◆- 印刷标准化 交流印刷国际标准ISO、Fogra/Ugra PSO、Fogra 39L、GMI及 GRACoLG7,紧跟国际最高印刷水平,形成符合企业实际需要的印刷标准。
旧 2020-09-27, 19:38     #1
lvhonghui 的头像
lvhonghui lvhonghui 当前在线
级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时级别:111 | 在线时长:12787小时 | 升级还需:205小时
Uid: 40111
注册日期: 2007-04-12, 18:49
感谢: 324
199 个帖子获得 304 次感谢
现金: 459金币
资产: 459金币
声望: 10 lvhonghui 向着好的方向发展
lvhonghui 的头像
Uid: 40111
感谢: 324
199 个帖子获得 304 次感谢
现金: 459金币
资产: 459金币
默认 懂英文的老铁们进来帮忙翻译一下吧。
对照百度翻译的有的很绕口,请用中文翻译一下。
CREO Prinergy (Harmony curves)
When printing the first P2P target, using the pre-set *** NONE *** setting in both Current or Target
should produce an un-calibrated plate. However on rare occasions *** NONE *** has been seen to
trigger hidden calibration values which are not retained when *** NONE *** is replaced by a userconstructed
curve, which then causes the G7 process to fail. Symptoms of this failure include
unexpected dot values on plate and/or incorrect gray balance or NPDC curves after G7 calibration.
If in doubt, print the first P2P target using your own ‘Custom Linear’ calibration curve constructed from
Current and Wanted curves, as follows:
Constructing a Custom Linear Current curve in Harmony
• Click File – New Curve – Current …
• In Current Curve Properties make sure Curve Set is ‘CMYK Curves’
• Enter the other required property values
• Click File – Save Curve As … with a suitable name, e.g. ‘Custom Linear Current’
Constructing a Custom Linear Target curve in Harmony
• Click File – New Curve – Target …
• In Target Curve Properties make sure Curve Set is ‘CMYK Curves’
• Click File – Save Curve As … with a suitable name, e.g. ‘Custom Linear Target’
Constructing a Custom Linear Calibration curve in Harmony
• Click File – New Curve – Calibration …
Exporting G7 Curves for Harmony
• In Create Curves, select Single channel file set and click Export
• Save the resulting folder with a suitable name, where it can be accessed from within Harmony
Loading G7 Curves into Harmony
• In the Harmony Target Curve window, select the Black channel
• Click Edit – Import Curve Profile... and load the black curve from the Single channel file set folder
• Repeat for the Cyan, Magenta and Yellow curves
• Save the Harmony Target curve and proceed as normal
当打印第一个P2P目标时,Harmony curves的当前值和目标值应该为无,也就是不加载曲线出一张直线版。
lvhonghui 当前在线
旧 2020-09-28, 08:25   只看该作者   #2
Art.XiaoLu 的头像
Art.XiaoLu Art.XiaoLu 当前离线
级别:39 | 在线时长:1687小时 | 升级还需:73小时级别:39 | 在线时长:1687小时 | 升级还需:73小时级别:39 | 在线时长:1687小时 | 升级还需:73小时级别:39 | 在线时长:1687小时 | 升级还需:73小时级别:39 | 在线时长:1687小时 | 升级还需:73小时级别:39 | 在线时长:1687小时 | 升级还需:73小时
Uid: 407415
注册日期: 2014-06-05, 00:10
198 个帖子获得 284 次感谢
现金: 2115金币
资产: 2395金币
声望: 10 Art.XiaoLu 向着好的方向发展
Art.XiaoLu 的头像
Uid: 407415
198 个帖子获得 284 次感谢
现金: 2115金币
资产: 2395金币
————谷歌翻译如下————
CREO印能捷(和声曲线)
打印第一个P2P目标时,请同时使用“当前”或“目标”中的预设***无***设置
应产生未校准的板。但是在极少数情况下,***无***被认为是
触发由用户构造的*** NONE ***替换时不保留的隐藏校准值
曲线,然后导致G7进程失败。此失败的症状包括
G7校准后,印版上的点值意外和/或灰度平衡或NPDC曲线不正确。
如有疑问,请使用您自己的“自定义线性”校准曲线打印第一个P2P目标
当前曲线和通缉曲线,如下所示:
协调构建自定义线性电​​流曲线
•单击文件–新建曲线–当前…
•在“当前曲线属性”中,确保“曲线集”为“ CMYK曲线”
•输入其他必需的属性值
•单击文件–使用合适的名称将曲线另存为…,例如。 “自定义线性电​​流”
和谐地构建自定义线性目标曲线
•单击文件–新建曲线–目标...
•在“目标曲线属性”中,确保“曲线集”为“ CMYK曲线”
•输入其他必需的属性值
•单击文件–使用合适的名称将曲线另存为…,例如。 “自定义线性定位”
协调构建自定义线性校准曲线
•单击文件–新建曲线–校准...
导出G7曲线以实现和谐
•在“创建曲线”中,选择“单通道文件集”,然后单击“导出”。
•用合适的名称保存生成的文件夹,可以从Harmony中访问该文件夹
将G7曲线加载为和声
•在“和声目标曲线”窗口中,选择“黑色”通道
•单击编辑–导入曲线轮廓...,然后从单通道文件集文件夹中加载黑色曲线。
•对青色,品红色和黄色曲线重复
•保存“和声目标”曲线并照常进行
————搜狗翻译如下————
CREO普林格(和谐曲线)
打印第一个P2P目标时,在当前或目标中使用预设的***无***设置
应该产生一个未校准的板。然而,在极少数情况下***无***被认为
当用户构造的***无***被替换时,触发不保留的隐藏校准值
曲线,然后导致G7进程失败。这种失败的症状包括
G7校准后,印版上出现意外的点值和/或不正确的灰度平衡或NPDC曲线。
如果有疑问,使用您自己的“自定义线性”校准曲线打印第一个P2P目标,该校准曲线由以下内容构成
当前曲线和所需曲线如下:
和谐构建自定义线性电流曲线
单击文件-新曲线-当前…
在当前曲线属性中,确保曲线集为“CMYK曲线”
输入其他必需的属性值
单击文件–将曲线另存为…使用合适的名称,例如“自定义线性电流”
和谐构建自定义线性目标曲线
单击文件-新曲线-目标…
在目标曲线属性中,确保曲线集为“CMYK曲线”
输入其他必需的属性值
单击文件–将曲线另存为…使用合适的名称,例如“自定义线性目标”
和谐构建自定义线性校准曲线
单击文件-新曲线-校准…
导出G7曲线以实现和谐
在创建曲线中,选择单通道文件集,然后单击导出
用合适的名称保存生成的文件夹,这样就可以在和谐中访问它
将G7曲线载入和声
在和声目标曲线窗口中,选择黑色通道
单击编辑–导入曲线轮廓...并从单通道文件集文件夹加载黑色曲线
对青色、洋红色和黄色曲线重复上述步骤
保存和谐目标曲线并正常进行
————有道翻译如下————
CREO Prinergy(和谐曲线)
当打印第一个P2P目标,使用预设的*** NONE ***设置在当前或目标
应该生产一个未校准的板。然而,在罕见的情况下,没有***被看到
触发器隐藏的校准值,不保留时,***没有***被一个userconstruct
这将导致G7进程失败。这种失败的症状包括
在七国集团校准后,印版上出现意外的网点值和/或不正确的灰平衡或NPDC曲线。
如果有疑问,打印第一个P2P目标使用您自己的“自定义线性”校准曲线构建
电流和需要曲线,如下:
构造一个自定义的和谐线性电流曲线
•单击文件-新建曲线-当前…
•在当前曲线属性中,确保曲线设置为“CMYK Curves”
•输入其他必需的属性值
•点击文件-保存曲线为…,并有一个合适的名字,例如“自定义线性电流”
构造一个自定义的线性目标曲线的和谐
•单击文件-新建曲线-目标…
•在目标曲线属性中,确保曲线设置为“CMYK Curves”
•输入其他必需的属性值
•点击文件-将曲线保存为…,并取一个合适的名字,例如“自定义线性目标”
和谐地构建自定义线性校准曲线
•单击文件-新建曲线-校准…
为和谐输出G7曲线
•在创建曲线中,选择单通道文件集,然后单击导出
•将结果文件夹保存为一个合适的名称,以便在Harmony中访问
将G7曲线加载到和谐中
•在和谐目标曲线窗口中,选择黑色通道
•点击编辑-导入曲线配置文件…并从单通道文件集文件夹加载黑色曲线
对青色、品红和黄色曲线重复上述操作
•保存和声目标曲线并正常进行
Art.XiaoLu 当前离线
旧 2020-09-28, 08:29   只看该作者   #3
lvhonghui 的头像
Uid: 40111
感谢: 324
199 个帖子获得 304 次感谢
现金: 459金币
资产: 459金币
lvhonghui 的头像
Uid: 40111
感谢: 324
199 个帖子获得 304 次感谢
现金: 459金币
资产: 459金币
CREO Prinergy 曲线(Harmony curves)
当打印第一个P2P目标时,在当前值或目标值中都使用预先设置的*无*设置产生未校准的板。(理解为出直线版)
但在极少数的情况下,可能会看不到隐藏的校准值,当*无*被用户替换时,这些值不会在曲线上保留,从而导致G7过程失败。这种故障包括G7校准后,板材上出现意外的点值和灰平衡或NPDC曲线不正确。
如果有疑问,使用你自己的“自定义线性”校准曲线打印第一个 p2p 目标,这些曲线是由当前和想要的曲线创建的,如下所示:
在harmoy中新建自定义当前值曲线
•单击文件–新建曲线–当前值
•在当前曲线属性中,确保曲线集是“CMYK曲线”
•输入其他需要的属性值
•点击文件-保存曲线…并使用适当的名称,例如“自定义当前值曲线”
在harmoy中新建自定义目标值曲线
•单击文件-新建曲线–目标值
•在目标曲线属性中,确保曲线集是“CMYK曲线”
•输入其他需要的属性值
•点击文件-保存曲线…并使用适当的名称,例如“自定义目标值曲线”
在harmoy中新建自定义校准曲线
•单击文件-新建曲线–校准值
为harmoy导出G7的曲线
•在创建曲线中,选择单个通道文件集并单击导出
•使用合适的名称保存结果文件夹,以便在Harmony中访问
加载G7曲线到harmoy中
•在harmoy目标曲线窗口中,选择黑色通道
•点击编辑-导入曲线…从单通道文件集文件夹加载黑色曲线
•对青色、品红和黄色曲线重复上述操作
•保存harmoy目标曲线并正常使用
lvhonghui 当前在线
旧 2020-09-28, 12:01   只看该作者   #4
du_andy 的头像
du_andy du_andy 当前离线
级别:24 | 在线时长:695小时 | 升级还需:30小时级别:24 | 在线时长:695小时 | 升级还需:30小时级别:24 | 在线时长:695小时 | 升级还需:30小时
Uid: 227221
注册日期: 2011-05-16, 21:27
来自: 接CTP临工
感谢: 14
46 个帖子获得 56 次感谢
现金: 372金币
资产: 373金币
声望: 10 du_andy 向着好的方向发展
du_andy 的头像
Uid: 227221
来自: 接CTP临工
感谢: 14
46 个帖子获得 56 次感谢
现金: 372金币
资产: 373金币
这不就是在Harmony软件做条线性化的过程吗
du_andy 当前离线
所有时间均为 +8, 现在的时间是 2025-01-01 18:41.
