2006-08-10, 17:08 | #1 | ||
http://www.inkjetart.com/canon/wide/iPF5000.html http://www.luminous-landscape.com/re...-ipf5000.shtml http://www.redrivercatalog.com/infoc...afipf5000.html :) |
2006-09-04, 11:01 | 只看该作者 #3 | ||
1. Ink usage very low, am printing A2 size for around 20 prints, average ink usage is around 3ml per print. With 12 colors of 130ml each, 3ml per print can roughly print around 520pcs of A2 per set of 12 color ink. 2. No need to change matt black and non-matt black ink unlike Espon printers, so you saved A LOT of ink everytime. Why? It is because whenever you change ink, you has to throw away those ink in the tube between the ink and the printhead. According to reliable source on the internet, it's a saving of US$75 everytime you swap the matt or non-matt black ink. 3. R,G and B color ink included, so you get real RED, real Blue and real green instead of mixing them. And since you don't have to mix the ink, you actually save ink as well. 4. The only A2 printer with 12 colours ink in the market. 5. Faster print speed then the rest. 6. 16bit plug-in of photoshop to print 16bit images. 7. Because it's using different kind of black at the same time, the shadow becomes more dynamic, in deep, very 3D kind of print. Conclusion, if China roll out this printer in the future, buy it. I strongly recommended. |
发表新主题 关闭主题 |
相似的主题 | ||||
主题 | 论坛 | |||
佳能IPF5000获06年度欧洲最佳大幅面打印机奖 | ◆- 业界新闻与评论 | |||
canon 打印机维修资料!!!! | ◆- 数码打样与色彩管理 | |||
canon 打印机维修资料 | ◆- 印前综合技术讨论区 |
