2006-08-12, 14:44 | #1 | ||
You can use the Device Link Module to create DeviceLink profiles set up from a direct link between two ICC profiles without the use of a Profile Connection Space (PCS). Thanks to its special parameters it supports individual treatment of the black channel, thus avoiding the problem that a PCS cannot transport all separation properties. RGB and CMYK input and output files are supported. The DeviceLink Module enables you to choose the Source ICC profile and the Destination ICC profile on the left and displays a comparison of the most important properties of the selected profiles. The profile type (RGB/CMYK, input/output profile) influences the selection options for the DeviceLink profiling on the right-hand side, those options not permitted are hidden. You can choose: Clean Primary Colors Clean Black CMYK Separation Clean Primary Colors If the Clean Primary Colors has been activated (On), the DeviceLink profile is generated in a way that cleanly converts the full tone colors from the Source profile (RGB/CMY) to the Destination profile. Thus there is no colorimetric adjustment for full tones. This avoids the printing of smaller amounts of other process colors in a 100% Yellow, for example, because the process color Yellow in the Output file differs from the process color Yellow in the Source profile. Clean Black If the Clean Black option has been activated (On), the DeviceLink profile is generated in a way that converts the black components in the Source profile to clean black components in the Destination profile. There is no four-color black as with a PCS conversion. Any black with a color cast in the Destination profile is nevertheless intelligently neutralized. CMYK Separation The CMYK Separation in the DeviceLink Module is the ProfileMaker Standard CMYK Separation Dialog that enables you to change the separation settings of the CMYK Destination profile. The DeviceLink Module directly analyzes the maximum total area cover in the Source and Destination profiles and generates a warning if the total area cover is larger in the Source than in the Destination profile. The total area cover of the Source profile is then applied to the separation settings of the Destination profile so as to avoid printing problems. |
2006-08-12, 16:48 | 只看该作者 #3 | ||
看来懂这个的也不多.那我就可以来班门弄虎了. 看文字还是不直观.我们来图. 图一是使用勾选 CLEAN选项转换出来的图.可以看到.K100成了K99.其它也有相应改变. M100转换成了M99+Y1 好.我们再来看看图二. 使用不勾选CLEAN选项生成的LINK ICC.也就是不保护.看看结果. K100仍然转换成了K99.但是K90的转换结果就是C5M5Y6K85哈哈.知道了吧.原来保护黑色通道Clean Black就是这个意思. 好.再看看M100的结果.C11 M90哈哈.这就是保护主色的结果>>Clean Primary Colors. |
2006-08-12, 17:58 | 只看该作者 #7 | ||
可以试用.只是处理过的文件都会加上DEMO字样.不过不要紧.学习学习. 在官网有下载. 色彩管理 功能强大...大家有必要人手一份.呵呵.下载地址: http://www.gretagmacbeth.com/index/p...oftware-11.htm 会出来一个地区选择.先ASIA后会自动跳转到下载页面! 它可以使用两种方式来转换文件.虚拟打印机和热文件夹.我在视频中使用的是热文件夹的方式. 可以处理TIFF.PDF.PS.EPS等印前通用格式.. 最重要的是能够把包含多种ICC的文件转换为印刷ICC...完全自动.呵呵.我喜欢...大家一起来玩玩吧. |
2006-08-14, 12:29 | 只看该作者 #11 | ||
ok.first .your question isn't a question. device link profile cann't be use in profilemake... profilemake is a tool to make profiles.... as xiaoqing63944149 said at floor five. we can use the device link profile in iqueue software. it's a great program for color.!
love is an expensive shopwindow
I open my life,If i can find you, then I'll know how rich I am. |
发表新主题 关闭主题 |
相似的主题 | ||||
主题 | 论坛 | |||
让数码打样黑色不偏色用 | ◆- 数码打样与色彩管理 | |||
DeviceLink profiles 起什么作用? | ◆- 数码打样与色彩管理 |
