2019-12-10, 07:49 | #1 | |||
Newbie Member
See new features and prepare yourself to upgrade or buy new version ! Aq5q4gf0QO.png ---------------------------------------------- Version 10.0.0.10062 [New Features] - Responsive Interactive Web Dashboard (Requires a php capable web server). - Context aware colour information. Shows Delta E, TVI, G7 and calibrated(adjusted) values - Colour previews are split into Printed, Target and calibrated areas. - See the Delta E, TVI etc after applying calibration curves. - Accurate Delta E tolerances shapes drawn when comparing colours. - Colour list shows out of tolerance delta E values. - Lab diagram Spider view. - Only show Solid and TVI patches in a Lab diagram. - CMYK Spot colour support. - 3D Lab plot. - Find the Closest CMYK match for any colour. Specify Channels and Minimum Dot. - New Target Lab panel for showing estimated targets. - Show estimated change in Lab value at different densities. - Softproof window shows ink coverage for each key. - Job Meta Data. Add extra information to a job. Add Key, Value and Default Value. - Rotate and Mirror Colour bars whilst editing. - Colour bars no longer require a paper patch, unless adding tints. - Unified Main Window. - Deleting settings can be done from a single site, or All sites. - Specify tolerances for CMYK separately. - Specify ∆H tolerances for CMYK separately. - ISO 15311-2 A/B/C tolerances. - Fail a job completely if an individual criteria fails. - 64 Bit Windows client. - 64 bit Windows Server. - 64 bit PostgreSQL 12 server with fast upgrade. - Web server no longer requires a Mobile Activation Code - Forgotten password support. Reset via Administrator login, or via the internet and Online Account. - Re-open the 5 most recent jobs. - Add / Remove / Re-Order columns in the Open Job Window. - Change Toolbar icon size and labels - Add / Edit Job comments during a job. - Per user preferences. - Directly create a target standard from measured sheet. - Save and Update calibration curves in the database - Automatic download of software updates. Downloaded by the License Server and distributed when a client logs in. ---------------------------- [隐藏内容]:
右列 13 位会员因为此帖价值甚高向 r3voluti0 表示感谢: |
A-J (2019-12-10),
byronz (2019-12-16),
chenfulin123 (2020-10-31),
DuoKe (2019-12-18),
duonvanson (2020-08-17),
hrs1017 (2019-12-13),
longjiuzhou123 (2019-12-10),
QQ33161288 (2019-12-10),
suodip (2019-12-10),
tzm1018 (2019-12-10),
wangyu1314 (2019-12-10),
余海 (2019-12-10),
我的天 (2019-12-10)
2019-12-10, 12:33 | 只看该作者 #2 | |||
右列会员因为此帖价值甚高向 印刷交流 表示感谢: |
2019-12-10, 13:04 | 只看该作者 #3 | |||
KEY应是变了,但狗就不知了
印前交流、流程交流、色彩交流、Prinegy修复、苹果系统软件交流。 金币 QQ:540003127(100RMB起,量大优惠) |
右列会员因为此帖价值甚高向 tzm1018 表示感谢: |
2019-12-13, 09:15 | 只看该作者 #4 | ||
右列会员因为此帖价值甚高向 地平线 表示感谢: |
2019-12-13, 09:42 | 只看该作者 #5 | ||
右列会员因为此帖价值甚高向 chen07521 表示感谢: |
2019-12-13, 11:57 | 只看该作者 #6 | |||
Newbie Member
For sure they are updating very quickly ! Now 10.0.0.10074 : Version 10.0.0.10074 [New Features] - Responsive Interactive Web Dashboard (Requires a php capable web server). - Context aware colour information. Shows Delta E, TVI, G7 and calibrated(adjusted) values - Colour previews are split into Printed, Target and calibrated areas. - See the Delta E, TVI etc after applying calibration curves. - Accurate Delta E tolerances shapes drawn when comparing colours. - Colour list shows out of tolerance delta E values. - Lab diagram Spider view. - Only show Solid and TVI patches in a Lab diagram. - CMYK Spot colour support. - 3D Lab plot. - Find the Closest CMYK match for any colour. Specify Channels and Minimum Dot. - New Target Lab panel for showing estimated targets. - Show estimated change in Lab value at different densities. - Softproof window shows ink coverage for each key. - Job Meta Data. Add extra information to a job. Add Key, Value and Default Value. - Rotate and Mirror Colour bars whilst editing. - Colour bars no longer require a paper patch, unless adding tints. - Unified Main Window. - Deleting settings can be done from a single site, or All sites. - Specify tolerances for CMYK separately. - Specify ∆H tolerances for CMYK separately. - ISO 15311-2 A/B/C tolerances. - Fail a job completely if an individual criteria fails. - 64 Bit Windows client. - 64 bit Windows Server. - 64 bit PostgreSQL 12 server with fast upgrade. - Web server no longer requires a Mobile Activation Code - Forgotten password support. Reset via Administrator login, or via the internet and Online Account. - Re-open the 5 most recent jobs. - Add / Remove / Re-Order columns in the Open Job Window. - Change Toolbar icon size and labels - Add / Edit Job comments during a job. - Per user preferences. - Directly create a target standard from measured sheet. - Save and Update calibration curves in the database - Automatic download of software updates. Downloaded by the License Server and distributed when a client logs in. |
右列会员因为此帖价值甚高向 r3voluti0 表示感谢: |
wangyu1314 (2019-12-13)
