◆- Adobe 设计软件应用 Photoshop、Illustrator、Indesign、FrameMaker、Indesign Server、Pagemaker 等adobe公司出品的平面设计类软件应用交流。
旧 2005-02-04, 20:35     #1
jz979 jz979 当前离线
Uid: 385
注册日期: 2004-07-01, 12:00
声望: 10 jz979 向着好的方向发展
jz979 jz979 当前离线
Uid: 385
默认 InDesign 插件知多少
A lowly apprentice production, inc.
http://www.alap.com
ALAP’s classic “stand-a-lone” plug-ins have been revamped and combined with exciting new features designed to expedite common publishing tasks, as well as simplify the more daunting ones. Targeted to creative professionals at every level, InTools brings innovative and timesaving features to Adobe InDesign.
“As a DTP operator for the last 10 years, I have never seen such a productive package for such a low price. Now the last rebels defending QuarkXPress have no more excuses; with InTools there are no missing features in InDesign!”
—Branislav Milic, Editor
InBooklet
A maintenance release to InBooklet version 2.1.4, an imposition Plug-In for Adobe InDesign, is now available. This version contains fixes to some known issues and is available free of charge to previous InBooklet 2.x users.
Imposer Pro
Imposer Pro is a plug-in for Adobe InDesign that imposes document pages into printer flats. Imposer Pro offers six sheet types (2-Up, 4-Up, 8-Up, 2-Up Consecutive, 3-Up Consecutive, and 4-Up Consecutive), four binding types (Saddle Stitch, Perfect Bound, Stacked, and None) and five imposition types (Standard, Work and Turn, Work and Tumble, Split Web, and Sheet Wise). To meet all your imposition needs — such as using different imposition methods for the same document — you can choose which pages to impose and how many signatures to create.
InEffects
The InEffects plug-in brings all the special effects power of a dedicated illustration or image-editing program directly to Adobe InDesign. With InEffects, you can apply any combination of sophisticated effects such as drop shadows, inner shadows, inner glows, outer glows, bevels, and embossing to any InDesign page object(s). You can save effects as reusable InEffects styles, which can be updated at any time.
InTools
Whatever the InDesign users’ needs are geared towards — layout, design, or production — InTools has something useful.
InTools includes:
InStarburst
Create attention-getting customizable starbursts that are completely editable InDesign objects with InStarburst.
InItemMarks
Use InItemMarks for a quick and convenient way to place custom crop and registration marks for both objects and pages.
InPathfinder
Combine multiple objects into single objects to create compound shapes with InPathfinder. Operations include Combine, Add, Subtract, and more.
InPrint
Select a portion of an InDesign page to either print or save to disk with InPrint. File formats include HTML, EPS, Adobe PDF, TIF and JPEG.
InNudge
Interactively adjust the position and rotation of objects and pictures with the intuitive InNudge palette.
InModify
Consolidate all the options for modifying selected objects or groups into a single context sensitive dialog box. With InModify, procedures that take several different palettes - such as applying a stroke, fill and text inset now require only a single dialog box.
jz979 当前离线
旧 2005-02-04, 20:36   只看该作者   #2
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Arcadia,Inc.
http://www.offshore-software.ru/downloads/pastefiles/
Paste Files Plug-In
The Paste Files command is an alternative to the Place command of Adobe InDesign. With Paste Files, you can specify the files to be placed by copying them to the Clipboard in Finder — you neither need to use the standard Open dialog nor have to deal with drag and drop from Finder. Just choose Copy in Finder, and then choose Paste Files in Adobe InDesign.
Paste Files handles all the files in the clipboard — it’s not limited to a single file as the built-in Place command.
The Paste Files behaves differently depending on whether there is only one file in the clipboard or more than one.
jz979 当前离线
旧 2005-02-04, 20:37   只看该作者   #3
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Cacidi Systems
http://www.cacidi.com
Cacidi Cropmarks
Cropmarks provides you with the possibility of creating high-quality crop and bleed marks on one or more than one selected object.
Cacidi Contact Sheet Pro
Contact Sheet provides you with the possibility of creating high-quality contact sheets and picture packages that take full advantage of Adobe InDesign?’s color management and its possibilities in print and export.
Cacidi Q-to-InDesign Batch
Q-to-InDesign Batch provides you with the possibility of automatically converting your old QuarkXPress and Adobe PageMaker? files into Adobe InDesign format.
Cacidi Catalog Extreme 4.0 Basic
Catalog Extreme 4.0 Basic is the fourth generation of the market’s most flexible ad and catalog production tool. You can create pages and turn them into complete ads, brochures, or catalogs using modules that consist of text, image, and decoration fields. All text is automatically stylized and images are automatically scaled via basic adjustment settings.
Cacidi Catalog Extreme 4.0 Update
In combination with Catalog Extreme 4.0 Basic, the Update plug-in allows you to update the document after you have created it. You can use this feature to update prices in your document and e.g. insert multiple languages in the document.
Cacidi Catalog Extreme PageQue 4.0
In combination with Catalog Extreme 4.0 Basic, the Extreme 4.0 PageQue plug-in allows you to design multiple pages or put together a brochure or a catalog based on the pages you have designed in Catalog Extreme 4.0 Basic.
Cacidi Catalog Extreme AutoCalc 4.0
With Catalog Extreme 4.0 AutoCalc, Cacidi Systems now introduces fully automatic one-click production. It is so simple that everyone can implement even very large productions.
Cacidi Extreme BarCodes
Extreme BarCodes allows you to create bar codes directly in your InDesign document by simply selecting the bar code type and entering your data in the BarCodes palette.
jz979 当前离线
旧 2005-02-04, 20:38   只看该作者   #4
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
callas software GmbH
http://www.callassoftware.com/en/mad...e_indesign.php
MadeToPrint
MadeToPrint is an Adobe InDesign CS Plug-In that optimizes print output as well as the creation of PDF, EPS and PostScript files and minimizes mistakes in repetitive jobs. Aside from saving standard print settings, MadeToPrint includes several practical features to ensure an efficient and safe production environment.
Ctrl Publishing
http://www.ctrl-ps.com
CrossTalk CSoPrint
Facilitate and speed up your print production without equipping all team members with an expensive DTP programme.
CrossTalk CS together with Adobe InCopy CS makes it possible for everyone involved in print production projects to edit and make changes to artwork copy. Without buying and having to learn a complicated desktop publishing programme. CrossTalk CS allows each team member to give input on artwork copy in their own time and edit their own copy areas directly in the artwork document. No need to ask the Art Director or DTP operator to execute the changes, they are already done!
jz979 当前离线
旧 2005-02-04, 20:38   只看该作者   #5
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Datalogics, Inc.
http://www.datalogics.com
DL Formatter
DL Formatter is a high-speed variable print solution, ideally suited for creating personalized communications in Adobe PostScript?, Adobe PDF, or PPML for production environments or web applications.
Em Software, Inc.
http://www.emsoftware.com
InFlow
InFlow ia an InDesign plugin for Macintosh and Windows. InFlow eliminates the cumbersome, manual process of adding pages and linking text frames when text is added to a main text flow. Though InFlow was available as a bundled product with Em Software’s InCatalog? and InData? products for over a year now, InFlow is now available as a standalone product.
InCatalog
InCatalog is an easy-to-use linking tool for making two-way connections between elements in your InDesign? documents — text selections or whole text and picture box contents — and fields in your database(s).
InData
InData is a new InDesign plug-in that brings the full typographic- and picture-publishing power of InDesign to bear on all your data-driven, repetitive publishing tasks: catalogs, directories, form letters, financial summaries, tables, labels, lists of all sorts, and more.
jz979 当前离线
旧 2005-02-04, 20:39   只看该作者   #6
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Enfocus Software
http://www.enfocus.com
PDF CheckUp
Speed up your production process by checking Adobe PDF files as you export them from InDesign. Adds reporting options to InDesign's file menus so you can analyze PDF file properties and graphic objects. Armed with this information you can easily repair or replace missing fonts, missing or incorrectly compressed images, and color definitions.
Extensis, Inc.
http://www.extensis.com
Font Auto-Activation for Suitcase
The Suitcase plug-in for InDesign? 2.0 offers users the ability to automatically activate (or turn on) any fonts required by an InDesign 2.0 document when it is opened. The plug-in will also activate fonts within any EPS files that are placed within an InDesign document.
jz979 当前离线
旧 2005-02-04, 20:40   只看该作者   #7
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
GLUON, Inc.
http://www.gluon.com
Cropster ID
The professional’s choice for setting up on-page mechanicals. Working from a specified bleed, trim, and safety, you can add colored guides, crop marks, dimension arrows, colorbars, logos, date stamps, and more to the page. Complex fold setups can be created, complete with guides for fold and gutter marks. All settings can be saved as presets for easy recall later.
ProScale ID
The world’s premier scaler for InDesign?, ProScale ID has features that are necessary to serious design professionals. It includes the ability to scale items and selections nonproportionally, yet keep text and graphics from distorting. It also can resize entire multipage documents in one click. All settings can be saved as presets for convenient recall.
Slugger ID
GLUON has long been the leader in slug technology. Slugger allows you to place mission-critical information and graphics automatically on each page (on a separate layer). The information is then updated automatically upon printing and saving. Information used, information location, and the look and feel of slugs are fully customizable. Information can include such functions as path last saved to, last two users, time, fonts used, pictures used, colors used, and more than 20 others, all user-definable.
jz979 当前离线
旧 2005-02-04, 20:40   只看该作者   #8
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
J2S
http://www.j2s.net/
J2SAutodata
J2SAutoData is a plug-in designed to insert the total number of pages of a document and keep this number up to date as pages are added or removed. J2SAutoData also works with InDesign books.
Jeberien Production Tools
http://www.jeberien.de/
JPT AutoCredit
AutoCredit automates the listing and control of pictures and credit information used in InDesign documents. It automates the insertion of credit information out of the IPTC credit information record into the assigned Credit text box. The tool supports easy point-and-release operation to connect pictures with credit boxes. Automatic on-screen analysis of pictures with missing credit information. Display of IPTC records. Export of detailed report (tab format). AutoCredit is XMP-prepared.
Kitchen Wisdom
http://www.wiskit.com/indesign/
Recipe Design Wizard
brings your recipes into the twenty first century with a layout that is attractive and significantly easier to use than traditional recipes. If you enjoy cooking, please take a look at our Apple Crisp recipe, and let us know what you think of the layout, which we've prepared using our Recipe Design Wizard Plug-in and Adobe InDesign.
jz979 当前离线
旧 2005-02-04, 20:41   只看该作者   #9
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
KNOWBODY ApS
http://www.knowbody.dk/
Cool Tracking
Use this plugin to make general amendments to the spacing (tracking) of fonts in InDesign?. Use a coordinate system (a'la quark) to specify your tracking values. At the same time, you can see a wysiwyg preview of how the values effect a sample-text. Tracking tables are stored in packages making it easy to share the tables in your organisation. The packages follow the document.
Cool Kerning
This plugin allows you to do automatic update of kerning values. You specify the kerning values on a master document, and the complete kerning table is organised in packages, that are distributed automatically with the document.
Smart Paste
Are you copying a lot of text from word? This plugin allows you to copy text from word and other text programs into InDesign maintaining bold, italic etc. but without the styles definitions that often are wrong anyway.
Label IT
Do you print your pages? This plugin adds the names of placed images and text files on top of the document. This makes it easy to proof-read the pages knowing which version of the image is actually on the pages.
Stamp It
This plugin adds timestamps to the document. But it also allows you to add a list of font usage and a list of all the users who have modified the document.
KLiC — Knowbody License Center
This plugin is required for all of the above plugins if you want to run the licensed versions. The plugin fetches license information from Knowbodys homepage. It also has the option to ackt as a message center. Knowbody is able to deliver plugin-update information directly to you workspace
Late Night Software Ltd.
http://latenightsw.com/tagon/
Tag-On 1.0 XPress Tags Importer
Tag-On 1.0 is an Adobe InDesign? 2.0 plug-in that allows you to import text formatted using QuarkXPress XPress Tags directly into InDesign 2.0 documents.
Tag-On 1.0 allows existing workflows involving XPress Tags to easily migrate to Adobe InDesign 2.0 by allowing existing XPress Tags generation software to be used with InDesign 2.0. It supports automation through AppleEvent/AppleScript on the Macintosh, and COM/Visual Basic on Microsoft Windows.
Tag-On 1.0 provides an ideal alternative to InDesign’s InTags import format because the XPress Tags language is much simpler than InTags. By using XPress Tags and Tag-On, workflows can target both QuarkXPress and InDesign 2.0.
jz979 当前离线
旧 2005-02-04, 20:42   只看该作者   #10
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Managing Editor Inc.
http://www.maned.com
TruEdit
TruEdit is an easy-to-use workflow solution that hot-wires InDesign and InCopy with folder-based tools. Designers and editors can work collaboratively, sending updates back and forth as needed. TruEdit's straightforward interface and streamlined workflow elements can help you make the most of Adobe's powerful publishing applications.
MOAM, Inc.
http://www.moam-inc.com
QwikMarx
QwikMarx is the fastest and most accurate way to create dimensions in InDesign.
n’PINE, Inc.
http://mathmagic.com
MathMagic Pro
MathMagic Pro is a mathematical equation editor that supports WYSIWYG editing and many powerful features for high-end desktop publishing.
MathMagic is available for both Macintosh and Windows versions of InDesign.
jz979 当前离线
旧 2005-02-04, 20:43   只看该作者   #11
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Paladin Software
http://www.paladinsoft.com/
Palette Protector
InDesign? 2.0 usually does a fine job of remembering where you positioned your tool palettes, but, sometimes, particularly after you've added or deleted a plug-in, InDesign forgets. It positions your palettes back to default locations. That’s where Palette Protector comes in. Palette Protector remembers where your tool palettes were even when InDesign forgets, and then puts them back in the correct positions.
Paladin Unit Converter
This plug-in converts over 100 different units of length, weight, and volume. It’s been found particularly useful by those working on catalogs and cookbooks, and by anyone who has a need to convert between measurement units within InDesign. Best of all, this plug-in is presently free from Paladin Software to introduce you to Paladin’s custom InDesign plug-in programming services. Enjoy.
Pound Hill Software, Inc.
http://poundhill.com/
Catalyst 1.1
This latest version the ground-breaking tool for creating plug-ins to capture and embed metadata in popular content creation applications. Version 1.1 of Catalyst expands compatibility to Macintosh OS X version 10.3.x, QuarkXPress version 6.x, and to all Adobe Creative Suite applications. Catalyst, Metavue (a metadata viewer and search application), and Catalyst Plug-ins all utilize Adobe's Extensible Metadata Platform (XMP). Pound Hill also announced today the release of MetaLab, a free tool for defining and adding a new XMP metadata panel to the File Info… dialogs in Adobe Creative Suite applications. Information and downloads are available.
jz979 当前离线
旧 2005-02-04, 20:49   只看该作者   #12
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Quickcut
http://www.quickcut.com
QuickPrint
The foolproof way to create perfect ads.
Your days of worrying about mechanical specs and creative restrictions are over. Now QuickPrint? does all the hard work for you.
How It Works
QuickPrint? is a unique application that makes sure the ads you send to newspapers, magazines, and printers always reproduce the way you intended. Whenever you create a document using the QuickPrint? plug-in and InDesign?, the program automatically embeds all loose elements such as fonts or graphics into a single fully encapsulated EPS or PDF file, eliminating any risk of losing picture elements or other valuable information.
QuickPrint? delivers unparalleled security features to ensure you never have to deal with any unpleasant surprises.
For each new job, the application automatically sets up your documents with the correct type, trim, and bleed specifications for the publisher or printer you’re sending to.
Before QuickPrint? allows you to output any files, it performs over 100 individual quality-control checks. These include tests for jpeg encoding, PostScript? color management, and the effective resolution of a placed image. Depending on the individual publisher, any one of these could cause a problem.
No other file delivery system in the world is this comprehensive about safeguarding your files. It checks against a comprehensive database of publisher specifications to ensure you always get the most accurate representation of your ad.
To be absolutely sure the specifications are always 100% correct, they are constantly updated and maintained by the publishers and printers themselves. So no matter where in the world your document is headed, it’ll always reproduce exactly how you intended.
Save Money, Time and Embarrassment
Ad agencies can forget spending a lot of time and money on film, couriers, and author’s corrections. Now, QuickPrint?, in conjunction with PageStore?, Quickcut’s file delivery program lets you send documents directly to printers and publishers and know they’ll always be perfect every time.
And newspapers, magazines, and printers never again have to waste valuable time preparing jobs for print.
jz979 当前离线
旧 2005-02-04, 20:50   只看该作者   #13
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Sansui Software Pvt. Ltd.
http://www.sansuisoftware.com
PublishNow!
Create ads, collateral, and brochures instantly using this online InDesign-based solution.
Split Box fx
Split Box fx is a revolutionary plug-in for InDesign which allows users to quickly split standard InDesign text and image boxes into works of art. Use simple drop down menus for great looking effects or combinine multiple effects.
InDesign HTTP
InDesign HTTP enables an interface with digital asset management systems (AMS) anywhere in the world! It allows you to search, retrieve and archive assets from within InDesign over the web without needing a browser or a desktop application. With InDesign HTTP solution, you can readily manage all your digitised files such as images, graphics, text, logos, documents and web pages — ‘digital assets’ - so enabling easy and timely enterprise-wide access and feeding efficiently into traditional and new media publishing channels.
Fractions'N'Prices
Fractions'N'Prices is a plugin for Adobe InDesign (2.0.1 upwards) that automates the formatting of Fractions and Prices in text on the page. It also allows you to remove all manual kerning applied between characters or to remove kerning from a kerning pair.
SmartPage
The SmartPage suite of plug-ins contains pagination tools for Macintosh and Windows. SmartPage allows you to place your story according to how you would like it to appear on the final page of your newspaper.
Smart Ruler
The Smart Ruler tool is used to draw rules to the top, left, right, and bottom of stories on your page.
Smart Gravity
The Smart Gravity tool moves a text or graphic object in the direction chosen. The selected object will be moved to the edge of the page, or to the point at which it meets another object.
Smart Rubber
The Smart Rubber tool stretches the width or height of a text or graphic object in the direction chosen. The border of the selected object will be stretched up to the edge of the page, or to the point at which it meets another object.
Object Align Pro
Object Align Pro enables single-click alignment and repositioning of graphics and text-based story elements.
Super Styler Pro
Super Styler Pro enables single-click creation of story elements, flowing of stories and pictures from a clipboard or XML workflow, and autofitting of frames to a story or pictures.
SmartPageView
SmartPageView maps to page baskets or content folders and provides a single unified window from which you can see ready and pasted stories and pictures that you can and drag-and-drop into placeholders drawn on the page.
XPublisha
XPublisha is a tool for variable data publishing and catalog publishing automation. XPublisha flows XML from data files into placeholders in an InDesign? document in a few easy steps. This means you can flow thousands of records into hundreds of pages without working up a sweat.
jz979 当前离线
旧 2005-02-04, 20:51   只看该作者   #14
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
SoftCare GmbH
http://www.softcare.de
K4 Publishing System
The K4 Publishing System is a collaborative editorial system that integrates Adobe InDesign? and Adobe InCopy? with an open and scalable SQL database.
With its multilevel security controls and robust customization options, K4 supports a transparent and secure production workflow for individual workgroups or entire publishing enterprises across multiple locations. One of the hallmarks of K4 is its open SQL interface, enabling other systems such as asset management or automated prepress to be linked to K4.
Text-O-Meter
SoftCare’s Plug-in Text-O-Meter for Adobe InDesign and Adobe InCopy gives you complete control over text length and text overset, enabling you to count, display, edit and print overset text. Text-O-Meter also calculates text length by number of characters and number of lines in an accessible floating palette.
jz979 当前离线
旧 2005-02-04, 20:52   只看该作者   #15
jz979 jz979 当前离线
Uid: 385
jz979 jz979 当前离线
Uid: 385
Teacup Software
http://www.teacupsoftware.com/
PatternMaker
Designed by page layout guru David Blatner, the PatternMaker brings high quality PostScript patterns to InDesign. Fill any frame with one of fifteen patterns, then modify, tweak and reinvent each pattern into unlmited variations!
Palette Manager
Automatically Organize Your Palettes. Meant for any InDesign? user looking for maximum efficiency, the Palette Manager keeps track of what's being worked on and puts the right palettes right where they're needed.
Workspace Manager
Automatically Create Workspaces. The Workspace Manager automatically creates, saves and invokes palette workspaces without requiring any work from the user.Working with InDesign has never been easier!
Triple Triangle Inc.
http://www.tripletriangle.com/
Raster Write With AutoSave
Raster Write enabled designers to export JPEG, TIFF, and GIF images from InDesign? using flexible configuration options. Managers can use Raster Write's powerful AutoSave rules to create proofs automatically whenever selected documents are saved.
Tick Tock
Tick Tock enables freelancers and design departments to track the time they spend on InDesign documents. Tick Tock reduces the hassle associated with tracking billable hours so that you can devote more time to creative design.
Tick Tock helps you to track your time using a customizable list of activities, allows you to enter notes about your work, and lets you view and edit the work history of your documents. You can export the document history to a file for reporting and billing purposes.
Virginia Systems
http://www.virginiasystems.com
Sonar Bookends InDex and Sonar Bookends Index Pro
Sonar Bookends InDex, and Sonar Bookends InDex Pro, are powerful automatic index generators capable of producing both an index and a table of contents for InDesign.
Sonar Bookends InFnote
Footnote/endnote management software for InDesign.
Sonar Bookends InXref
Cross-reference generator for InDesign.
jz979 当前离线
ID CS 应用技巧汇总 cn911 ◆- Adobe 设计软件应用 69 2006-05-10 10:51
ID CS 应用技巧汇总 zhanggrgj ◆- Adobe 设计软件应用 4 2006-04-14 16:48
PageMaker的终结者——排版天才InDesign sirdar ◆- Adobe 设计软件应用 5 2006-01-04 14:35
Adobe InDesign 的历史 wbamyln ◆- Adobe 设计软件应用 3 2005-01-24 09:50
中文版InDesign排版软件 ctkkhtdwxf ◆- Adobe 设计软件应用 27 2004-08-24 19:57
所有时间均为 +8, 现在的时间是 2025-01-04 13:08.
