藏内容]:
此帖于 2018-03-26 10:14 被 wangyu1314 编辑. 原因: 合并新附件 |
右列 13 位会员因为此帖价值甚高向 梦幻蓝天 表示感谢: |
352584 (2018-03-22),
A-J (2018-03-21),
DuoKe (2018-03-21),
duonvanson (2021-05-02),
gaozonga520 (2018-03-20),
geyouwei (2023-09-15),
Kuranjun (2024-11-10),
mlz06 (2018-08-28),
quyu (2018-04-09),
tzm1018 (2018-03-20),
wangyu1314 (2018-03-20),
哈哈88888888 (2018-03-20),
老济 (2018-03-21)
2018-03-20, 23:52 | 只看该作者 #7 | |||
Newbie Member
Version 9.0.0.3697 [New Client Features] - Jobs can be divided into Projects and sheets. - Move Jobs into project, - Add sheets into projects - Copy existing jobs/projects and sheets - New PDF Report Designer - Create PDF styles and choose which sections are included. - Auto Mode default PDF Style - Estimated targets and density ranges in standard are calculated and displayed for spot colours. - Density numbers are shown for spot colours using either a Spectral Density value, or CMYK depending on if the target colour has spectral values. - Asymmetric perfecting press support. - {Mac} Techkon SpectroDens support [New Server Features] - Create an email schedule for reports. - Send reports either on a schedule or on a trigger. - Send reports to multiple recipients. - Reports can be generated as PDF, HTML or XML. ------- [隐藏内容]:
右列 6 位会员因为此帖价值甚高向 r3voluti0 表示感谢: |
nonamekiller (2024-01-23),
QQ33161288 (2018-03-21),
redwinding (2018-03-21),
tzm1018 (2018-03-21),
印刷交流 (2018-03-21),
风岭2011 (2018-03-21)
2018-03-20, 23:59 | 只看该作者 #8 | ||
高级会员
2018-03-21, 08:34 | 只看该作者 #9 | |||
期侍 期侍 Period of paternity !The dog for version 8 ! |
2018-03-21, 11:26 | 只看该作者 #10 | |||
顽石之中良玉隐焉
生产不干胶贴纸,双面胶EVA,珍珠棉,海棉等电子绝缘材料等业务!树下春包装材料:https://shuxc1688.taobao.com/ |
2018-03-21, 14:00 | 只看该作者 #12 | |||
论坛版主
印前(软件)教学 印前(流程)教学 印前(色彩)教学 印能捷&印能捷EVO、HQRIP和海德堡Prinect,esko流程、GMG & CGS & EFI数码打样类软件,印能捷数据库修复,超强专业印前系统! 更多介绍 http://33161288.lofter.com/ 出售金币(100RMB=160金币,最低100起售,量大从优) 印前脚本及插件订制 联系[QQ:33161288] ----------------------------------------------------------- 承接:文件制作,文件修改,文件拼版,输出最终1 bit tiff |
2018-03-21, 14:03 | 只看该作者 #13 | |||
Newbie Member
右列 5 位会员因为此帖价值甚高向 r3voluti0 表示感谢: |
A-J (2018-03-21),
wjzoufeng (2018-03-24),
梦幻蓝天 (2018-03-21)
