2020-10-08, 02:21 | #1 | |||
Newbie Member
4.0.0.1 Build 109 __________________________ Installation Certain programs may block the installation process. The process pauses after extracting the installation files. In this case proceed as follows: 1. If the current version of Adobe Creative Cloud is installed, sign out from the Adobe CC desktop app. 2. Start Windows Task Manager and click the Details tab. Right-click 'Setup.exe' and select 'Analyze wait chain'. The process listed under 'Setup.exe' is blocking the installation. Select and end it. Version 4.0.0.1 ADDITIONS #62081 - Epson SC-Px500 printers: Added new paper type 'ORIS PearlPROOF Select'. #62094 - Epson SC-Px500 printers: Added new print resolution 'Super fine 1200x1200dpi Precise (1200dpi data)' for proofing continuous tone data. Requirements: Install new printer plug-in 'CP_ESCP7595_20_1.exe' and new printer firmware 'LK01KA'. New firmware will be made available for download on Epson website on October 9, 2020. #61889 - Creating Reference Printer Profiles: Addition of noise can be controlled from user interface. BUG FIXES #62232 - Spot color correction: Fixed the wild cards in the dialog box that appears when selecting a device profile. #62224 - It is again possible to delete user accounts. #62206 - For jobs with RGB images, process colors are no longer left out from the list of separations in the 'Info' panel. #62295 - ScreenDot queues: The job preview image updates as expected when color separations are modified. #62167 - Fixed a PDF input issue that occurred when the Adobe PDF Print Engine was not used. #61798 - Main window: Increasing the width of the 'Info' panel no longer causes the job list in the center to increase in width, too. #62244 - Scatter proof settings are no longer displayed incorrectly if a queue was set to add information text to every scatter proof job. #62233 - Epson SC-P7500 printers: Fixed the SpectroProofer communication error that prevented the measurement data to be written back to COLOR TUNER. Requirement: Install new printer firmware 'LK01KA' available on Epson website from October 9, 2020. #61363 - Automatic certification with inline spectro: Fixed an error that occurred when spot colors not available in the SCGx file should be ignored. #62151 - Epson SC-Px500: In ScreenDot and ScreenDot Plus mode, automatic certification works as expected now. -------------------------- [隐藏内容]:
右列 6 位会员因为此帖价值甚高向 r3voluti0 表示感谢: |
A-J (2020-10-08),
redwinding (2020-10-08),
wangyu1314 (2020-10-08),
夜色无黑 (2020-10-08),
我的天 (2020-10-08),
火星来客 (2021-02-07)
