旧 2023-11-23, 09:12     #1
9876543213 9876543213 当前离线
帅哥 级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时级别:70 | 在线时长:5198小时 | 升级还需:127小时
Uid: 260600
注册日期: 2011-10-24, 14:02
感谢: 11
93 个帖子获得 302 次感谢
现金: 80金币
资产: 7899金币
声望: 10 9876543213 向着好的方向发展
Uid: 260600
感谢: 11
93 个帖子获得 302 次感谢
现金: 80金币
资产: 7899金币
默认 Print2CAD 2024 AI v24.21 x64
别处搬运。收点搬运费。软件英文版。没有中文版。请自行测试
[隐藏内容]:
您需要花费 10 金币购买,才能查看该隐藏内容。 [看谁购买]
Print2CAD BackToCAD product is an efficient tool for converting drawings and PDF designers to editable DWG and DXF files and vice versa. These files are easily editable in CAD software such as AutoCAD and Intel. This software is a standalone program and is not affiliated with any CAD software. It also converts pdf files to DWG / DXF as well as converts them. In addition, you can easily convert DWG / DXF files to other image formats such as TIFF / JPEG and more.
It can also convert HPGL files to DWG / DXF format. This software uses Autodesks TrustedDWG technology and is unique in its conversion, output files are 100% compatible with Autodesk products. The tool can also OCR texts. Texts extracted from images and PDFs are added to the output in an editable format. The program uses both English and German with different units of measurement.
The simple application environment is designed and the conversion process proceeds with step-by-step wizards. You will be provided with the necessary information at each step. Based on this information you make the desired adjustments and you will ultimately receive quality output. For the right use of the program there are 28 different video clips along with which you will learn different conversion scenarios. It is also worth noting that this software detects layers when converting PDF files and is able to isolate them. Geometric shapes such as circles and bows are also well recognized and converted to CAD equivalent in DWG / DXF formats.
文件类型: png QQ图片20231123091046.png (290.0 KB, 52 次查看)
9876543213 当前离线
旧 2023-11-23, 11:08   只看该作者   #2
lou 的头像
lou lou 当前离线
帅哥 级别:51 | 在线时长:2855小时 | 升级还需:57小时级别:51 | 在线时长:2855小时 | 升级还需:57小时级别:51 | 在线时长:2855小时 | 升级还需:57小时级别:51 | 在线时长:2855小时 | 升级还需:57小时级别:51 | 在线时长:2855小时 | 升级还需:57小时级别:51 | 在线时长:2855小时 | 升级还需:57小时
Uid: 60195
注册日期: 2007-11-14, 10:08
感谢: 28
99 个帖子获得 150 次感谢
现金: 4166金币
资产: 4166金币
声望: 13 lou 向着好的方向发展
lou lou 当前离线
lou 的头像
Uid: 60195
感谢: 28
99 个帖子获得 150 次感谢
现金: 4166金币
资产: 4166金币
声望: 13 lou 向着好的方向发展
这个干啥的哟,全英文的,也给大伙翻一下啊!,哎,还是我来用度娘给大家译一下!大概能看懂!
Print2CAD BackToCAD产品是将图形和PDF设计器转换为可编辑DWG和DXF文件的有效工具,反之亦然。这些文件可以在AutoCAD和Intel等CAD软件中轻松编辑。该软件是一个独立的程序,不隶属于任何CAD软件。它还将pdf文件转换为DWG/DXF,并对其进行转换。此外,还可以轻松地将DWG/DXF文件转换为其他图像格式,如TIFF/JPEG等。
它还可以将HPGL文件转换为DWG/DXF格式。此软件使用Autodesks TrustedDWG技术,并且在转换方面具有独特性,输出文件与Autodesk产品100%兼容。该工具还可以对文本进行OCR。从图像和PDF中提取的文本以可编辑的格式添加到输出中。该程序同时使用英语和德语,测量单位不同。
设计了简单的应用程序环境,转换过程通过逐步向导进行。每一步都会向您提供必要的信息。根据这些信息,您可以进行所需的调整,最终将获得高质量的输出。为了正确使用该程序,有28个不同的视频剪辑,您将了解不同的转换场景。同样值得注意的是,该软件在转换PDF文件时检测图层,并能够隔离它们。圆形和蝴蝶结等几何形状也得到了很好的识别,并转换为DWG/DXF格式的CAD等效图形。
lou 当前离线
旧 2023-11-23, 12:27   只看该作者   #3
terry2016 terry2016 当前离线
级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时级别:62 | 在线时长:4152小时 | 升级还需:69小时
Uid: 531439
注册日期: 2016-08-21, 23:26
年龄: 44
41 个帖子获得 45 次感谢
现金: 1065金币
资产: 1066金币
声望: 10 terry2016 向着好的方向发展
Uid: 531439
年龄: 44
41 个帖子获得 45 次感谢
现金: 1065金币
资产: 1066金币
是AA版的吗》???................
terry2016 当前离线
旧 2023-11-23, 13:39   只看该作者   #4
Uid: 260600
感谢: 11
93 个帖子获得 302 次感谢
现金: 80金币
资产: 7899金币
Uid: 260600
感谢: 11
93 个帖子获得 302 次感谢
现金: 80金币
资产: 7899金币
必须是AA,不带AA不会发。。。。。。。。
9876543213 当前离线
所有时间均为 +8, 现在的时间是 2025-01-04 15:12.
