旧 2024-03-28, 16:39     #1
nguyensign nguyensign 当前离线
级别:60 | 在线时长:3882小时 | 升级还需:83小时级别:60 | 在线时长:3882小时 | 升级还需:83小时级别:60 | 在线时长:3882小时 | 升级还需:83小时级别:60 | 在线时长:3882小时 | 升级还需:83小时级别:60 | 在线时长:3882小时 | 升级还需:83小时级别:60 | 在线时长:3882小时 | 升级还需:83小时
Uid: 500420
注册日期: 2016-02-21, 21:56
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
声望: 10 nguyensign 向着好的方向发展
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
帖子 Flexi Complete Release Notes (24.0.0 Build 4393)
Operating Systems Supported
• Windows 11 (X64)
•Windows 10 32-bit (x86) or 64-bit (x64) processor
Installing on a Mac using parallels or bootcamp is not recommended and not supported.
New Features
  • Skinable Interface
  • Artboard contrast slider
  • Full screen support
  • Open file tabs
  • Show used color swatch
  • See tools hidden from view
  • Show the number of selected jobs in Production Manager
  • New CutContour swatch
  • Find color tool
  • Keyboard Shortcuts added for mask/unmask
  • New Templates added
  • Finishing tools added to Flexi designer
  • Added option to change file name when sending to Rasterlink
  • Added option to exclude CutContours when sending to Onyx
  • Job Estimation Dialog is now scalable
  • Improved Import/Export of PDF files
  • "Delete selected" tool added
  • Ability to rasterize in CMYK color mode
  • Custom weedpaths in designer
  • improved job info fields
  • Preview CutContour paths in Production Manager
  • Full screen preview in Production Manager
  • improvements to job nesting
  • Added a zoom to page button in job properties
  • Show file name when hovering mouse over job
  • Labels and Marks improvements
  • Match image size in sandwhich jobs
  • Smooth edge of transparency & preview
  • Added transparency by object boundary
  • Assign Transparent Color
  • Send full canvas
  • Very low file preview resolution added to production manager
  • Added notifications for updates
  • Variable dot weight profiling
  • Linearization verification
  • Black generation
Bug Fixes
• Fixed a bug handling a PDF with many pages as well as custom cut colors.
• Preview of PDF with Transparency in Job Properties Dialog: RGB converted to CMYK.
• Adding large TIFF files would crash Production Manager.
• Addressed TIFF files with extra spot channels not opening in Production Manager.
• Text with transparent shadows will not group after converted to outlines.
• Fixed default offset value for converting rectangle to reg mark, from -10 to 0.
• Job name doesn’t display if order of columns in changed in Production Manager queues.
• Wrong message when adding jobs to already nested group.
• Addressed multiple issues with localization, especially for German language.
• Improvement for the accuracy of proposed output values for Color Profile Adjustment dialog.
• Fixed issue with adding drivers for Mutoh 1908W
•Job Monitor showing scrambled characters for job names.
• Fixed missing tilling anchor points in Production Manager.
• Weed border panel margin not saving.
• Summa OPOS XY2 marks are not printed if the barcode option is unticked.
• SummaFlex barcode Y-line was too thin.
• When selecting Japanese language for install language, Install Manager still shows English.
• Color Adjustment not applied correctly to RGB output.
• Fixed media name when profiles created in non-Unicode version and added to Unicode version of Flexi.
• Unable to print to HP DesignJet T730.
• Input profile from Photoshop PNG file not imported into Flexi.
• Preset from 22 sp3 causing error in 22 SP4 when job sent from RIP and Print Dialog.
• Saving transparent PNG after resizing it in Flexi will remove transparency.
• Laser Cut Mark to use color selected in Labels and Marks page.
• Incorrect space is added between tiles when using color bands
• Horizonal offset is not working when using Page and Tile Nesting and Print color bands.
• Catch exception in header HP Pagewide XL 5000.
• Sentinel USB drivers not installed when the option is ticked in the installer.
• Tiles not nested in same order in RIP and Print Dialog compared to Production Manager.
• Not able to send jobs to two OKI DATA ColorPainter M-64s at same time.
• The outputs are shifted after applying Jig layout when Print while RIP is used.
• Copies changes not saved for nested job and multi-page documents.
• Join Path tool does not bring up Join Path tab in Design Central.
• Files saved from Flexi 22 with report template will crash Flexi 22 when reopened.
• Smaller differences between exported documents and the original ones when exporting as CMYK color space.
• Incorrect position for copies when using nest and page range options.
• Print shifted in the middle of printing when Print while Rip is used.
• HPGL/2 Command error on GCC Jaguar V 183
• Incorrect size of font and line spacing for inside labels.
• PM crashing when job length is longer than media length.
• Summa OPOS marks cut off when nesting jobs.
• Copy preference form precious installation not copying Production Manager preferences.
• Gradient fill from Illustrator pdf not importing correctly.
• Inconsistent behavior when using labels and cut along page border
• Added validation and automatic correction of the erroneous color adjustment curves after loading from presets.
• Job switching positing when changing between Fotoba Mark and Fotoba Horizontal Mark.
• Incorrect position of labels when used with Fotoba Marks.
• Open path contour cut line from 3rd party app not recognized.
• Improvement to Myiro color spectrometer target.
• SVG file not importing correctly.
• Font style not showing in the Insert Symbol dialog.
• Not to allow negative values on the "Define Jig Layout" fields.
• Creating transparency for PDF files in Production Manager.
• Roland GR-540 keeps returning to origin.
• Splitting of jobs with variable data to layers causing Production Manager to crash.
• Cursor is misaligned when using multiple monitors.
• Joining text together causes text to get scrambled.
• Improved speed loading images and showing preview in Production Manager.
• Files with mesh effect not loading into Production Manager.
• Auto Serialization won't work with "tab" on keyboard.
• Roland BN-20 driver issues.
• Importing certain PDF file with DeviceN images incorrectly.
• Copy/Paste text from Outlook.
• "Ghost copies" in printed job while using Graphtec Barcode from RIP & PRINTdialogs
• Epson SC-F2100 problem to print layers.
• Cursor ghosting when dragging swatches if Windows scaling is applied.
• Improvement to gradient import from PDF files.
• Improvement to gradient imported with ai file.
• When applying Cut Page Boundaries for JIG jobs registration marks will not print.
• Cut Contour Mark effect is now generated correctly with large transparent images.
• Cutter selection for printers in Production Manager is now applied to RIP and Print Dialog.
• Automatic Tile Flip now flips also the cut jobs to match the print.
• Copied & pasted OLE bitmaps no longer disappear after saving the file.
• Copying and pasting an OLE bitmap no longer causes it to be resized.
• Uninstaller now removes desktop icons.
• Spot color gradients no longer change colors when printed when Soft-proofing is on.
• Certain effects didn’t keep the corner positions when resized.
• Splash screen now blends with the background correctly.
• License expiration date now shows local time.
• Fixed color issue printing certain PDF with transparency.
• Nesting in Flexi now applies the spacing
• Progress for "Download ICC" was showing even after cancelling for Epson SC-V7000.
• Cut jobs for rotated cut job 90 degree now shows matching preview with the print jobs.
• Cut contour paths are now created for open paths.
文件类型: txt Flexi_Win_24_0_0_4393_New_Printer_Drivers.txt (54.9 KB, 225 次查看)
nguyensign 当前离线   回复时引用此帖回复时引用此帖
右列 5 位会员因为此帖价值甚高向 nguyensign 表示感谢:
abcab (2024-10-02), elnice (2024-10-23), mr.gremli (2024-09-29), NIldo (2024-09-29)
旧 2024-04-20, 14:16   只看该作者   #2
guowei0 guowei0 当前离线
Uid: 496852
注册日期: 2016-01-17, 10:53
1 个帖子获得 2 次感谢
资产: 13金币
声望: 10 guowei0 向着好的方向发展
Uid: 496852
1 个帖子获得 2 次感谢
资产: 13金币
where to download this ?
guowei0 当前离线   回复时引用此帖回复时引用此帖
旧 2024-04-20, 14:31   只看该作者   #3
lvhonghui 的头像
lvhonghui lvhonghui 当前离线
级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时级别:115 | 在线时长:13843小时 | 升级还需:77小时
Uid: 40111
注册日期: 2007-04-12, 18:49
感谢: 345
210 个帖子获得 330 次感谢
现金: 371金币
资产: 371金币
声望: 10 lvhonghui 向着好的方向发展
lvhonghui 的头像
Uid: 40111
感谢: 345
210 个帖子获得 330 次感谢
现金: 371金币
资产: 371金币
支持的操作系统:
- Windows 11 (X64)
- Windows 10 32位(x86)或64位(x64)处理器
不建议在 Mac 上使用 Parallels 或 Bootcamp 进行安装,也不提供支持。
新功能:
- 可定制皮肤界面
- 艺术板对比度滑块
- 全屏支持
- 打开文件选项卡
- 显示使用的颜色样本
- 查看被隐藏的工具
- 在生产管理器中显示所选作业数量
- 新的 CutContour 样本
- 查找颜色工具
- 为蒙版/取消蒙版添加了键盘快捷键
- 添加了新模板
- Flexi 设计师中添加了完工工具
- 发送到 Rasterlink 时添加了更改文件名选项
- 发送到 Onyx 时添加了排除 CutContours 的选项
- 作业估算对话框现在可缩放
- 改进的 PDF 文件导入/导出
- 添加了“删除所选”工具
- 在 CMYK 色彩模式下进行栅格化的能力
- 设计师中的自定义除草路径
- 改进的作业信息字段
- 在生产管理器中预览 CutContour 路径
- 生产管理器中的全屏预览
- 作业嵌套的改进
- 作业属性中添加了一个缩放到页面按钮
- 鼠标悬停在作业上时显示文件名
- 标签和标记改进
- 匹配夹心作业中的图像大小
- 平滑透明度和预览的边缘
- 通过对象边界添加透明度
- 分配透明颜色
- 发送完整画布
- 生产管理器中添加了非常低的文件预览分辨率
- 添加更新通知
- 可变点权重配置
- 线性化验证
- 黑色生成
错误修复:
- 修复了处理具有许多页面和自定义切割颜色的 PDF 的错误。
- 作业属性对话框中具有透明度的 PDF 预览:RGB 转换为 CMYK。
- 添加大型 TIFF 文件会导致生产管理器崩溃。
- 修复了在生产管理器中打开具有额外专色通道的 TIFF 文件时出现的问题。
- 具有透明阴影的文本在转换为轮廓后不会分组。
- 将矩形转换为注册标记时,默认偏移值从 -10 更改为 0。
- 如果在生产管理器队列中更改列的顺序,作业名称不会显示。
- 向已嵌套组中添加作业时显示错误消息。
- 解决了多个本地化问题,特别是德语语言的问题。
- 为颜色配置调整对话框提供的建议输出值的准确性得到改善。
- 修复了为 Mutoh 1908W 添加驱动程序的问题
- 作业监视器显示作业名称的字符混乱。
- 在生产管理器中缺少切割锚点。
- 除草边框面板边距未保存。
- 如果取消勾选条形码选项,Summa OPOS XY2 标记将不会打印。
- SummaFlex 条形码 Y 线太细。
- 选择日语安装语言时,Install Manager 仍显示英语。
- 颜色调整未正确应用于 RGB 输出。
- 在非 Unicode 版本中创建的配置文件添加到 Unicode 版本的 Flexi 中时,媒体名称未保存。
- 无法打印到 HP DesignJet T730。
- 从 Photoshop PNG 文件导入的输入配置文件未导入到 Flexi 中。
- 从 22 sp3 中创建的预设在从 RIP 和打印对话框发送作业时导致 22 SP4 中出错。
- 在 Flexi 中调整大小后保存透明 PNG 将删除透明度。
- 使用在标签和标记页面中选择的颜色打印 Laser Cut Mark。
- 使用彩色带时,瓷砖之间添加的空白不正确
- 在使用页面和瓷砖嵌套和打印彩色带时,水平偏移不起作用。
- 在 GCC Jaguar V 183 上出现 HPGL/2 命令错误
- 在标签内部使用的字体大小和行间距不正确。
- 当作业长度长于媒体长度时,PM 崩溃。
- 嵌套作业时,Summa OPOS 标记被切割。
- 从以前的安装中未复制 Production Manager 首选项。
- 从 Illustrator pdf 复制/粘贴文本未正确导入。
- 使用标签并沿页面边框剪裁时的不一致行为
- 从预设加载后,对错误的颜色调整曲线进行验证和自动修正的添加。
- 更改 Fotoba Mark 和 Fotoba Horizontal Mark 之间的位置时,作业切换位置。
- 使用 Fotoba Marks 时标签的位置不正确。
- 从第三方应用程序导入的开放路径轮廓线未被识别。
- Myiro 色谱仪目标的改进。
- SVG 文件未正确导入。
- 插入符号对话框中未显示字体样式。
- 不允许在“定义夹具布局”字段中输入负值。
- 为 PDF 文件创建透明度在生产管理器中。
- Roland GR-540 在返回原点时。
- 将变量数据拆分到图层导致生产管理器
lvhonghui 当前离线   回复时引用此帖回复时引用此帖
旧 2024-04-21, 14:25   只看该作者   #4
Rianrian Rianrian 当前在线
级别:32 | 在线时长:1216小时 | 升级还需:5小时级别:32 | 在线时长:1216小时 | 升级还需:5小时
Uid: 701984
注册日期: 2021-02-01, 12:57
年龄: 25
感谢: 22
12 个帖子获得 29 次感谢
现金: -112金币
资产: -112金币
声望: 10 Rianrian 向着好的方向发展
Uid: 701984
年龄: 25
感谢: 22
12 个帖子获得 29 次感谢
现金: -112金币
资产: -112金币
作者: nguyensign 查看帖子
• Windows 11 (X64)
New Features
Skinable Interface
Full screen support
Open file tabs
Show used colo...
如何使用它????
Rianrian 当前在线   回复时引用此帖回复时引用此帖
旧 2024-04-21, 19:56   只看该作者   #5
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
对眼
作者: Rianrian 查看帖子
如何使用它????
我不知道
旧 2024-04-27, 02:55   只看该作者   #6
colorproofart colorproofart 当前离线
级别:35 | 在线时长:1418小时 | 升级还需:22小时级别:35 | 在线时长:1418小时 | 升级还需:22小时级别:35 | 在线时长:1418小时 | 升级还需:22小时级别:35 | 在线时长:1418小时 | 升级还需:22小时级别:35 | 在线时长:1418小时 | 升级还需:22小时
Uid: 121730
注册日期: 2009-10-25, 16:45
51 个帖子获得 245 次感谢
现金: 780金币
资产: 1780金币
声望: 14 colorproofart 向着好的方向发展
Uid: 121730
51 个帖子获得 245 次感谢
现金: 780金币
资产: 1780金币
能不能把安装文件放一个出来啊!!!!!
colorproofart 当前离线   回复时引用此帖回复时引用此帖
旧 2024-04-27, 10:03   只看该作者   #7
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
对眼
作者: colorproofart 查看帖子
能不能把安装文件放一个出来啊!!!!!
Sorry, I don't have it yet.
旧 2024-09-29, 13:34   只看该作者   #8
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
帖子
Flexi 24 SP1 (24.1.0 Build 4510)
文件类型: pdf SAi Production Suite 24 SP1 Readme.pdf (3.82 MB, 52 次查看)
旧 2024-09-29, 16:15   只看该作者   #9
mr.gremli mr.gremli 当前离线
级别:9 | 在线时长:119小时 | 升级还需:21小时级别:9 | 在线时长:119小时 | 升级还需:21小时级别:9 | 在线时长:119小时 | 升级还需:21小时
Uid: 722439
注册日期: 2022-08-28, 15:54
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
声望: 10 mr.gremli 向着好的方向发展
Uid: 722439
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
Is there medicine al ready? How fast
mr.gremli 当前离线   回复时引用此帖回复时引用此帖
旧 2024-09-30, 09:43   只看该作者   #10
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
难过
作者: mr.gremli 查看帖子
Only information, don't have any others that people would like to have
旧 2024-10-01, 01:13   只看该作者   #11
Uid: 722439
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
Uid: 722439
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
作者: nguyensign 查看帖子
I wasn't telling you this, but because of what Camo had put on
旧 2024-10-01, 10:54   只看该作者   #12
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
Uid: 500420
感谢: 118
119 个帖子获得 202 次感谢
现金: 1936金币
资产: 1936金币
对眼
作者: mr.gremli 查看帖子
That guy is pirated software seller and all what he posted here are not really useful at all. It looks that guy was gone
旧 2024-10-02, 13:56   只看该作者   #13
网鱼儿 网鱼儿 当前离线
级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时级别:31 | 在线时长:1148小时 | 升级还需:4小时
Uid: 710334
注册日期: 2021-08-23, 09:51
18 个帖子获得 20 次感谢
现金: 117金币
资产: 617金币
声望: 10 网鱼儿 向着好的方向发展
网鱼儿 网鱼儿 当前离线
Uid: 710334
18 个帖子获得 20 次感谢
现金: 117金币
资产: 617金币
声望: 10 网鱼儿 向着好的方向发展
论坛上PP热度这么高的吗,难道这里没什么人用colorgate23吗,看到某平台上好多人再卖这个
网鱼儿 当前离线   回复时引用此帖回复时引用此帖
旧 2024-10-02, 16:24   只看该作者   #14
贝吉塔 的头像
贝吉塔 贝吉塔 当前离线
级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时级别:47 | 在线时长:2426小时 | 升级还需:70小时
Uid: 520259
注册日期: 2016-06-12, 19:44
感谢: 31
79 个帖子获得 93 次感谢
现金: 142金币
资产: 142金币
声望: 10 贝吉塔 向着好的方向发展
贝吉塔 贝吉塔 当前离线
贝吉塔 的头像
Uid: 520259
感谢: 31
79 个帖子获得 93 次感谢
现金: 142金币
资产: 142金币
声望: 10 贝吉塔 向着好的方向发展
某平台上PP22也不少人在卖,你没看到上边有某平台上的卖家在问安装包吗?
贝吉塔 当前离线   回复时引用此帖回复时引用此帖
旧 2024-10-05, 18:53   只看该作者   #15
Uid: 722439
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
Uid: 722439
7 个帖子获得 7 次感谢
现金: 53金币
资产: 53金币
There are already people who sold version 24.1
所有时间均为 +8, 现在的时间是 2025-12-01 17:31.
