| 论坛帮助 |
| 日历事件 |
#1 | ||
自印度的六开胶印机(Autoprint) Autoprint 1520 FL and Knight Autoprint 1520 FL (frontloading) with a maximum paper size of 15" x 20", can be ideally utilized in letter press and big offset houses, where in short run and low end jobs can be undertaken. The Autoprint 1520 FL is the ideal upgradation solution for present users as well, since it enables printing using both direct offset master as well as plate. The 'Plug 'N' Print' capabilities of the machine are complemented by a country-wide support network and Autoprint's highly customer focussed approach to marketing. A world - class AC drive as standard feature enables use of rugged 3 phase squirrel cage motors resulting in low noise and power consumption. All switchgears are of high quality. Low weight chain gripper assembly helps improve gripper performance and fewer setting changes. ![]() Paper Guides On Feeder Table Control Panel Three Cylinder - Chain Delivery Front Loading (FL) Features Side Lay Registration Oscillation System Ductor Assembly Centralised Lubrication System Maximum paper size Minimum paper size Printing area (Maximum) Blanket Gripper margin on plate Gripper margin on paper Gripper bite Paper thickness Plate thickness Direct offset master thickness Inking unit Dampening unit Main drive motor Pump Motor Speed Physical dimensions (L x W x H) Net weight Gross weight Lubrication ![]() ![]() ![]() ![]() ![]() Autoprint has been the Indian pioneer in the manufacture of sophisticated mini-offset printers and other machines for the printing industry. Built to offer high quality results with economy and reliability, the machines have been designed to meet the requirement for quality short run jobs. Utilizing technology developed by Autoprint's own R & D Centre, the machines have proved their worth not only in India but abroad as well. The 'Plug 'N' Print' capabilities of the machine are complemented by a country-wide support network and Autoprint's highly customer focused approach to marketing. The quality of large offset. The features of large offset. The price of mini offset. Presenting Autoprint Knight: the machine you helped design! You wanted a machine that could elevate your printing jobs from cut-colour to multi-colour, from mediocre to high quality, from limited benefits to advanced features Your needs and your feedback have played a major role in the creation of Autoprint Knight: a single colour mini offset machine that can offer you excellent multi-colour quality at affordable prices. Autoprint Knight is an ideal upgradable solution for small offset printers across the country - and the world! Autoprint Knight comes to you with most of the features of large offset. So you can get the quality of large offset in small format printing. In fact, it is for the first time, that a small offset machine has been packed with so many sophisticated features! ![]() Inking & Dampening System Control Panel Bellow Suckers, Ball Shoe Guides Delivery Stacker Pressure Adjusting Scale Pull Type Side Lay Plate Clamp Swing Type Ink Duct Front Loading Three Cylinder Design Chain Delivery System Paper Guides on Feeder Table for easy adjustment and feeding of various paper stocks and sizes A hi-tech Double Sheet Detector No Sheet Detector Gear-driven Oscillators Large Ink Fountain Roller of 60 mm dia and a mechanism of fine control with 8 steps Maximum Paper SizeMinimum Paper SizePrinting Area (Maximum)BlanketGripper Margin on PlateGripper Margin on PaperGripper BitePlate ThicknessPaper ThicknessInking UnitDampening UnitMain Drive MotorCompressor Pump MotorControl PanelSpeedLubricationPhysical Dimensions L x W x H Net WeightGross Weight 380 x 508 mm100 x 150 mm357 x 490 mm4 Ply Rubber blanket, 1.9 mm thickness32 mm9 mm4 mm0.2 mm (Direct Offset Master can also be used)30 to 300 gsm15 Rollers including 4 Oscillators and 3 Form Rollers5 Rollers including 1 Oscillator and 2 Form Rollers1 HP AC 3 Phase (Connectable to Single Phase Power Supply)1 HP AC Single PhaseLatest productivity monitoring type1500 to 6000 iphCentralised Lubrication system1700 x 1340 x 1400 mm1200 Kgs. Approximately1500 Kgs. Approximately 380 x 508 mm 125 x 175 mm 350 x 485 mm 4 Ply rubber blanket, 1.9 mm thick 32 mm (1.25") 13 mm 4 mm 30 to 300 gsm 0.05 to 0.2 mm 100 micron 11 Rollers, 3 Oscillators, 2 Form Rollers 4 Rollers, 1 Oscillator, 1 Form Roller 1 HP AC 3 phase (connectable in single phase power supply) 1 HP AC single phase 1500 to 5000 iph 1700 x 1200 x 1400 mm 1100 Kg approx. (un packed) 1400 Kg approx. (packed) Centralised lubrication system |
| 发表新主题 关闭主题 |
| 主题 | 论坛 | |||
| 我购一台华光六开胶印机, 請給意見 | ◆- 普通 & 高保真胶印技术 | |||
| 我购一台东航六开胶印机, 請給意見 | ◆- 普通 & 高保真胶印技术 | |||
| 转让一台日本良明480K-NP六开打码胶印机 | ◆- 印刷企业经营与管理 | |||
| 转让一台日本良明480K-NP六开打码胶印机 | ◆- 普通 & 高保真胶印技术 | |||
