旧 2020-07-05, 23:28     #1
cd1819 cd1819 当前离线
级别:19 | 在线时长:475小时 | 升级还需:5小时级别:19 | 在线时长:475小时 | 升级还需:5小时级别:19 | 在线时长:475小时 | 升级还需:5小时级别:19 | 在线时长:475小时 | 升级还需:5小时
Uid: 538188
注册日期: 2016-10-13, 13:10
年龄: 36
现金: 52金币
资产: 52金币
声望: 10 cd1819 向着好的方向发展
cd1819 cd1819 当前离线
Uid: 538188
年龄: 36
现金: 52金币
资产: 52金币
默认 奥西Vp135 报错6139求助
维修模式清过,传感器清洁过,求大神指到
cd1819 当前离线
旧 2020-07-06, 13:54   只看该作者   #2
yanjunmouse yanjunmouse 当前离线
帅哥 级别:11 | 在线时长:175小时 | 升级还需:17小时级别:11 | 在线时长:175小时 | 升级还需:17小时级别:11 | 在线时长:175小时 | 升级还需:17小时级别:11 | 在线时长:175小时 | 升级还需:17小时级别:11 | 在线时长:175小时 | 升级还需:17小时
Uid: 151870
注册日期: 2010-03-23, 22:03
现金: 22金币
资产: 22金币
声望: 10 yanjunmouse 向着好的方向发展
Uid: 151870
现金: 22金币
资产: 22金币
Error code 6139 Sheet in warm process
Screening
1 Check if the customer removed paper by pulling the TTF out of the machine. Support the customer if necessary.
See the "Remove paper from the TTF" procedure which is a part of the operating manual.
2 If the TTF cannot be pulled out. A sheet may be stuck between TTF and horizontal paper transport.
3 If the problem occurs again after the customer removes the paper, check if there is paper again in the machine.
NO -> go to measures
YES -> go to additional measures
Measures Action Info
1 Replace the Sensor box, WPR. Remove the Sensor box WPR
Sensor Box WPR 0675
2 Check for toner pollution on the sensor box. In case of pollution, replace the toner suction channel
Note:
After you have solved the problem, reset the maintenance counter of the detected sheet in warm process (SDS: Maintenance Counters/printer/Warm PRocess/detected sheet in warm process).
Additional measures
Action Info
3 Check for correct paper separation from the paper trays.
Adjust if necessary.
4 Check if < gsm and coated paper is used.
Curl is suspicious.
5 Rotate the TTF coupling and see if all functions in the TTF unit rotate.
Correct if necessary. TTF Unit WPR 0670
6 Print a job with 80 gsm:
If job is okay, media is the problem.
If job is not okay, it is a technical problem.
7 Test the Paper receive unit, WPR with A3 200 gsm, if okay the problem is not related to the Paper receive unit, WPR. Paper Receiving Unit WPR 0680
Additional information
The sheet sensor located in the sensor box, detects a sheet in the warm process.
This is a Permanent Error (PE).
Note:
yanjunmouse 当前离线
旧 2020-07-09, 18:58   只看该作者   #3
疯狂的小螺丝 的头像
疯狂的小螺丝 疯狂的小螺丝 当前离线
Uid: 172046
注册日期: 2010-07-05, 21:27
感谢: 320
450 个帖子获得 617 次感谢
现金: -13992金币
资产: -13992金币
声望: 11 疯狂的小螺丝 向着好的方向发展
疯狂的小螺丝 疯狂的小螺丝 当前离线
疯狂的小螺丝 的头像
Uid: 172046
感谢: 320
450 个帖子获得 617 次感谢
现金: -13992金币
资产: -13992金币
拉出TTF带总成,里面带子是否有损坏,是否有碎纸 传感器是否脏污。手动旋转看看,是否能转动这些组件。
略懂一点奥西 柯美 理光高速机维修,相互学习交流指正。
疯狂的小螺丝 当前离线
所有时间均为 +8, 现在的时间是 2025-12-14 08:52.
