2019-09-03, 10:43 | #1 | |||
力博
点击查看 360度 全景产品效果 Thermo3D How it works: — Measure 3D distortion of thermoformed parts in Capture3D 2017™. — Decorate 3D parts in Pigmentz 2017. — Predistort artwork with Thermo3D plugin in Illustrator™. — Publish final decoration into 3D pdf (compatible with Acrobat Reader) or html5 file. 头盔 吸塑 MetalCan3D How it works: — Measure 3D distortion of drawn parts in Capture3D 2017™. — Decorate 3D parts in Pigmentz 2017. — Predistort artwork with Metalcan3D plugin in Illustrator™. — Publish final decoration into 3D pdf (compatible with Acrobat Reader) or html5 file. Sleeve3D Standard How it works: — Draw the profile of a container in Illustrator. — Build and decorate 3D sleeve in Pigmentz 2017. — Predistort artwork with Sleeve3D plugin in Illustrator™. — Publish final decoration into a 3D pdf (compatible with Acrobat Reader) or html5 file. Sleeve3D Advanced How it works: — Measure 3D distortion of sleeve in Capture3D™. — Decorate 3D sleeve in Pigmentz. — Predistort artwork with Sleeve3D plugin in Illustrator™. — Publish final decoration into 3D pdf (compatible with Acrobat Reader) or html5 file. Label&Cup3D How it works: — adapt of your container decoration to the print area and to the die cut lines. — Modelize in 3D your container (cylindrical, conical & tronconical shapes). — Warp decoration on 3D shape to check if other predistortions are needed. — Publish final decoration into 3D pdf (compatible with Acrobat Reader) or html5 file.
曦霞一日功,换得闲半生。 凌云志犹在,敢与日月争。 此帖于 2019-09-03 11:33 被 Helix.xu 编辑. 原因: 添加图片 |
右列会员因为此帖价值甚高向 Helix.xu 表示感谢: |
r3voluti0 (2019-10-17)
