2005-04-04, 14:12 | #1 | ||
Selectively display layers and layer comps in Photoshop® files, and layers in Adobe PDF files, to experiment with different design options or use multiple variations of a file in your layout — all while linking to a single file. Anchored Objects Easily anchor callouts, pull quotes, margin notes, and graphics to text. Precisely control the positioning of Anchored Objects, apply text wrap settings, and more. Repeated transformations Automatically repeat transformations, such as scale, skew, rotate, and fit, from one object to another. Shape-to-shape conversion Use convenient buttons in the Pathfinder palette to convert an object from one shape to another, such as turning a rectangle into an ellipse of the same size. Noise and Spread for drop shadow control Adjust Noise and Spread options to fine-tune the appearance of drop shadows and feathers onscreen and in print. Noise gives them a rougher or grainier texture; spread controls the amount of blur in a drop shadow. Consistent color Synchronize color settings across Adobe applications with one click of your mouse to achieve consistent color onscreen. Exchange color swatches across all the components of Adobe Creative Suite 2. Color Picker Use a color picker similar to the one in Adobe Photoshop and Illustrator® software to visually select RGB, CMYK, or LAB colors. Adobe Bridge Browse, organize, label, and preview graphics and InDesign documents, templates, and snippets in Adobe Bridge. Drag and drop assets from Adobe Bridge into layouts easily and efficiently. Search for files using metadata, such as keywords, colors, and image resolution. Object styles Apply and globally update object-level formatting more efficiently using object styles. Save a wide range of graphic, text, and frame-level attributes as object styles to create more consistent designs and speed up production tasks. InDesign snippets Easily export InDesign objects as snippets, which can be shared with colleagues or reused in other documents. When you place or drag a snippet into a layout, InDesign re-creates the original objects, their formatting, and their relative positioning on the page. Improved Microsoft Word and RTF support Automatically style Microsoft Word files on import by mapping Word styles to InDesign styles. Also resolve style name conflicts at import, preserve local overrides while removing other formatting, and save Word import settings as presets for future use. Style management Selectively load paragraph, character, and object styles from other InDesign documents, and control how InDesign handles style name conflicts. Quick-apply styles Quickly sort through dozens or even hundreds of styles to find and apply the one you want without taking your hands off the keyboard. Drag-and-drop text Drag and drop text within and between text frames, tables, views, and documents. Also drag and drop text from other applications, such as Microsoft Word, into InDesign layouts. Flexible dictionary management Link to one or more user dictionaries at once on your hard drive or network. Import and export word lists for convenient dictionary updating. Paste without formatting Automatically strip formatting from copy as you paste it from one location to another in Adobe InCopy® CS2 software, or from a source application such as Microsoft Word or e-mail into your InCopy CS2 file. The pasted text then inherits the formatting applied to its new destination. Frame-level baseline grids Set up baseline grids at the text-frame level to accurately lay out a mix of different leading values in your designs. Footnote support Use dynamic footnotes with your preferred numbering and layout options. Footnotes travel appropriately across columns and pages as text flow changes. Import footnotes from Microsoft Word and RTF text files. XML table tagging Easily apply XML tags to InDesign tables. Then import XML content into the tables or export it from them. Enhanced XML import Import XML files with flexible control using the Structure view and Tags palette. Automatically flow XML into tagged templates or import and interactively place it. Enhanced options give you greater import control and make it easier to achieve the results you want. Linked XML files Create a link to an XML file on import, so you can easily update your placed XML content whenever the source XML content is updated. Adobe InCopy CS2 assignments Assign only the elements of a document that an editor needs to work on in InCopy CS2 while you're designing the rest — whether that's specific frames on a page, frames on one or more spreads, or all the frames in a document. Multipage Adobe PDF files Import a page, a range of pages, or all the pages in an Adobe PDF file at once for faster layout and production. Adobe PDF export presets Use one of the included Adobe PDF presets to more consistently and reliably create Adobe PDF files from InDesign CS2 and any other component of Adobe Creative Suite 2. Now you can customize and share these “joboptions” files with others. Backwards compatibility with InDesign CS Export your InDesign CS2 document to the InDesign Interchange (INX) format and open it in InDesign CS for sharing with people still working in the previous version. Package for GoLive command Export objects or a complete InDesign document to jump-start your Web design. Then open in Adobe GoLive® software and choose to generate an XHTML Web site automatically, apply a CSS template, or drag and drop design elements into your Web page. |
2005-04-04, 21:38 | 只看该作者 #6 | ||
1。Adobe 桥 (Adobe Bridge) 在adobe 桥中浏览、组织、标示和预览图像和Indesign文档、模版、片断。可以非常方便和高效率的在桥窗口中拖放素材到页面中。使用元数据搜索文件,例如关键词、色彩、和图像分辨率。 2。物件样式 可以很有效的使用物件样式对物件级的页面对象应用全局性的样式化。保存图像、文本、框架等等的物件属性为物件样式来快速统一做出一致性的设计方案。 3。Photoshop和PDF图层支持 对photoshop图层文件和pdf图层文件,选择性显示图层和组织图层,快速尝试不同风格的设计,这只需要在indesign中连接一个图层文件就可以完成。 4。indesign 片断 可以方便的把一个indesign对象生成为一个片断,这样你可以把这个片断和你的同事分享或都放在其它文档中,当你置入或拖放片断到页面,indesign重新创建原物件,他们会格式化和放置在页面的相对位置。 5。incopy cs 2 协作 分配文档元素——编辑只需在incopy cs 2中工作余下的就是你的设计了——特定的框是该放在某一页、某一跨页或更多跨页、或者整个文档。 6。对indesign cs 的向下兼容性 导出你的 indesign cs 2 文档为INX文档,并可在前 indesign cs 版本中打开分享,继续编辑。 7。锚物件 非常容易的锚定插图号、拨注、旁注、图像到文本。应用文本绕排设置可恰到好处的布置锚定的物件、使用文本绕排设定等其它功能。 8。改良的Microsoft word和RTF文档的支持 导入 Microsoft word 文档时自动化映射word的样式为indesign 的样式,导入的样式名称相冲突问题得到了解决,当移除其他格式时保留了本地样式名称,并以边框形式保存Word导入的设置供备用。 9。智能文本操作, 享受强大的文本操作特性,包括可以拖放和粘贴非格式化文本,加入了一个完整的文字处理工具以更快的编辑。 10。灵活的XML支持 导入的XML文档更易掌控,包括链接XML内容以轻易的更新,映射 XML 标签到表格,然后导入 XML 内容,再从表格中导出它们。 |
2005-04-04, 21:45 | 只看该作者 #7 | ||
支持Adobe Photoshop 和 Adobe PDF图层 可选择性的显示Photoshop文件的图层、图层复合,以及Adobe PDF文件的图层,您可以在版面设计中对一个文件进行多种变化,试验不同的设计效果。 锚物体 轻松地将插图的编号、引用、页边旁注以及图形锚定到文本上。还可以精确地控制锚物体的位置,应用文本绕排以及更多的设置。 重复变化 自动的重复变化,比如从一个物体到另一个物体的缩放、倾斜、旋转、匹配操作等。 外型转换 使用“路径寻找器(Pathfinder)”调板上便利的按钮,可以将对象从一个形状转换到另一个形状,比如将一个矩形转换为一个等大的椭圆形。 投影增加杂点和扩展控制 调节“杂色(Noise)”和扩展选项可调整投影和羽化在屏幕或打印时的外观。 “杂色(Noise)”为投影产生颗粒状的纹理;扩展则控制投影中模糊的程度。 调和颜色 在Adobe程序间同步颜色设置只需您点击一下鼠标即可实现屏幕上一致的颜色。 交换色样通用于Adobe Creative Suite 2的所有成员。 颜色吸管 使用类似于Adobe Photoshop和Illustrator软件一样可视化的颜色拾取工具选择RGB、CMYK或者LAB颜色。 Adobe Bridge 您现在可在Adobe Bridge中浏览、管理、批注、预览图形以及InDesign的文档、模版或者InDesign片断。从Adobe Bridge拖放素材到InDesign中更是简洁高效。同时,你还可以使用诸如关键字、颜色、图像分辨率等元数据(Metadata)进行文件搜索。 对象样式 使用对象样式可以更有效地应用以及整体更新对象级别的外观。将诸多类型的素材如图形、文本以及图文框级别的属性保存为对象样式,可供快速创作更多一致的设计。 InDesign 片断 轻松地将InDesign对象输出为可供同事分享或者在其他文档中重用的片断。当您置入或拖拽一个片断到版式设计中时,InDesign将重新生成这个原始的对象,它们的格式,以及它们在页面中的相对位置。 改良的Microsoft Word和RTF支持 输入时将Word样式映射到InDesign样式。这样可以避免样式名称冲突,移除其他格式时保护局部设置,以及保存Word输入设置为预置供重复使用。 样式管理 可选择性地从其他InDesign文档载入段落、字符以及对象样式并控制如何处理InDesign样式名称的冲突。 快速应用样式 即使不用键盘也可以将多个甚至上百个样式快速排序,方便你查找和应用希望的样式。 拖拽文本 在文本框、表格、视图以及文档之间拖拽文本。也能从其他应用程序如Microsoft Word中拖拽文本到InDesign版式设计中。 灵活的目录管理 一次性的在您的硬盘驱动器或网络驱动器上链接一个或多个用户目录。输入或输出字符列表进行便利的目录更新。 忽略格式粘贴 从副本中自动剔除样式,比如您在Adobe InCopy CS2软件中从一个位置粘贴到另一个位置,或者从一个来源程序比如Microsoft Word或E-mail到您的InCopy CS2文件。这些粘贴的文本当时继承了格式并应用到了新的目标中。 文本框级别基线网格 在您的设计中以文本框级别设置基线网格,依此精确的安排混合不同的行距设置。 支持脚注 按照您设定的编号和布局选项使用动态的脚注。脚注能像文本流更改一样正确处理跨越栏及页面的情形。可以从Microsoft Word及RTF文本文件中输入脚注。 XML表格标记 轻松地应用XML标签到InDesign表格上。现在可以输入XML内容到表格或者从表格输出XML。 增强的XML输入 使用结构视图和标签调板灵活的控制XML文件的输入。自动地流入XML到标签模版或者输入并进行交互替换。增强的选项提供给您足够的输入控制,轻易达到您需要的结果。 链接XML文件 输入时创建一个XML文件的链接。由此您可以轻易的更新您置入的XML内容——只要源XML内容是最新的。 Adobe InCopy CS2 分配 当设计到一定程度后,可以将文档中的元素指派到InCopy CS2供编辑人员使用,无论是单个的文本框,还是跨页的文本框甚至文档中的所有文本框。 多页 Adobe PDF 文件 一次性输入Adobe PDF文件的一个页面、一个页码段或者所有页面,用于快速版式设计和生产。 Adobe PDF 输出预置 在InDesign CS2以及Adobe Creative Suite 2的其他成员中,使用内置的Adobe PDF预置可创建更为统一可靠的Adobe PDF文件。现在您可以自定义并同他人分享这些“作业选项”文件。 InDesign CS 向后兼容 同那些仍在使用上一个版本的人们交流时,可输出您的InDesign CS2文档为InDesign (INX)交换格式,用InDesign CS打开。 打包至 GoLive 命令 输出整个InDesign文档或物体开始您的Web设计。将打开Adobe GoLive软件并自动选择生成一个 XHTML站点,应用CSS模版,或者拖拽设计元素到您的Web页面中。 系统需求 - Intel® Pentium® III或4处理器 - Microsoft® Windows® 2000 (SP3)或Windows XP - 256MB of RAM (推荐 320MB) - 850MB 可用硬盘空间 - 1,024x768 显示器分辨率 16位视频卡 (推荐24位屏幕显示) - CD-ROM 驱动器 - QuickTime 6(用于多媒体特性) - Adobe PostScript® 打印机:PostScript Level 2 or PostScript 3™ - Internet 或电话连接用于产品激活 - Internet宽带连接用于Adobe Stock Photos (Adobe Stock Photos 可能不能供所有国家、语言可用且会经常更改。使用该服务由Adobe Stock Photos服务组管理。更多信息请访问Adobe Stock Photos。) 官方链接:http://www.adobe.com/products/indesign/newfeatures.html |
发表新主题 关闭主题 |
相似的主题 | ||||
主题 | 论坛 | |||
在驴里发现个好东西--2005年0DAY图形图象软件插件合集 | ◆- Adobe 设计软件应用 | |||
PageMaker的终结者——排版天才InDesign | ◆- Adobe 设计软件应用 | |||
Adobe InDesign 的历史 | ◆- Adobe 设计软件应用 | |||
中文版InDesign排版软件 | ◆- Adobe 设计软件应用 |
