2024-04-17, 19:51 | #1 | ||
123123.gif var scriptID = "用符号替换对象 "; var numSelectedItems = 0; var docRef = app.activeDocument; var selectedSymbol = null; // find a symbol in the selection (first symbol found is used) selectedSymbol = getSymbolInSelection(docRef, selectedSymbol); //$.write(selectedSymbol); // script will not work unless selection includes a symbol var symbolName = '未选择符号,脚本将运行失败!'; if (selectedSymbol){ symbolName = selectedSymbol.name; } // Make a simple interface box var box = new Window('dialog', scriptID); box.alignChildren='left'; // headline box.add('statictext', undefined, "符号替换对象"); // stats panel: display selected object count and symbol box.statsPanel = box.add('panel', undefined, "信息"); box.statsPanel.alignChildren='left'; box.statsPanel.group0 = box.statsPanel.add('group', undefined ); box.statsPanel.add('statictext', undefined, "已选符号名称: " + symbolName); box.statsPanel.add('statictext', undefined, "选定的对象数: " + numSelectedItems+"个"); // options panel box.optionsPanel = box.add('panel', undefined, "选项"); box.optionsPanel.alignChildren='left'; // scale checkbox, default: false var scaleCheck = box.optionsPanel.add('checkbox', undefined, "缩放符号以匹配原始对象?"); scaleCheck.value=false; // clear originals checkbox; default true var clearCheck = box.optionsPanel.add('checkbox', undefined, "清除原始对象?"); clearCheck.value=false; //true // ok and cancel buttons group box.buttons = box.add('group', undefined ); box.buttons.orientation='row'; box.buttons.add('statictext', undefined, "运行脚本"); var okButton = box.buttons.add('button',undefined, "确定", {name:'ok'}); var closeButton = box.buttons.add('button',undefined, "取消", {name:'close'}); // Ok button function okButton.onClick = function(){ var scaleSymbol = scaleCheck.value; var clearOriginals = clearCheck.value; if (selectedSymbol == null) {alert(scriptID + "\n" + "请选择一个符号", scriptID, true); box.close(); } else { replaceWithSymbol(docRef, selectedSymbol, clearOriginals, scaleSymbol); box.close(); } // box.ok(); } closeButton.onClick = function(){ box.close(); } box.show() function replaceWithSymbol(docRef, selectedSymbol, clearOriginals, scaleSymbol){ // loop through remaining selection and replace them with symbols on active layer // clear originals if desired for(i=0;i<docRef.selection.length;i++){ var currObj=docRef.selection[i]; // $.write(currObj.layer); var currLeft=currObj.left; var currTop=currObj.top; var currWidth=currObj.width; var currHeight=currObj.height; var currInstance=docRef.activeLayer.symbolItems.add(selectedSymbol); if (scaleSymbol){ currInstance.width*=currHeight/currInstance.height; currInstance.height=currHeight; currInstance.left=currLeft; currInstance.top=currTop; } else { currInstance.position = Array( currObj.position[0]+currWidth/2 - currInstance.width/2, currObj.position[1]-currHeight/2 + currInstance.height/2 ); } currObj.selected = false; currInstance.selected = true; if (clearOriginals) {currObj.remove();} } redraw(); if (numSelectedItems > 0) { // alert(scriptID + "\n" + numSelectedItems + " " + ((numSelectedItems == 1)?"object":"objects") + " in total", scriptID, true); } else { alert(scriptID + "\n" + "请选择对象", scriptID, true); return; } } function getSymbolInSelection(docRef, selectedSymbol) { // loop through selected items to get the desired symbol and deselect this item var symbolLayer = null; for(i=0;i<docRef.selection.length;i++){ if(docRef.selection[i].symbol) { symbolLayer = docRef.selection[i].layer; selectedSymbol = docRef.selection[i].symbol; docRef.selection[i].selected = false; numSelectedItems -= 1; } numSelectedItems += 1; } return selectedSymbol; } |
回复时引用此帖 |
2024-06-09, 16:35 | 只看该作者 #7 | ||
/* Program version: Adobe Illustrator CC+ */ var scriptName = 'ReplaceItems-2', settingFile = { name: scriptName + '__setting.json', folder: Folder.myDocuments + '/Scripts/' }; // DIALOG var dialog = new Window("dialog"); dialog.text = "Replace objects"; dialog.orientation = "column"; dialog.alignChildren = ["center", "top"]; dialog.spacing = 10; // MAINGROUP var MainGroup = dialog.add("group"); MainGroup.orientation = "row"; MainGroup.alignChildren = ["left", "fill"]; MainGroup.spacing = 10; MainGroup.margins = 0; // FIRSTCOLUMN var FirstColumn = MainGroup.add("panel"); FirstColumn.text = ""; FirstColumn.preferredSize.width = 175; FirstColumn.orientation = "column"; FirstColumn.alignChildren = ["left", "top"]; FirstColumn.spacing = 8; FirstColumn.margins = [10, 5, 0, 10]; var saveOriginalCheckbox = FirstColumn.add("checkbox"); saveOriginalCheckbox.text = "Save original"; //saveOriginalCheckbox.value = true; var copyColorsCheckbox = FirstColumn.add("checkbox"); copyColorsCheckbox.text = "Copy fill color (for simple objects)"; var ignoreStroke = FirstColumn.add("checkbox"); ignoreStroke.text = "Ignore stroke"; //ignoreStroke.value = true; try { if ( selection[0].typename=="GroupItem"){ //ignoreStroke.enabled = false; ignoreStroke.text = "Ignore stroke of the replaced objects"; } }catch (e){ alert ("Plese, select some objects"); } var TopObj= FirstColumn.add("checkbox"); TopObj.text = "Replace with the top object"; var ResizeStroke= FirstColumn.add("checkbox"); ResizeStroke.text = "Resize stroke"; // SECONDCOLUMN var SecondColumn = MainGroup.add("panel"); SecondColumn.text = "Size"; SecondColumn.orientation = "column"; SecondColumn.alignChildren = ["left", "top"]; SecondColumn.spacing = 8; SecondColumn.margins = [10, 15, 10, 10]; var NochangeCheckbox = SecondColumn.add("radiobutton"); NochangeCheckbox.text = "No changes"; //NochangeCheckbox.value = true; var fitInWidthCheckbox = SecondColumn.add("radiobutton"); fitInWidthCheckbox.text = "Fit width"; //fitInWidthCheckbox.value = false; var fitInHeightCheckbox = SecondColumn.add("radiobutton"); fitInHeightCheckbox.text = "Fit height"; //fitInHeightCheckbox.value = false; var copySize= SecondColumn.add("radiobutton"); copySize.text = "Copy"; // THIRDCOLUMN var ThirdColumn = MainGroup.add("panel"); ThirdColumn.text = "Alignment"; ThirdColumn.preferredSize.width = 100; ThirdColumn.orientation = "row"; ThirdColumn.alignChildren = ["left", "top"]; ThirdColumn.spacing = 22; ThirdColumn.margins = [10, 17, 0, 11]; ThirdColumn.alignment = ["left", "fill"]; // GROUP1 var group1 = ThirdColumn.add("group"); group1.orientation = "column"; group1.alignChildren = ["left", "center"]; group1.spacing = 19; group1.margins = 0; var AlignTopLeft = group1.add("radiobutton"); var AlignCenterLeft = group1.add("radiobutton"); var AlignBottomLeft = group1.add("radiobutton"); // GROUP2 var group2 = ThirdColumn.add("group"); group2.orientation = "column"; group2.alignChildren = ["left", "center"]; group2.spacing = 19; group2.margins = 0; var AlignTopCenter = group2.add("radiobutton"); var AlignCenterCenter = group2.add("radiobutton"); var AlignBottomCenter = group2.add("radiobutton"); // GROUP3 var group3 = ThirdColumn.add("group"); group3.orientation = "column"; group3.alignChildren = ["left", "center"]; group3.spacing = 19; group3.margins = 0; var AlignTopRight = group3.add("radiobutton"); var AlignCenterRight = group3.add("radiobutton"); var AlignBottomRight = group3.add("radiobutton"); AlignCenterCenter.value = true; var myRadioButtons = []; AlignTopLeft.onClick = toggleRadioButtons; myRadioButtons.push(AlignTopLeft); AlignCenterLeft.onClick = toggleRadioButtons; myRadioButtons.push(AlignCenterLeft); AlignBottomLeft.onClick = toggleRadioButtons; myRadioButtons.push(AlignBottomLeft); AlignTopCenter.onClick = toggleRadioButtons; myRadioButtons.push(AlignTopCenter); AlignCenterCenter.onClick = toggleRadioButtons; myRadioButtons.push(AlignCenterCenter); AlignBottomCenter.onClick = toggleRadioButtons; myRadioButtons.push(AlignBottomCenter); AlignTopRight.onClick = toggleRadioButtons; myRadioButtons.push(AlignTopRight); AlignCenterRight.onClick = toggleRadioButtons; myRadioButtons.push(AlignCenterRight); AlignBottomRight.onClick = toggleRadioButtons; myRadioButtons.push(AlignBottomRight); function toggleRadioButtons() { for (var i = 0, il = myRadioButtons.length; i < il; i ++) { if (myRadioButtons[i] !== this) { myRadioButtons[i].value = false; } } this.value = true; } // FINALBUTTONS //var divider2 = dialog.add("panel"); //divider2.alignment = "fill"; var FinalButtons = dialog.add("group"); FinalButtons.orientation = "row"; FinalButtons.alignChildren = ["left", "center"]; FinalButtons.spacing = 10; FinalButtons.margins = 0; var cancel = FinalButtons.add("button", undefined, undefined, {name: "Cancel"}); cancel.text = "Cancel"; cancel.justify = "center"; cancel.onClick = function() { dialog.close(); } var ok = FinalButtons.add("button", undefined, undefined, {name: "Ok"}); ok.text = "Ok"; ok.justify = "center"; ok.onClick = startAction; ok.active = true; var progressBar = dialog.add('progressbar', [0, 0, 110, 5]), progressBarCounter = 100; progressBar.value = 0; progressBar.minvalue = 0; progressBar.maxvalue = progressBarCounter; /////// //FUNCTIONS// function setFillColor(items, color) { if (color) { var i = items.length; if (i) while (i--) { if (items[i].typename === 'GroupItem') { setFillColor(items[i].pageItems, color); } else if (items[i].typename === 'CompoundPathItem') { if (items[i].pathItems.length) items[i].pathItems[0].fillColor = color; } else if (items[i].typename === 'PathItem') { items[i].fillColor = color; } } } } function getFillColor(items) { var i = items.length, gc; if (i) while (i--) { if (items[i].typename === 'GroupItem' && (gc = getFillColor(items[i].pageItems))) return gc; else if (items[i].typename === 'CompoundPathItem' && items[i].pathItems.length) return items[i].pathItems[0].fillColor; else if (items[i].typename === 'PathItem') return items[i].fillColor; } } ///////////////////////// function startAction() { if (selection.length) { items = selection, i = items.length; progressBarCounter = progressBar.maxvalue / i; var nodes = selection[0]; if (TopObj.value == false) { selection = null; app.paste(); nodes = selection[0]; selection = null; } //// while (i--) { var err = null; var item = items[i]; var node = nodes.duplicate(item, ElementPlacement.PLACEBEFORE); if (node.typename != "GroupItem"){ var nd_s =ignoreStroke.value? 0:(node.visibleBounds[1]-node.geometricBounds[1])*2; } else { var nd_Bounds = FindBounds(node); var nd_height = nd_Bounds[1] - nd_Bounds[3]; var nd_width = nd_Bounds[2] - nd_Bounds[0]; // var nd_height = nd_Bounds[5] - nd_Bounds[7]; //var nd_width = nd_Bounds[6] - nd_Bounds[4]; } ////if ignoreStroke true calculate parameters of geometric bounds if (ignoreStroke.value == true){ if (item.typename != "GroupItem") { var it_top = item.geometricBounds[1]; var it_left = item.geometricBounds[0]; var it_width = item.geometricBounds[2] - item.geometricBounds[0]; var it_height = item.geometricBounds[1] - item.geometricBounds[3]; } else if (item.typename == "GroupItem") { var it_Bounds = FindBounds(item); var it_top = it_Bounds[1]; var it_left = it_Bounds[0]; var it_width = it_Bounds[2] - it_Bounds[0]; var it_height = it_Bounds[1] - it_Bounds[3]; } ////if ignoreStroke false calculate parameters of visible bounds } else if (ignoreStroke.value == false) { if (item.typename != "GroupItem") { var it_top = item.visibleBounds[1]; var it_left = item.visibleBounds[0]; var it_width = item.visibleBounds[2] - item.visibleBounds[0]; var it_height = item.visibleBounds[1] - item.visibleBounds[3]; }else if (item.typename == "GroupItem"){ var it_Bounds = FindBounds(item); var it_top = it_Bounds[5]; var it_left = it_Bounds[4]; var it_width = it_Bounds[6] - it_Bounds[4]; var it_height = it_Bounds[5] - it_Bounds[7]; } } ////////////////////////// ///change size/// var newStroke, newHeight, newWidth; newStroke = newHeight = newWidth = 100; if (fitInHeightCheckbox.value) { //if node is vertical line if (node.width == 0) { newStroke = newHeight = it_height * 100 / node.height; newWidth = 100; //if node is horisontal line } else if (node.height == 0) { newStroke = it_height * 100 / node.strokeWidth; newHeight = newWidth = 100; //if node isnot a group } else if (it_height != 0) { if (node.typename != "GroupItem") { newWidth = newHeight = newStroke = ResizeStroke.value ? (it_height / (node.height + nd_s)) * 100 : ((it_height - nd_s) / node.height) * 100; //if node is a group } else if (node.typename == "GroupItem") { newWidth = newHeight = newStroke = it_height / nd_height * 100; } } else { err = "There is an object with zero height"; } } else if (fitInWidthCheckbox.value) { //if node is vertical line if (node.width == 0) { newStroke = it_width * 100 / node.strokeWidth; newHeight = 100; //if node is horisontal line } else if (node.height == 0) { newStroke = newWidth = it_width * 100 / node.width; newHeight = 100; //if node is not a group } else if (it_width != 0) { if (node.typename != "GroupItem" & node.height != 0 & node.width != 0) { newWidth = newHeight = newStroke = ResizeStroke.value ? (it_width / (node.width + nd_s)) * 100 : ((it_width - nd_s) / node.width) * 100; //if node is a group } else if (node.typename == "GroupItem") { newWidth = newHeight = newStroke = it_width / nd_width * 100; } } else { err = "There is an object with zero width"; } } else if (copySize.value) { //if node is vertical line if (node.width == 0) { newWidth = 100; newHeight = it_height * 100 / node.height; newStroke = it_width * 100 / node.strokeWidth; //if node is horisontal line } else if (node.height == 0) { newWidth = it_width * 100 / node.width; newHeight = 100; newStroke = it_height * 100 / node.strokeWidth; } else if (it_width != 0 | it_height != 0) { //if node is not a group if (node.typename != "GroupItem") { newWidth = ((it_width - nd_s) / node.width) * 100; newHeight = ((it_height - nd_s) / node.height) * 100; newStroke = 100; //if node is a group } else if (node.typename == "GroupItem") { newHeight = it_height / nd_height * 100; newWidth = it_width / nd_width * 100; newStroke = undefined; /// ? } } else { err = "There is an object with zero width or height"; } } node.resize( scaleX=newWidth, scaleY= newHeight, changePositions= undefined, changeFillPatterns= undefined, changeFillGradients= undefined, changeStrokePattern= undefined, changeLineWidths = ResizeStroke.value ? newStroke : 100); // end changing size /// calculate node parametres if (node.typename == "GroupItem") { var nd_Bounds = FindBounds(node); var nd_top = nd_Bounds[1]; var nd_left = nd_Bounds[0]; var nd_width = nd_Bounds[2] - nd_Bounds[0]; var nd_height = nd_Bounds[1] - nd_Bounds[3]; var nd_str = 0; } else if (node.typename != "GroupItem") { if (ignoreStroke.value == true) { var nd_str = node.visibleBounds[1] - node.geometricBounds[1]; var nd_width = node.geometricBounds[2] - node.geometricBounds[0]; var nd_height = node.geometricBounds[1] - node.geometricBounds[3]; var nd_top = node.geometricBounds[1]; var nd_left = node.geometricBounds[0]; if (node.height == 0 || node.width == 0) { nd_str = 0; nd_height = node.visibleBounds[1] - node.visibleBounds[3]; nd_width = node.visibleBounds[2] - node.visibleBounds[0]; } } else if (ignoreStroke.value == false) { var nd_str = 0; var nd_width = node.visibleBounds[2] - node.visibleBounds[0]; var nd_height = node.visibleBounds[1] - node.visibleBounds[3]; var nd_top = node.visibleBounds[1]; var nd_left = node.visibleBounds[0]; } } ////////////////////////// ///change position/// //if node is clipping mask if (node.typename == "GroupItem"){ ///TOP if (AlignTopLeft.value | AlignTopRight.value | AlignTopCenter.value) { node.top = node.top - (nd_top - it_top) + nd_str; } if (AlignCenterLeft.value | AlignCenterRight.value | AlignCenterCenter.value) { node.top = node.top - ((nd_top - nd_height / 2) - (it_top - it_height / 2)) + nd_str; } if (AlignBottomLeft.value | AlignBottomRight.value | AlignBottomCenter.value) { node.top = node.top - ((nd_top - nd_height) - (it_top - it_height)) + nd_str; } ///LEFT if (AlignTopLeft.value | AlignCenterLeft.value | AlignBottomLeft.value) { node.left = node.left - (nd_left - it_left) - nd_str; } if (AlignTopCenter.value | AlignCenterCenter.value | AlignBottomCenter.value) { node.left = node.left + ((it_left + it_width / 2) - (nd_left + nd_width / 2)) - nd_str; } if (AlignTopRight.value | AlignCenterRight.value | AlignBottomRight.value) { node.left = node.left + ((it_left + it_width) - (nd_left + nd_width)) - nd_str; } /// } else { ///TOP if (AlignTopLeft.value | AlignTopRight.value | AlignTopCenter.value) { node.top = it_top + nd_str; } if (AlignCenterLeft.value | AlignCenterRight.value | AlignCenterCenter.value) { node.top = it_top + (nd_height - it_height) / 2 + nd_str; } if (AlignBottomLeft.value | AlignBottomRight.value | AlignBottomCenter.value) { node.top = it_top + nd_height - it_height + nd_str; } ///LEFT if (AlignTopLeft.value | AlignCenterLeft.value | AlignBottomLeft.value) { node.left = it_left - nd_str; } if (AlignTopCenter.value | AlignCenterCenter.value | AlignBottomCenter.value) { node.left = it_left - (nd_width - it_width) / 2 - nd_str; } if (AlignTopRight.value | AlignCenterRight.value | AlignBottomRight.value) { node.left = it_left - (nd_width - it_width) - nd_str; } } ///////////////////////////// if (copyColorsCheckbox.value) { try { setFillColor([node], getFillColor([item])); } catch (e) { alert(e + '\n' + e.line) } } if (err != null) { node.remove(); } if (!saveOriginalCheckbox.value) { if (item.clipping == true) { item = item.parent; } item.remove(); } progressBar.value += progressBarCounter; dialog.update(); } //end while if (saveOriginalCheckbox.value == true & TopObj.value == true) { node.remove(); } if (TopObj.value == false) { nodes.remove(); } } dialog.close(); if (err!=null) alert (err); } // end StartAction /////////////////////// /* //////////////////////////////Get object size-support mask function/////////////////////////////////// */ function FindBounds(obj) { var Bounds = new Array(); GET_Bounds(obj); var v_left = new Array(); var g_left = new Array(); var v_top = new Array(); var g_top = new Array(); var v_right = new Array(); var g_right = new Array(); var v_bottom = new Array(); var g_bottom = new Array(); for (var i = 0; i < Bounds.length; i += 1) { g_left[i] = Bounds[i].geometricBounds[0]; v_left[i] = Bounds[i].visibleBounds[0]; g_top[i] = Bounds[i].geometricBounds[1]; v_top[i] = Bounds[i].visibleBounds[1]; g_right[i] = Bounds[i].geometricBounds[2]; v_right[i] = Bounds[i].visibleBounds[2]; g_bottom[i] = Bounds[i].geometricBounds[3]; v_bottom[i] = Bounds[i].visibleBounds[3]; } var v_L = MIN_IN_ARRAY(v_left); var g_L = MIN_IN_ARRAY(g_left); var v_T = MAX_IN_ARRAY(v_top); var g_T = MAX_IN_ARRAY(g_top); var v_R = MAX_IN_ARRAY(v_right); var g_R = MAX_IN_ARRAY(g_right); var v_B = MIN_IN_ARRAY(v_bottom); var g_B = MIN_IN_ARRAY(g_bottom); return [g_L, g_T, g_R, g_B, v_L, v_T, v_R, v_B]; function GET_Bounds(obj) { if (IS_CLIP(obj)) { Bounds.push(obj.pageItems[0]); return; } if (obj.constructor.name == "GroupItem") { try { var N_sub_obj = obj.pageItems.length; for (var i = 0; i < N_sub_obj; i += 1) { GET_Bounds(obj.pageItems[i]); } } catch (error) {} return; } Bounds.push(obj); return; } } //////////////// function IS_CLIP(obj) { try { if (obj.constructor.name == "GroupItem") { if (obj.clipped) { return true; } } } catch(error) { } return false; } function MAX_IN_ARRAY(the_array) { var MAX = the_array[0]; for (var i = 0; i < the_array.length; i += 1) { if (the_array[i] > MAX) { MAX = the_array[i] } } return MAX; } function MIN_IN_ARRAY(the_array) { var MIN = the_array[0]; for (var i = 0; i < the_array.length; i += 1) { if (the_array[i] < MIN) { MIN = the_array[i] } } return MIN; } ////////////////////// function saveSettings() { var $file = new File(settingFile.folder + settingFile.name), data = [ saveOriginalCheckbox.value, copyColorsCheckbox.value, ignoreStroke.value, NochangeCheckbox.value, fitInWidthCheckbox.value, fitInHeightCheckbox.value, copySize.value, TopObj.value, ResizeStroke.value ].toString(); $file.open('w'); $file.write(data); $file.close(); } function loadSettings() { var $file = File(settingFile.folder + settingFile.name); if ($file.exists) { try { $file.open('r'); var data = $file.read().split('\n'), $main = data[0].split(','); saveOriginalCheckbox.value = ($main[0] === 'true'); copyColorsCheckbox.value = ($main[1] === 'true'); ignoreStroke.value = ($main[2] === 'true'); NochangeCheckbox.value = ($main[3] === 'true'); fitInWidthCheckbox.value = ($main[4] === 'true'); fitInHeightCheckbox.value = ($main[5] === 'true'); copySize.value = ($main[6] === 'true'); TopObj.value= ($main[7] === 'true'); ResizeStroke.value= ($main[8] === 'true'); } catch (e) {} $file.close(); } } dialog.onClose = function() { saveSettings(); return true; } function checkSettingFolder() { var $folder = new Folder(settingFile.folder); if (!$folder.exists) $folder.create(); } checkSettingFolder(); loadSettings(); dialog.center(); dialog.show(); |
回复时引用此帖 |
