2024-02-16, 15:42 | #1 | ||
Hello, I am preparing variable data in Packz. In a text field, the title is on the first line and the position is on the second line. I can do these on separate lines without any problems. However, if the title is empty on the first line, I cannot move the task to the next line. That's why I tried to combine the text field and more than one variable data in the text field, in this case it combines the two data side by side. I can't make lines. I ask for help from friends who are experts on this subject. BR |
回复时引用此帖 |
2024-02-19, 20:11 | 只看该作者 #2 | ||
I can do this with artpro+. The sample file is attached You can also see it as a video. https://recordit.co/MEYDS0lbAh Is it possible to do this in PACKZ? BR |
回复时引用此帖 |
